shnhatha221108
Em muốn tổng hợp dữ liệu từ nhiều file vào một file "TH" chứa các sheet tương ứng MS1,MS2
Mong anh chị em giải pháp chỉnh sửa giúp đoạn code:
	Sub TongHop()
    Dim cnn As Object, lsSQL As String, lrs As Object, Fname
    Dim Fso As Object, Link As String, shNameNguon, shNameDich, i As Long
    Set Fso = CreateObject("Scripting.FileSystemObject")
    Set lrs = CreateObject("ADODB.Recordset")
    shNameNguon = Array("NGAY_1", "NGAY_2")
    shNameDich = Array("MS1", "MS2")
    With Application.FileDialog(msoFileDialogFilePicker)
        .AllowMultiSelect = True
        .Filters.Add "Microsoft Excel Files", "*.xls; *.xlsx; *.xlsb; *.xlsm", 1
        If .Show = -1 Then
            Link = .InitialFileName
            MsgBox "Ban da khong chon tong hop", vbInformation, "Thong Bao"
            Exit Sub
        For Each Fname In .SelectedItems
            With cnn
                If Val(Application.Version) < 12 Then
                    .ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;" _
                                      & "Data Source=" & Fname & ";Extended Properties=""Excel 8.0;HDR=No"";"
                    .ConnectionString = "Provider=Microsoft.ACE.OLEDB.12.0;" _
                                      & "Data Source=" & Fname & ";Extended Properties=""Excel 12.0;HDR=No"";"
                .Open
            For i = 0 To UBound(shNameNguon)
                lsSQL = "SELECT * FROM [" & shNameNguon(i) & "$A3:W10000]"
                lrs.Open lsSQL, cnn, 3, 1
                Sheets(shNameDich(i)).Range("A6:W50000").ClearContents
                Sheets(shNameDich(i)).Range("B50000").End(3).Offset(1, 0).CopyFromRecordset lrs
                lrs.Close
    cnn.Close
    Set lrs = Nothing
    Set cnn = Nothing
