Chuyên đề giải đáp những thắc mắc về code VBA
maytinhvp01
trong ví du:
max = Ran.Cells(1, 1)
For d = 1 To Ran.Rows.Count
Next c
Next d
v = Tim(max, Ran)
LonNhat = max
[INFO1]Thông báo:
Vì topic này:
đã quá dài nên BQT đóng lại.
NDU96081631
[/INFO1]
Sub Boimau()
Sheets("UU").Select
Range("N11:O38").Select
With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.ThemeColor = xlThemeColorLight2
.TintAndShade = 0.799981688894314
.PatternTintAndShade = 0
Sheets("YE").Select
.Pattern = xlSolid
Sheets("YG").Select
.Pattern = xlSolid
Sheets("YH").Select
.Pattern = xlSolid
Sheets("YJ").Select
.Pattern = xlSolid
Sheets("YN").Select
.Pattern = xlSolid
Sheets("YQ").Select
.Pattern = xlSolid
Sheets("YP").Select
.Pattern = xlSolid
Sheets("YR").Select
.Pattern = xlSolid
Sheets("YS").Select
.Pattern = xlSolid
Sheets("YT").Select
.Pattern = xlSolid
Sheets("QQ").Select
.Pattern = xlSolid
Sheets("NN").Select
.Pattern = xlSolid
Sheets("PP").Select
.Pattern = xlSolid
Sheets("VV").Select
.Pattern = xlSolid
Sheets("SS").Select
.Pattern = xlSolid
Sheets("TT").Select
.Pattern = xlSolid
Sheets("RR").Select
.Pattern = xlSolid
Sheets("QQ").Select
Nhờ các thầy cô rút ngẵn đoạn code giúp em được không ạ
Chạy thử xem sao
Sub Boimau_()
Dim Ten
Dim Ws As Worksheet
Dim IDic As Object
Dim t
Set IDic = CreateObject("Scripting.Dictionary")
Ten = Array("UU", "YE", "YG", "YH", "YJ", "YN", "YQ", "YP", "YR", "YS", "YT", "QQ", "NN", "PP", "VV", "SS", "TT", "RR", "QQ")
For Each t In Ten
    IDic.Item(t) = ""
Next t
For Each Ws In Worksheets
    If IDic.exists(Ws.Name) Then
        Ws.Range("N11:O38").Select
        .Pattern = xlSolid
Next Ws
Chạy thử xem sao
Sub Boimau_()
Dim Ten
Dim Ws As Worksheet
Dim IDic As Object
Dim t
For Each t In Ten
    IDic.Item(t) = ""
Next t
        .Pattern = xlSolid
Next Ws
Nó báo lỗi thầy ơi
    178.7 KB · Đọc: 4
Sub GPE(Rng As Range)
 With Rng.Interior
    .Pattern = xlSolid:                                 .PatternColorIndex = xlAutomatic
    .ThemeColor = xlThemeColorLight2:     .TintAndShade = 0.799981688894314
Sub Boimau()
 Sheets("UU").Select
 Range("N11:O38").Select:           GPE Selection
 Sheets("YE").Select
 Sheets("YG").Select
 Sheets("YH").Select
 Sheets("YJ").Select
 Sheets("YN").Select
 Sheets("YQ").Select
 Sheets("YP").Select
 Sheets("YR").Select
 Sheets("YS").Select
 Sheets("YT").Select
 Sheets("QQ").Select
 Sheets("NN").Select
 Sheets("PP").Select
 Sheets("VV").Select
 Sheets("SS").Select
 Sheets("TT").Select
 Sheets("RR").Select
 Sheets("QQ").Select
With Rng.Interior
Sub Boimau()
Sheets("UU").Select
Sheets("YE").Select
Sheets("YG").Select
Sheets("YH").Select
Sheets("YJ").Select
Sheets("YN").Select
Sheets("YQ").Select
Sheets("YP").Select
Sheets("YR").Select
Sheets("YS").Select
Sheets("YT").Select
Sheets("QQ").Select
Sheets("NN").Select
Sheets("PP").Select
Sheets("VV").Select
Sheets("SS").Select
Sheets("TT").Select
Sheets("RR").Select
Sheets("QQ").Select
Nó chạy lâu quá thầy ơi. Hay máy em cùi mía nhỉ
Sub Boimau()
  Dim Ws As Worksheet, TenSheet As String
  TenSheet = "#UU#YE#YG#YH#YJ#YN#YQ#YP#YR#YS#YT#QQ#NN#PP#VV#SS#TT#RR#"
    If InStr(1, TenSheet, "#" & Ws.Name & "#") > 0 Then
      With Ws.Range("N11:O38").Interior
        .Pattern = xlSolid
  Next Ws
Sub XuatPDF()
ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF
FileName = "ThisWorkbook & Name.pdf"
Quality = xlQualityStandard
IncludeDocProperties = True
IgnorePrintAreas = False
Nhờ các thầy cô sửa giúp em đoạn code trên với ạ. Em muốn xuất tất cả sheet trong cùng 1 file. nhưng cái code trên nó lại chỉ xuất cái sheet hiện hành.
