Tổng hợp 2 sheet dữ liệu thành 1 (5 người xem)
Bạn xài macro sau & những mong là khỏi đưa file lên
Sub CopyFrom2Sheets()
 Dim Col As Byte, jJ As Long, lRw As Long
 Dim Sh1 As Worksheet, Sh2 As Worksheet
 Set Sh1 = Sheets("S1"):                     Set Sh2 = Sheets("S2")
 jJ = Sh1.Cells.Find(What:="*", After:=Sh1.[A1], SearchOrder:= _
   xlByColumns, SearchDirection:=xlPrevious).Column
 Col = Sh2.Cells.Find(What:="*", After:=Sh2.[A1], SearchOrder:= _
 If jJ > Col Then Col = jJ
 jJ = Sh1.Cells.Find(What:="*", After:=Sh1.[A1], SearchOrder:=xlByRows, _
   SearchDirection:=xlPrevious).Row
 lRw = Sh2.Cells.Find(What:="*", After:=Sh2.[A1], SearchOrder:=xlByRows, _
 If jJ > lRw Then lRw = jJ
 Sheets("S0").Select:                        Cells.ClearContents
 For jJ = 1 To Col
   Cells(1, 2 * jJ - 1).Resize(lRw).Value = Sh1.Cells(jJ).Resize(lRw).Value
   Cells(1, 2 * jJ).Resize(lRw).Value = Sh2.Cells(jJ).Resize(lRw).Value
 Next jJ
Chú í khi dùng: Tên các trang tính là 'S1', 'S2' & 'S0'
For jJ = 1 To Col
Next jJ
Tuyệt lắm bạn HYen17! Cảm ơn bạn rất nhiều! Chúc ngày mới thắng lợi!
Nếu em gán hết vào S0 và sort lại thì thời gian còn 1/4.
Còn nếu em dùng array thế range thì thời gian còn 1/3.
Sub CopyFrom2SheetsA()
Dim T
Dim iCol As Long, iCl As Long, iRw As Long, iRow As Long
Dim Sh1 As Worksheet, Sh2 As Worksheet, myRng As Range
Dim Arr01(), Arr02()
T = Timer
With Sh1
 iCl = .Cells.Find(What:="*", After:=.[A1], SearchOrder:= _
 iRw = .Cells.Find(What:="*", After:=.[A1], SearchOrder:=xlByRows, _
If iCl > iCol Then iCol = iCl
If iRw > iRow Then iRow = iRw
With Sh2
With Sh1
  Arr01 = .Cells(1, 1).Resize(iRow, iCol).Value
With Sh2
  Arr02 = .Cells(1, 1).Resize(iRow, iCol).Value
Sheets("S0").Select
Cells.ClearContents
Cells(1, 1).Resize(iRow, iCol).Value = Arr01
Cells(1, 1).Offset(, iCol).Resize(iRow, iCol).Value = Arr02
Erase Arr01, Arr02
Set myRng = Cells(1, 1).Resize(iRow, iCol * 2)
With myRng
 .Sort Key1:=.Cells(1, 1), Order1:=xlAscending, Header:=xlGuess, _
        OrderCustom:=1, MatchCase:=False, Orientation:=xlLeftToRight, _
        DataOption1:=xlSortNormal
Set myRng = Nothing
MsgBox Timer - T
Sub CopyFrom2SheetsB()
Dim T
Dim Arr01(), Arr02(), ArrKQ()
T = Timer
With Sh1
With Sh2
With Sh1
With Sh2
ReDim ArrKQ(1 To iRow, 1 To iCol * 2)
For iCl = 1 To iCol
  For iRw = 1 To iRow
    ArrKQ(iRw, 2 * iCl - 1) = Arr01(iRw, iCl)
    ArrKQ(iRw, 2 * iCl) = Arr02(iRw, iCl)
  Next iRw
Next iCl
Sheets("S0").Select
Cells.ClearContents
Cells(1, 1).Resize(iRow, iCol * 2).Value = ArrKQ
Erase Arr01, Arr02, ArrKQ
MsgBox Timer - T
Híc, nhìn code của chị Hải Yến và bạn Thu Nghi hoa cả mắt, cứ như đi trên Đào Hoa đảo của Hoàng dược sư vậy
Xin góp một cách nông dân _ nghĩ sao làm vậy cho nó ...dễ hiểu
Public Sub Gheplungtung()
    Dim Vung As Range, Sh, I As Integer, Cot As Integer
    Cells.Clear
        For I = 1 To 2
            Set Sh = Sheets("S" & I)
            Cot = Sh.[cw1].End(xlToLeft).Column
            Set Vung = Sh.Range(Sh.[a1], Sh.[a5000].End(xlUp)).Resize(, Cot)
                If [a1] = "" Then
                    [a1].Resize(Vung.Rows.Count, Cot) = Vung.Value
                    [cw1].End(xlToLeft)(1, 2).Resize(Vung.Rows.Count, Cot) = Vung.Resize(, Cot).Value
                        With ActiveWorkbook.Worksheets("S0").Sort
                            .Header = xlGuess
                            .MatchCase = False
                            .Orientation = xlLeftToRight
                            .SortMethod = xlPinYin
                            .Apply
Góp vui code này thử xem ?
