Add-in A-Tools: Query, Share and manage Excel workbooks on LAN, Internet (1 người xem)
Nguyễn Duy Tuân
Nghị Hách
Giáo viên, CEO tại Bluesofts
A-Tools is an add-in software which runs on Microsoft Excel. A-Tools has the following functions :
1. Share and manage Excel workbooks on the network
Add-in A-Tools allows sharing Excel workbook for multiple users editing on the same spreadsheet on LAN or internet (network). The server can assign rights for each user group are allowed to open any sheet, the data for editing or read-only. Access speed is very fast. Protocol to connect to the server and client is TCP IP, thus Add-in A-Tools is a tool to share Excel spreadsheets over the network is safe and effective.
[video=youtube;N3nYDYNlWv0]http://www.youtube.com/watch?v=N3nYDYNlWv0&feature=related[/video]​
2. Query data on spreadsheet/worksheet, links variety of database to spreadsheet
Add-in A-Tools can create dynamic reports by using the functions to query the database (DB) with T-SQL language. It also allows users to connect to the internal and external database such as Excel, Access, Foxpro, MS SQL, MySQL and Firebird,... for instance.
The "SQL Builder" helps users to create a query formula (with BS_SQL function) easily and efficiently. Users are able to create highly sophisticated worksheets which are filtered according to various conditions and associated with different data sources. In that way, accuracy, stability and high speed are ensured
http://www.youtube.com/watch?v=NWZM6kJAPZE
Thanks in advance for your critics and comments.
DOWNLOAD
cậu Tuân chơi toàn tiếng Tây --=0
Cài đặt xong, hiện lên thông báo sau.
Setup
Runtime Error (at 121:6335):
Access violation at address 7C9101B3 in module 'ntdll.dll'. Write of address 774E2192.
OK
Mở Excel lên không thấy A-tools. Phải vào Tools/Add-ins…. Chọn lại đường dẫn.
Thực hiện chức năng chuyển mã từ Unicode sang VNI bị lỗi và thoát khỏi Excel.
Su dung Office 2003 va 2010
Setup
OK
Bạn kiểm tra có phải máy đang dùng pm diệt virus Avira không, nếu phải thì làm theo hướng dẫn ở đay:
http://www.bluesofts.net/cau-hoi-th...n-may-da-cai-phan-mem-diet-virus-qaviraq.html
Bạn Tuân ơi mình cài A Tools trên excel 2013 win 8 64 bit bị lỗi Custom UI Runtime Error. Mình có kèm theo ảnh bạn xem giúp mình fix lỗi với
    14.8 KB · Đọc: 66
Bạn kiểm tra xem Office của bạn là phiên bản nào (mục About)? Home, Business, Professional?
Phiên bản Professional plus 2013 32 bit bạn Tuân ơi. Mình cài A Tool và BSAC đều bị lỗi như trên hết
