sep_hatxel
Sub CopyFrom2Sheets()
 Dim Col As Byte, jJ As Long, lRw As Long
 Dim Sh1 As Worksheet, Sh2 As Worksheet
 Set Sh1 = Sheets("S1"):                     Set Sh2 = Sheets("S2")
 jJ = Sh1.Cells.Find(What:="*", After:=Sh1.[A1], SearchOrder:= _
   xlByColumns, SearchDirection:=xlPrevious).Column
 Col = Sh2.Cells.Find(What:="*", After:=Sh2.[A1], SearchOrder:= _
 If jJ > Col Then Col = jJ
 jJ = Sh1.Cells.Find(What:="*", After:=Sh1.[A1], SearchOrder:=xlByRows, _
   SearchDirection:=xlPrevious).Row
 lRw = Sh2.Cells.Find(What:="*", After:=Sh2.[A1], SearchOrder:=xlByRows, _
 If jJ > lRw Then lRw = jJ
 Sheets("S0").Select:                        Cells.ClearContents
 For jJ = 1 To Col
   Cells(1, 2 * jJ - 1).Resize(lRw).Value = Sh1.Cells(jJ).Resize(lRw).Value
   Cells(1, 2 * jJ).Resize(lRw).Value = Sh2.Cells(jJ).Resize(lRw).Value
 Next jJ
Tuyệt lắm bạn HYen17! Cảm ơn bạn rất nhiều! Chúc ngày mới thắng lợi!PHP:Option Explicit Sub CopyFrom2Sheets() Dim Col As Byte, jJ As Long, lRw As Long Dim Sh1 As Worksheet, Sh2 As Worksheet Set Sh1 = Sheets("S1"): Set Sh2 = Sheets("S2") jJ = Sh1.Cells.Find(What:="*", After:=Sh1.[A1], SearchOrder:= _ xlByColumns, SearchDirection:=xlPrevious).Column Col = Sh2.Cells.Find(What:="*", After:=Sh2.[A1], SearchOrder:= _ xlByColumns, SearchDirection:=xlPrevious).Column If jJ > Col Then Col = jJ jJ = Sh1.Cells.Find(What:="*", After:=Sh1.[A1], SearchOrder:=xlByRows, _ SearchDirection:=xlPrevious).Row lRw = Sh2.Cells.Find(What:="*", After:=Sh2.[A1], SearchOrder:=xlByRows, _ SearchDirection:=xlPrevious).Row If jJ > lRw Then lRw = jJ Sheets("S0").Select: Cells.ClearContents For jJ = 1 To Col Cells(1, 2 * jJ - 1).Resize(lRw).Value = Sh1.Cells(jJ).Resize(lRw).Value Cells(1, 2 * jJ).Resize(lRw).Value = Sh2.Cells(jJ).Resize(lRw).Value Next jJ End Sub
Chú í khi dùng: Tên các trang tính là 'S1', 'S2' & 'S0'
Nếu em gán hết vào S0 và sort lại thì thời gian còn 1/4.PHP:Option Explicit Sub CopyFrom2Sheets() End Sub
Sub CopyFrom2SheetsA()
Dim T
Dim iCol As Long, iCl As Long, iRw As Long, iRow As Long
Dim Sh1 As Worksheet, Sh2 As Worksheet, myRng As Range
Dim Arr01(), Arr02()
T = Timer
With Sh1
 iCl = .Cells.Find(What:="*", After:=.[A1], SearchOrder:= _
 iRw = .Cells.Find(What:="*", After:=.[A1], SearchOrder:=xlByRows, _
If iCl > iCol Then iCol = iCl
If iRw > iRow Then iRow = iRw
With Sh2
With Sh1
  Arr01 = .Cells(1, 1).Resize(iRow, iCol).Value
With Sh2
  Arr02 = .Cells(1, 1).Resize(iRow, iCol).Value
Sheets("S0").Select
Cells.ClearContents
Cells(1, 1).Resize(iRow, iCol).Value = Arr01
Cells(1, 1).Offset(, iCol).Resize(iRow, iCol).Value = Arr02
Erase Arr01, Arr02
Set myRng = Cells(1, 1).Resize(iRow, iCol * 2)
With myRng
 .Sort Key1:=.Cells(1, 1), Order1:=xlAscending, Header:=xlGuess, _
        OrderCustom:=1, MatchCase:=False, Orientation:=xlLeftToRight, _
        DataOption1:=xlSortNormal
Set myRng = Nothing
MsgBox Timer - T
Sub CopyFrom2SheetsB()
Dim T
Dim Arr01(), Arr02(), ArrKQ()
T = Timer
With Sh1
With Sh2
With Sh1
With Sh2
