Dưới đây là một số ví dụ về sử dụng API trong VBA (lấy từ Sample.xls của Excel 2000) để các bạn tham khảo:
1. Lấy tên các ổ đĩa trong máy:
2. Xác định độ phân giải màn hình:
3. Xác định UserName truy cập Window:
Private Declare Function GetLogicalDriveStrings Lib "kernel32" Alias "GetLogicalDriveStringsA" _
(ByVal nBufferLength As Long, _
ByVal lpBuffer As String) As Long
Sub Get_Logical_Drive_String()
Dim DrvString As String
Dim TotDrvs As Long
Dim Counter As Integer
'TotDrvs returns the total number of characters in return string
TotDrvs = GetLogicalDriveStrings(0&, DrvString)
'DrvString is the buffer created to hold the string
DrvString = String(TotDrvs - 1, " ")
'Calling GetLogicalDriveStrings a second time fills the string with valid data
'example "a:\c:\d:\e:\"
TotDrvs = GetLogicalDriveStrings(TotDrvs, DrvString)
'Parse through the return string displaying each in a msgbox
For Counter = 1 To TotDrvs Step 4
MsgBox Mid(DrvString, Counter, 3)
Next Counter
Private Declare Function GetSystemMetrics Lib "user32" (ByVal nIndex As Long) As Long
'Constants for GetSystemMetrics
Const SM_CXSCREEN = 0 ' Width of screen
Const SM_CYSCREEN = 1 ' Height of screen
Sub Get_System_Metrics()
Dim XVal As Long, YVal As Long
YVal = GetSystemMetrics(SM_CYSCREEN)
XVal = GetSystemMetrics(SM_CXSCREEN)
MsgBox "Your Screen Resolution is " & XVal & " by " & YVal
Private Declare Function GetUserName Lib "advapi32.dll" Alias "GetUserNameA" _
(ByVal lpBuffer As String, _
nSize As Long) As Long
Sub Get_User_Name()
Dim lpBuff As String * 25
Dim ret As Long, UserName As String
ret = GetUserName(lpBuff, 25)
UserName = Left(lpBuff, InStr(lpBuff, Chr(0)) - 1)
MsgBox UserName