Nếu em muốn xuất PDF mà nó lưu vào khu vực mình muốn thì thêm code như nào ạ
Sub Main()
    Const thumuc_gioidanh As String = "D:\Gioi danh"
    Dim ws As Worksheet
    For Each ws In ThisWorkbook.Worksheets
        If ws.Visible = xlSheetVisible Then
            Luu_PDF ws, thumuc_gioidanh
    Next ws
Sub Luu_PDF(ByVal ws As Worksheet, ByVal Noi_luu As String)
    ws.ExportAsFixedFormat Type:=xlTypePDF, Filename:=Noi_luu & "\" & ws.Name & ".pdf"
Nhờ mọi người giải thích dùm em ý nghĩa đoạn code bên dưới , qua trọng các dòng em đánh số .
code lồng nhiều hàm if quá ko hiểu nổi !!!
Sub fifoNL()
  Dim nhapArr(), xuatArr(), Res()
  Dim I As Long, n As Long, sRow As Long
  Dim sNhap As Double, sXuat As Double, dXuat As Date
  Dim Ma As String, tmp As String
  With Sheets("DATANL")
    I = .Range("A" & Rows.Count).End(xlUp).Row
    If I < 3 Then MsgBox ("Khong co du lieu"): Exit Sub
    nhapArr = .Range("A3:D" & I).Value
    I = .Range("F" & Rows.Count).End(xlUp).Row
    xuatArr = .Range("F3:H" & I).Value
    sRow = UBound(xuatArr)
1    ReDim Res(1 To sRow, 1 To 1)
  For I = 1 To sRow
    dXuat = xuatArr(I, 1): Ma = xuatArr(I, 2): sXuat = xuatArr(I, 3)
2     tmp = ""
    If Len(Ma) > 0 And sXuat > 0 Then
      For n = 1 To UBound(nhapArr)
        If nhapArr(n, 1) > dXuat Then Exit For
        If nhapArr(n, 2) = Ma Then
          sNhap = nhapArr(n, 3)
          If sNhap > 0 Then
            If sNhap >= sXuat Then
3              Res(I, 1) = tmp & nhapArr(n, 4)
4              If Len(tmp) > 0 Then Res(I, 1) = Res(I, 1) & "(" & sXuat & ")"
              nhapArr(n, 3) = sNhap - sXuat
              sXuat = 0
              Exit For
5              tmp = tmp & nhapArr(n, 4) & "(" & sNhap & "); "
              nhapArr(n, 3) = 0
              sXuat = sXuat - sNhap
      Next n
6      If sXuat > 0 Then Res(I, 1) = tmp & "Thieu(" & sXuat & ")"
  Next I
7  Sheets("DATANL").Range("I3").Resize(sRow) = Res
Sub fifoNL()
  For I = 1 To sRow
2     tmp = ""
          If sNhap > 0 Then
              sXuat = 0
              Exit For
              nhapArr(n, 3) = 0
      Next n
  Next I
Nếu muốn rõ ràng thì bạn nên gửi kèm theo file chứa code lên cho nhanh
Đọc code này thấy sặc mùi sì tin GPE.
Lấy ở thớt nào thì chịu khó cho luôn đường dẫn, bà con khỏi mất công tìm hiểu.
(ví dụ có những chỗ code dở hay sai, không thấy ngữ cảnh làm sao biết)
Em mới học VBA mà tìm và thử mãi vẫn chưa làm được chọn ô cuối cùng của mảng vừa chọn. Nhờ các bác giúp đỡ với ạ.
Trân trọng cảm ơn!
Sub Chon_o_cuoi()
    Sheets("Sheet1").range("mang1").Select
'    Cần code tiếp theo để đưa chuột về ô cuối cùng của mảng "mang1"
Trân trọng cảm ơn!
Sub Chon_O_Cuoi()
    Sheets("Sheet1").Range("mang1").Select
    With Selection
        If .Columns.Count = 1 Then
            .Offset()(.Rows.Count).Select
            .Offset()(.Cells.Count).Select
        MsgBox Selection.Address
Trân trọng cảm ơn!
Sub Chon_o_cuoi()
  Selection(Selection.Rows.Count, Selection.Columns.Count).Select
Sub Chon_o_cuoi()
Sub Chon_O_Cuoi()
 '  Range1 = Union(Range("A2:B3"), [C1: D9])        '
    Sheets("Sheet1").Range("Range1").Select