ReDim ArrKQ(1 To iRow, 1 To iCol * 2)
For iCl = 1 To iCol
  For iRw = 1 To iRow
    ArrKQ(iRw, 2 * iCl - 1) = Arr01(iRw, iCl)
    ArrKQ(iRw, 2 * iCl) = Arr02(iRw, iCl)
  Next iRw
Next iCl
Sheets("S0").Select
Cells.ClearContents
Cells(1, 1).Resize(iRow, iCol * 2).Value = ArrKQ
Erase Arr01, Arr02, ArrKQ
MsgBox Timer - T
	Public Sub Gheplungtung()
    Dim Vung As Range, Sh, I As Integer, Cot As Integer
    Cells.Clear
        For I = 1 To 2
            Set Sh = Sheets("S" & I)
            Cot = Sh.[cw1].End(xlToLeft).Column
            Set Vung = Sh.Range(Sh.[a1], Sh.[a5000].End(xlUp)).Resize(, Cot)
                If [a1] = "" Then
                    [a1].Resize(Vung.Rows.Count, Cot) = Vung.Value
                    [cw1].End(xlToLeft)(1, 2).Resize(Vung.Rows.Count, Cot) = Vung.Resize(, Cot).Value
                        With ActiveWorkbook.Worksheets("S0").Sort
                            .Header = xlGuess
                            .MatchCase = False
                            .Orientation = xlLeftToRight
                            .SortMethod = xlPinYin
                            .Apply
Application.ScreenUpdating = 0
    Sheets("Sheet3").Cells.Clear
    Sheets("Sheet1").[a1].CurrentRegion.Resize(50000).Copy Sheets("Sheet3").[a1]
    Sheets("Sheet2").[a1].CurrentRegion.Resize(50000).Copy Sheets("Sheet3").[IV1].End(1)(1, 2)
    Cells.Sort [a1], 1, , , , , 2
Bạn không xác định dòng cuối của dữ liệu mà ấn cho nó 5 vạn dòng thì ngất ngư chứ chả chơi!
Chúc vui!
    Sheets("Sheet1").UsedRange.Copy Sheets("Sheet3").[a1]
    Sheets("Sheet2").UsedRange.Copy Sheets("Sheet3").[IV1].End(1)(1, 2)
	Chắc chắn không có cách nào nhanh hơn cách sort thông thương này (vì hầu như nó chẳng làm điều gì ghê gớm, cứ như ta làm bằng tay)Cảm ơn thầy đã nhắc nhở em mới nhớ đến thuộc tính UsetRange http://www.giaiphapexcel.com/forum/showthread.php?6419-Thuộc-tính-UsedRange&p=44286#post44286
Mã:Private Sub Worksheet_Activate() Application.ScreenUpdating = 0 Sheets("Sheet3").Cells.Clear Sheets("Sheet1").UsedRange.Copy Sheets("Sheet3").[a1] Sheets("Sheet2").UsedRange.Copy Sheets("Sheet3").[IV1].End(1)(1, 2) Cells.Sort [a1], 1, , , , , 2 End Sub
Thủ code này nhé bạnVâng! Cảm ơn GPE rất nhiều! GPE có thể giúp mình làm trường hợp ngược lại được không ạ? Tức là nếu mình đã có sẵn kết quả là số liệu nhập theo số cột tự nhiên liên tiếp và bây giờ muốn tách ra sang 2 sheet khác: một sheet là số liệu theo cột chẵn và một sheet là số liệu theo cột lẻ!
Public Sub tach()
    Dim I As Long, J As Long, iCot As Long, Sh As Worksheet
        iCot = [bw1].End(xlToLeft).Column
            For I = 1 To 2
                Set Sh = Sheets("Sheet" & I + 1)
                    For J = I To iCot Step 2
                        Cells(J).EntireColumn.Hidden = True
                        Range([a1], [a5000].End(xlUp)).Resize(, iCot).SpecialCells(12).Copy Sh.[a1]
                        Cells.EntireColumn.Hidden = False
	Mình có file excel mong GPE giúp đỡ! Chân thành cảm ơn!
