hỏi cách lấy dữ liệu từ bảng giá chứng khoán trực tuyến trên web vào file excel (4 người xem)
Fpts chặn priceboard rồi, giờ phải có tk mới vào được
Trang vcbs
Public Sub hello(ByVal selectedStocks As String, ByVal criteriaId As String, ByVal pthMktId As String)
Dim str As String, payload As String, arr
'template Payload:{"selectedStocks":"AAM,ABT","criteriaId":"-11","marketId":0,"lastSeq":0,"isReqTL":false,"isReqMK":false,"tlSymbol":"","pthMktId":""}
payload = "{""selectedStocks"":""" & selectedStocks & """,""criteriaId"":""" & criteriaId & """,""marketId"":0,""lastSeq"":0," & _
"""isReqTL"":false,""isReqMK"":false,""tlSymbol"":"""",""pthMktId"":""" & pthMktId & """}"
With CreateObject("MSXML2.ServerXMLHTTP")
    .Open "POST", "http://quotes.vcbs.com.vn/PriceBoard/Acc/amw", False
    .setRequestHeader "Content-Type", "application/json"
    .send (payload)
    str = .ResponseText
If Len(pthMktId) = 0 Then
    arr = tachBangGia(str)
    arr = tachGDTT(str)
Sheet1.Range("A5").Resize(UBound(arr) + 1000, UBound(arr, 2) + 50).ClearContents
Sheet1.Range("A5").Resize(UBound(arr), UBound(arr, 2)).Value = arr
Private Function tachBangGia(ByVal stResponse As String)
Dim lStart As Long, lEnd As Long, arr, dArr, dicColName As Object, r As Long
Dim rowData, cellData, c As Long, colIndex As Long
Dim regec As Object, mats As Object, mat As Object
Set dicColName = CreateObject("Scripting.Dictionary")
dicColName.CompareMode = vbTextCompare
arr = Array("SB", "CL", "FL", "RE", "B3", "V3", "B2", "V2", "B1", "V1", "CH", "CP", "CV", "S1", _
"U1", "S2", "U2", "S3", "U3", "TT", "OP", "HI", "LO", "FB", "FS", "FR")
For r = 0 To UBound(arr) Step 1
    dicColName(arr(r)) = r + 1
ReDim dArr(1 To 1000, 1 To dicColName.Count)
tachBangGia = dArr
lStart = WorksheetFunction.Max(1, InStr(1, stResponse, """f"":["))
lEnd = InStr(lStart, stResponse, "],")
If lStart < 2 Or lEnd < 2 Then Exit Function
stResponse = Replace(Mid(stResponse, lStart, lEnd - lStart + 1), "\""", "")
arr = Split(stResponse, "Id:")
Set regec = CreateObject("VBScript.RegExp")
regec.Pattern = "[A-Z][A-Z0-9]\:[^,]*(,\d+)*"
'[A-Z][A-Z0-9]\:.*?(?=,[A-Z][A-Z0-9]\:)
regec.Global = True
For r = LBound(arr) + 1 To UBound(arr) Step 1
    Set mats = regec.Execute(arr(r))
    For Each mat In mats
        cellData = Split(mat, ":")
        If dicColName.exists(cellData(0)) Then
            colIndex = dicColName(cellData(0))
            dArr(r, colIndex) = IIf(CStr(cellData(1)) = "null", "", cellData(1))
tachBangGia = dArr
Private Function tachGDTT(ByVal stResponse As String)
Dim lStart As Long, lEnd As Long, dicColName As Object, arr, dArr, r As Long
Dim colIndex As Long, rowData, colName As String, cellData, c As Long
arr = Array("Symbol", "Price", "MatchVol", "fake", "Time")
tachGDTT = dArr
lStart = WorksheetFunction.Max(1, InStr(1, stResponse, """pm"":["))
lEnd = InStr(lStart, stResponse, "}]")
stResponse = Replace(Mid(stResponse, lStart, lEnd - lStart + 2), """", "")
arr = Split(stResponse, "{Id:")
    rowData = Split(arr(r), ",")
    For c = LBound(rowData) + 1 To UBound(rowData) Step 1
        lStart = InStr(1, rowData(c), ":")
        If lStart > 0 Then
            cellData = Mid(rowData(c), lStart + 1)
            colName = Left(rowData(c), lStart - 1)
            If dicColName.exists(colName) Then
                colIndex = dicColName(colName)
                If colIndex = 2 Then
                    dArr(r, colIndex) = cellData / 1000
                    dArr(r, 4) = "=RC[-2] * RC[-1]"
tachGDTT = dArr
Public Function createVcbsList()
Dim arr(1 To 50, 1 To 4), curRow As Long, str As String
    .Open "GET", "http://quotes.vcbs.com.vn/PriceBoard", False
    .send
    str = .ResponseText
tachGroup str, arr, "HOSE", curRow
tachGroup str, arr, "HNX", curRow
tachGroup str, arr, "UPCOM", curRow
createVcbsList = arr
Private Sub tachGroup(ByVal stResponse As String, ByRef arr, groupName As String, ByRef curRow As Long)
Dim lStart As Long, lEnd As Long, mats As Object, mat As Object
Static regec As Object, domDoc As Object
lStart = InStr(1, stResponse, "id=""" & groupName & "_Group""")
lEnd = InStr(lStart, stResponse, "</ul>")
If regec Is Nothing Then
    regec.Pattern = "onclick\=\""selectTab\(([^\)]+)[\s\S]+?(<p>[\s\S]+?</p>)[\s\S]+?(value\=\""([\s\S]+?))?</li>"
    regec.IgnoreCase = True
    regec.Global = True
    Set domDoc = CreateObject("Msxml2.DOMDocument")
Set mats = regec.Execute(Mid(stResponse, lStart, lEnd - lStart + 5))
    curRow = curRow + 1
    arr(curRow, 1) = groupName
    domDoc.LoadXML mat.submatches(1)
    arr(curRow, 2) = domDoc.Text
    arr(curRow, 3) = mat.submatches(0)
    If Len(mat.submatches(3)) > 0 Then
        arr(curRow, 4) = Left(mat.submatches(3), InStr(1, mat.submatches(3), """") - 1)
Cái này bạn có thể cho mỗi bảng của ba sàn lúc lấy về cho vào 3 sheet khác nhau được k?
