hỏi cách lấy dữ liệu từ bảng giá chứng khoán trực tuyến trên web vào file excel (23 người xem)
Mong được các anh giành thời gian giúp đỡ :(
Trang vcbs
Public Sub hello(ByVal selectedStocks As String, ByVal criteriaId As String, ByVal pthMktId As String)
Dim str As String, payload As String, arr
'template Payload:{"selectedStocks":"AAM,ABT","criteriaId":"-11","marketId":0,"lastSeq":0,"isReqTL":false,"isReqMK":false,"tlSymbol":"","pthMktId":""}
payload = "{""selectedStocks"":""" & selectedStocks & """,""criteriaId"":""" & criteriaId & """,""marketId"":0,""lastSeq"":0," & _
"""isReqTL"":false,""isReqMK"":false,""tlSymbol"":"""",""pthMktId"":""" & pthMktId & """}"
With CreateObject("MSXML2.ServerXMLHTTP")
    .Open "POST", "http://quotes.vcbs.com.vn/PriceBoard/Acc/amw", False
    .setRequestHeader "Content-Type", "application/json"
    .send (payload)
    str = .ResponseText
If Len(pthMktId) = 0 Then
    arr = tachBangGia(str)
    arr = tachGDTT(str)
Sheet1.Range("A5").Resize(UBound(arr) + 1000, UBound(arr, 2) + 50).ClearContents
Sheet1.Range("A5").Resize(UBound(arr), UBound(arr, 2)).Value = arr
Private Function tachBangGia(ByVal stResponse As String)
Dim lStart As Long, lEnd As Long, arr, dArr, dicColName As Object, r As Long
Dim rowData, cellData, c As Long, colIndex As Long
Dim regec As Object, mats As Object, mat As Object
Set dicColName = CreateObject("Scripting.Dictionary")
dicColName.CompareMode = vbTextCompare
arr = Array("SB", "CL", "FL", "RE", "B3", "V3", "B2", "V2", "B1", "V1", "CH", "CP", "CV", "S1", _
"U1", "S2", "U2", "S3", "U3", "TT", "OP", "HI", "LO", "FB", "FS", "FR")
For r = 0 To UBound(arr) Step 1
    dicColName(arr(r)) = r + 1
ReDim dArr(1 To 1000, 1 To dicColName.Count)
tachBangGia = dArr
lStart = WorksheetFunction.Max(1, InStr(1, stResponse, """f"":["))
lEnd = InStr(lStart, stResponse, "],")
If lStart < 2 Or lEnd < 2 Then Exit Function
stResponse = Replace(Mid(stResponse, lStart, lEnd - lStart + 1), "\""", "")
arr = Split(stResponse, "Id:")
Set regec = CreateObject("VBScript.RegExp")
regec.Pattern = "[A-Z][A-Z0-9]\:[^,]*(,\d+)*"
'[A-Z][A-Z0-9]\:.*?(?=,[A-Z][A-Z0-9]\:)
regec.Global = True
For r = LBound(arr) + 1 To UBound(arr) Step 1
    Set mats = regec.Execute(arr(r))
    For Each mat In mats
        cellData = Split(mat, ":")
        If dicColName.exists(cellData(0)) Then
            colIndex = dicColName(cellData(0))
            dArr(r, colIndex) = IIf(CStr(cellData(1)) = "null", "", cellData(1))
tachBangGia = dArr
Private Function tachGDTT(ByVal stResponse As String)
Dim lStart As Long, lEnd As Long, dicColName As Object, arr, dArr, r As Long
Dim colIndex As Long, rowData, colName As String, cellData, c As Long
arr = Array("Symbol", "Price", "MatchVol", "fake", "Time")
tachGDTT = dArr
lStart = WorksheetFunction.Max(1, InStr(1, stResponse, """pm"":["))
lEnd = InStr(lStart, stResponse, "}]")
stResponse = Replace(Mid(stResponse, lStart, lEnd - lStart + 2), """", "")
arr = Split(stResponse, "{Id:")
    rowData = Split(arr(r), ",")
    For c = LBound(rowData) + 1 To UBound(rowData) Step 1
        lStart = InStr(1, rowData(c), ":")
        If lStart > 0 Then
            cellData = Mid(rowData(c), lStart + 1)
            colName = Left(rowData(c), lStart - 1)
            If dicColName.exists(colName) Then
                colIndex = dicColName(colName)
                If colIndex = 2 Then
                    dArr(r, colIndex) = cellData / 1000
                    dArr(r, 4) = "=RC[-2] * RC[-1]"
tachGDTT = dArr
Public Function createVcbsList()
Dim arr(1 To 50, 1 To 4), curRow As Long, str As String
    .Open "GET", "http://quotes.vcbs.com.vn/PriceBoard", False
    .send
    str = .ResponseText
tachGroup str, arr, "HOSE", curRow
tachGroup str, arr, "HNX", curRow
tachGroup str, arr, "UPCOM", curRow
createVcbsList = arr
Private Sub tachGroup(ByVal stResponse As String, ByRef arr, groupName As String, ByRef curRow As Long)
Dim lStart As Long, lEnd As Long, mats As Object, mat As Object
Static regec As Object, domDoc As Object
lStart = InStr(1, stResponse, "id=""" & groupName & "_Group""")
lEnd = InStr(lStart, stResponse, "</ul>")
If regec Is Nothing Then
    regec.Pattern = "onclick\=\""selectTab\(([^\)]+)[\s\S]+?(<p>[\s\S]+?</p>)[\s\S]+?(value\=\""([\s\S]+?))?</li>"
    regec.IgnoreCase = True
    regec.Global = True
    Set domDoc = CreateObject("Msxml2.DOMDocument")
Set mats = regec.Execute(Mid(stResponse, lStart, lEnd - lStart + 5))
    curRow = curRow + 1
    arr(curRow, 1) = groupName
    domDoc.LoadXML mat.submatches(1)
    arr(curRow, 2) = domDoc.Text
    arr(curRow, 3) = mat.submatches(0)
    If Len(mat.submatches(3)) > 0 Then
        arr(curRow, 4) = Left(mat.submatches(3), InStr(1, mat.submatches(3), """") - 1)
ồ thật vậy sao bạn ? Nhưng thôi mình không dám phản đối bạn đâu. Khi có quá ít thời gian thì đành phải công nhận như vậy, khỏe hơn. --=0--=0
í, hổng chịu đâu. :(:(
Bạn ở trên biểu là "nghĩ" như thế thôi.
Cô Rô bốt mà dỗi là bắt đền bạn ở trên. Hu hu.
    187.3 KB · Đọc: 247
    132.8 KB · Đọc: 225
Tôi không biết gì hết, không hiểu gì hết. Giờ các bạn diễn đàn nói gì tôi cũng thấy đúng. Thế là nhẹ nhàng thanh thản. hi hi %#^#$%#^#$
Bạn @AutoReply mình hỏi xíu mình muốn lấy theo ngành với lại macro tự động cập nhật số mới của thị trường sau 3 phút hay 5 phút gì đó thì mình code mình nên viết ntn nhỉ? mình cũng không rành phần này lắm
Cảm ơn bạn nhiều
Em lần đầu tiên vào web e thấy bác @AutoReply siêu thật. E chưa bao giờ được học nhưng thấy các anh viết trên đây thật ngưỡng mộ các anh. Chúc các anh sức khoẻ và thành công.
cám ơn bác rất nhiều, em tìm cách link dữ liệu mãi mà không được.
bạn Autoreply ơi, chỉ giúp mình với. Mình ko thấy có nút bấm nào trên file cả, nút bấm đó ở đâu à bạn