Application.ScreenUpdating = 0
    Sheets("Sheet3").Cells.Clear
    Sheets("Sheet1").[a1].CurrentRegion.Resize(50000).Copy Sheets("Sheet3").[a1]
    Sheets("Sheet2").[a1].CurrentRegion.Resize(50000).Copy Sheets("Sheet3").[IV1].End(1)(1, 2)
    Cells.Sort [a1], 1, , , , , 2
Tuy có vài dòng code, nhưng khi chạy thì như vịt, vì
Bạn không xác định dòng cuối của dữ liệu mà ấn cho nó 5 vạn dòng thì ngất ngư chứ chả chơi!
Chúc vui!
Chúc vui!
Cảm ơn thầy đã nhắc nhở em mới nhớ đến thuộc tính UsetRange http://www.giaiphapexcel.com/forum/showthread.php?6419-Thuộc-tính-UsedRange&p=44286#post44286
    Sheets("Sheet1").UsedRange.Copy Sheets("Sheet3").[a1]
    Sheets("Sheet2").UsedRange.Copy Sheets("Sheet3").[IV1].End(1)(1, 2)
Chắc chắn không có cách nào nhanh hơn cách sort thông thương này (vì hầu như nó chẳng làm điều gì ghê gớm, cứ như ta làm bằng tay)
Thử nghiệm trên dữ liệu 50000 dòng trên mổi sheet thì cách của ThuNghi ra kết quả trong vòng 5s, cách của anh Trung Chinh ra kết quả trong vòng 2s
Mà nói chung thì cách dùng Sort Left to Right ta cảm giác tin tưởng hơn
Mà anh Trung Chinh nè, em thấy đoạn
có vẽ không ổn
Em nghĩ nên vầy chứ
Sheets("Sheet3").UsedRange.Sort [A1], 1, , , , , , 1, , , 2
Vâng! Cảm ơn GPE rất nhiều! GPE có thể giúp mình làm trường hợp ngược lại được không ạ? Tức là nếu mình đã có sẵn kết quả là số liệu nhập theo số cột tự nhiên liên tiếp và bây giờ muốn tách ra sang 2 sheet khác: một sheet là số liệu theo cột chẵn và một sheet là số liệu theo cột lẻ!
Thủ code này nhé bạn
Public Sub tach()
    Dim I As Long, J As Long, iCot As Long, Sh As Worksheet
        iCot = [bw1].End(xlToLeft).Column
            For I = 1 To 2
                Set Sh = Sheets("Sheet" & I + 1)
                    For J = I To iCot Step 2
                        Cells(J).EntireColumn.Hidden = True
                        Range([a1], [a5000].End(xlUp)).Resize(, iCot).SpecialCells(12).Copy Sh.[a1]
                        Cells.EntireColumn.Hidden = False
Mình có file excel mong GPE giúp đỡ! Chân thành cảm ơn!
Mạn phép các thầy đã trả lời ở trên, em không quen dùng code; nên em dùng hàm có được không?
Hàm như sau: =IF(ISEVEN(COLUMN());INDEX(Sheet2!$A$1:$AJ$122;ROW();MATCH(COLUMN()+9;Sheet2!$A$1:$AJ$1;0));INDEX(Sheet1!$A$1:$AJ$122;ROW();MATCH(COLUMN()+9;Sheet1!$A$1:$AJ$1;0)))
Em trả lại file đã được làm (em lam tren 3 mang cung nhau ve kich thuc nhu file yeu cau kem theo):