Trang vcbs
    .send (payload)
    str = .ResponseText
    arr = tachGDTT(str)
tachBangGia = dArr
regec.Global = True
tachBangGia = dArr
tachGDTT = dArr
        If lStart > 0 Then
tachGDTT = dArr
    .send
    str = .ResponseText
    regec.Global = True
    curRow = curRow + 1
Có thể lấy dữ liệu bảng giá phái sinh và chứng quyền không anh ơi
Mình không biết lấy bạn ơi. Bạn liên hệ bài #64 nhé.
Bác ơi, cháu tìm trên internet có mỗi file của bác là lấy được dữ liệu bảng giá, nhưng chỉ lấy được dữ liệu một sàn nhất định mỗi lần.
Hiện cháu mong muốn lấy bảng giá trực tuyến, toàn bộ giữ liệu của mỗi sàn (3 sàn - tất cả các mã) vào chung một sheet/hoặc mỗi sàn vào một sheet cũng được ạ. (Nếu có thể thêm được auto refresh theo thời gian đặt thì tốt cho cháu lắm ạ).
Nhờ Bác có thể chỉnh giúp cháu được không ạ.
Đây là file của bác đã làm trong chủ đề ạ.
Cháu cám ơn các bác nhiều ạ!
Trên vcbs bị chặn rồi. Xin bác @AutoReply giúp với. Lỗi chắc ở khúc này. Đường link ko vào được nữa.
.send (payload)
str = .ResponseText
XIN LỖI LÀM PHIỀN BÁC. ĐÃ TRUY CẬP LẠI BÌNH THƯỜNG RỒI Ạ.
Trang vcbs
    .send (payload)
    str = .ResponseText
    arr = tachGDTT(str)
tachBangGia = dArr
regec.Global = True
tachBangGia = dArr
tachGDTT = dArr
        If lStart > 0 Then
tachGDTT = dArr
    .send
    str = .ResponseText
    regec.Global = True
    curRow = curRow + 1
Bác ơi, trang bảng giá của VCBS mới thay đổi hôm nay (31/12/2020), giờ file này không update được nữa. Bác xem chỉnh sửa file giúp theo bảng giá mới của VCBS được không ạ. Cám ơn bác nhiều!
trong file có cái nút bấm , tùy chọn sàn mà lấy nhé
Public Sub hello(ByVal region As String, ByVal targetTB As String)
Dim arr(1 To 2000, 1 To 25), r As Long, str As String
Dim mats, mapID, mat, dArr, ub As Long, col As Long
    .Open "GET", "http://priceboard.fpts.com.vn/" & region & "/data.ashx?s=quote&l=" & targetTB, False
    .send
    str = .ResponseText
mapID = Array(1, 2, 3, 4, -1, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, _
        16, 17, 18, 19, -1, 20, 21, 22, 23, -1, 24, 25)
ub = UBound(mapID) + 1
With CreateObject("VBScript.RegExp")
    .Global = True
    .Pattern = "\[""?(\d{1,2})""?,""?([^\]""]+)""?"
    dArr = Split(str, "}")
    For r = 0 To UBound(dArr)
        Set mats = .Execute(dArr(r))
            col = mat.submatches(0)
            If col < ub Then
                If mapID(col) > 0 Then
                    arr(r + 1, mapID(col)) = mat.submatches(1)
làm ơn nói kỹ
tôi chưa va cái này bao giờ
có ai biết tải thì giúp với ạ
vithong
Bác có thể tham khảo thêm ứng dụng tại bài viết ở link bên dưới:
    .send
    str = .ResponseText
    .Global = True
            If col < ub Then
Em chào Chị AutoReply xinh đẹp!
Em có tải file ở bài #7 về chạy mà nó không chạy. Em gửi Chị đường link nguồn một số trang lấy bảng giá chứng khoán:
https://priceboard.vcbs.com.vn/Priceboard
https://iboard.ssi.com.vn/bang-gia-ssi/hose
https://liveboard.cafef.vn/?center=1
https://banggia.vndirect.com.vn/chung-khoan/danh-muc
Chị có thể sửa lại code, chỉ cần bấm 1 cái là code chạy full các mã của 2 sàn giao dịch: Hồ chí minh và Hà Nội. Rất mong Chị giúp đỡ. Cảm ơn Chị nhiều!
Trang vcbs
    .send (payload)
    str = .ResponseText
    arr = tachGDTT(str)
tachBangGia = dArr
regec.Global = True
tachBangGia = dArr
tachGDTT = dArr
        If lStart > 0 Then
tachGDTT = dArr
    .send
    str = .ResponseText
    regec.Global = True
    curRow = curRow + 1
Bạn AutoReply ơi bạn có thể sửa lại code của bảng VCBS được không vì hiện nó bị lỗi không dùng được.
Cảm ơn bạn nhiều!
Cảm ơn bạn nhiều!
Mình đã đổi lại link của VCBS nhưng nó bị lỗi ở câu lệnh bị bôi vàng như sau:
Bạn có thể sửa giúp được không? Cảm ơn bạn nhiều!
tren nay nhieu nguoi gioi qua, bai phuc bai phuc
