Phiên bản mới đây. Tốc độ nhanh hơn bản cũ. Khắc phục tốc độ bị chậm khi dùng Shift để chọn nhiều item.
[GPECODE=vb]
Set check sate with selected items in ListView
' By Nguyen Duy Tuan (duytuan@bluesofs.net)
www.giaiphapexcel.com
Private IdxOfFirst As Long, IdxOfSecond As Long
Private IsShiftKeyPressed As Boolean, IsCtrlKeyPressed As Boolean
Private MustClearAll As Boolean, IsClickCheck As Boolean
Dim CurrentItem As MSComctlLib.ListItem
Dim I As Long
With ListView1
.MultiSelect = True 'Cho phep chon nhieu item va chay CheckItemsWithSelectState trong ListView1_ItemClick
.ColumnHeaders.Add , , "VALUE", .Width - 4
.CheckBoxes = True
For I = 1 To 10000
.ListItems.Add , , "Item" & I
IdxOfFirst = .SelectedItem.Index
IdxOfSecond = IdxOfFirst
Private Sub ListView1_ColumnClick(ByVal ColumnHeader As MSComctlLib.ColumnHeader)
ColumnHeader.Tag = Not CBool(IIf(ColumnHeader.Tag = "", 0, ColumnHeader.Tag))
CheckItems CBool(ColumnHeader.Tag), Nothing, True
MustClearAll = CBool(ColumnHeader.Tag)
Private Sub ListView1_ItemClick(ByVal Item As MSComctlLib.ListItem)
Set CurrentItem = Item
Private Sub ListView1_ItemCheck(ByVal Item As MSComctlLib.ListItem)
'when mouse click on item to set check state
MustClearAll = True
IsClickCheck = True
Item.Selected = Item.Checked
Private Sub ListView1_MouseUp(ByVal Button As Integer, ByVal Shift As Integer, ByVal x As stdole.OLE_XPOS_PIXELS, ByVal y As stdole.OLE_YPOS_PIXELS)
If IsClickCheck Then
IsClickCheck = False
Exit Sub
If Not CurrentItem Is Nothing Then
If ListView1.MultiSelect Then
CheckItemsWithSelectState CurrentItem
Private Function CheckItems(ByVal bCheck As Boolean, ByVal Item As ListItem, ByVal bSelectIfChecked As Boolean) As Long
Dim I As Long, IdxCurrent As Long
If Not Item Is Nothing Then
IdxCurrent = Item.Index
Dim ItemVisible As MSComctlLib.ListItem
Set ItemVisible = ListView1.GetFirstVisible
For I = ItemVisible.Index To ListView1.ListItems.Count
CheckItems = CheckItems + 1
If IdxCurrent <> I Then 'don't set state for current index
If ListView1.ListItems(I).Checked <> bCheck Then
ListView1.ListItems(I).Checked = bCheck
If bSelectIfChecked Then
ListView1.ListItems(I).Selected = bCheck
DoEvents
Next I
For I = ItemVisible.Index To 1 Step -1
DoEvents
Next I
Private Function CheckItemsWithSelectState(ByVal Item As ListItem) As Long
Dim I As Long
IsShiftKeyPressed = IsShiftKeyDown()
IsCtrlKeyPressed = IsControlKeyDown()
If IsCtrlKeyPressed Then
Item.Checked = Item.Selected
MustClearAll = True
Exit Function
'If no shift, no ctrl press then check to clear check state for all items
If Not (IsShiftKeyPressed Or IsCtrlKeyPressed) Then
If MustClearAll Then
MustClearAll = False
CheckItems False, Item, False
'Clear old seleted items
For I = IdxOfFirst To IdxOfSecond
If I <> Item.Index Then
ListView1.ListItems(I).Checked = False
Next I
' find IdxOfFirst from current index
For I = Item.Index To 1 Step -1
If Not ListView1.ListItems(I).Selected Then
Exit For
IdxOfFirst = I
Next I
' find IdxOfSecond from current index
For I = Item.Index To ListView1.ListItems.Count
Exit For
IdxOfSecond = I
Next I
'Set check state for new selected items
For I = ItemVisible.Index To IdxOfSecond
ListView1.ListItems(I).Checked = ListView1.ListItems(I).Selected
DoEvents
Next I
For I = ItemVisible.Index To IdxOfFirst Step -1
DoEvents
Next I
[/GPECODE]
