Option Compare Text
Option Private Module
#If Mac Then
#Else
  #If VBA7 Then
    Private Declare PtrSafe Function ScreenToClient Lib "USER32" (ByVal Hwnd As LongPtr, lpPoint As POINTAPI) As Long
    Private Declare PtrSafe Function ShowWindow Lib "user32.dll" (ByVal Hwnd As LongPtr, ByVal lCmdShow As Long) As Boolean
    Private Declare PtrSafe Function LockWindowUpdate Lib "USER32" (ByVal hwndLock As LongPtr) As Long
  #Else
    Private Declare Function ScreenToClient Lib "user32" (ByVal hwnd As Long, lpPoint As POINTAPI) As Long
    Private Declare Function ShowWindow Lib "user32.dll" (ByVal hWnd As Long, ByVal lCmdShow As Long) As Boolean
    Private Declare Function LockWindowUpdate Lib "user32" (ByVal hwndLock As Long) As Long
  #End If
  #If VBA7 Then
    Private Declare PtrSafe Function getTickCount Lib "kernel32" Alias "GetTickCount" () As Long
  #Else
    Private Declare Function GetTickCount Lib "kernel32" () As Long
  #End If
  #If VBA7 Then
    Private Declare PtrSafe Function IsClipboardFormatAvailable Lib "USER32" (ByVal wFormat As LongPtr) As Long
    Private Declare PtrSafe Function GlobalUnlock Lib "kernel32" (ByVal hMem As LongPtr) As LongPtr
    Private Declare PtrSafe Function GlobalSize Lib "kernel32" (ByVal hMem As LongPtr) As Long
    Private Declare PtrSafe Function GlobalLock Lib "kernel32" (ByVal hMem As LongPtr) As LongPtr
    Private Declare PtrSafe Function GlobalAlloc Lib "kernel32" (ByVal wFlags As Long, ByVal dwBytes As LongPtr) As LongPtr
    Private Declare PtrSafe Function CloseClipboard Lib "USER32" () As Long
    Private Declare PtrSafe Function OpenClipboard Lib "USER32" (ByVal Hwnd As LongPtr) As LongPtr
    Private Declare PtrSafe Function EmptyClipboard Lib "USER32" () As Long
    Private Declare PtrSafe Function lstrcpy Lib "kernel32" (ByVal lpString1 As Any, ByVal lpString2 As Any) As LongPtr
    Private Declare PtrSafe Function wstrlen Lib "kernel32" Alias "lstrlenW" (ByVal lpString As LongPtr) As Long
    Private Declare PtrSafe Function wstrcpy Lib "kernel32" Alias "lstrcpyW" (ByVal lpString1 As Any, ByVal lpString2 As Any) As LongPtr
    Private Declare PtrSafe Function GetClipboardData Lib "USER32" (ByVal wFormat As LongPtr) As LongPtr
    Private Declare PtrSafe Function SetClipboardData Lib "USER32" (ByVal wFormat As Long, ByVal hMem As LongPtr) As LongPtr
    Private Declare PtrSafe Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (destination As Any, source As Any, ByVal Length As LongPtr)
  #Else
    Private Declare Function IsClipboardFormatAvailable Lib "user32" (ByVal wFormat As Long) As Long
    Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (Destination As Any, Source As Any, ByVal Length As LongPtr)
    Private Declare Function GlobalUnlock Lib "kernel32" (ByVal hMem As Long) As Long
    Private Declare Function GlobalSize Lib "kernel32" (ByVal hMem As Long) As Long
    Private Declare Function GlobalLock Lib "kernel32" (ByVal hMem As Long) As Long
    Private Declare Function GlobalAlloc Lib "kernel32" (ByVal wFlags As Long, ByVal dwBytes As Long) As Long
    Private Declare Function CloseClipboard Lib "user32" () As Long
    Private Declare Function OpenClipboard Lib "user32" (ByVal hwnd As Long) As Long
    Private Declare Function EmptyClipboard Lib "user32" () As Long
    Private Declare Function wstrlen Lib "kernel32" Alias "lstrlenW" (ByVal lpString As LongPtr) As Long
    Private Declare Function wstrcpy Lib "kernel32" Alias "lstrcpyW" (ByVal lpString1 As Any, ByVal lpString2 As Any) As Long
    Private Declare Function lstrcpy Lib "kernel32" (ByVal lpString1 As Any, ByVal lpString2 As Any) As Long
Private Declare Function GetClipboardData Lib "user32" (ByVal wFormat As Long) As Long
    Private Declare Function SetClipboardData Lib "user32" (ByVal wFormat As Long, ByVal hMem As Long) As Long
  #End If
#End If
Public ClipboardStorage As String
'                                 ClipBoard
Sub PasteFromClipboard()
  SendKeys "^v", False
  AOT2 TimeSerial(0, 0, 1), "ClipboardReturnLast", True
Function PasteText(ByVal text As String)
  ' Dán vãn baÒn bãÌng phím tãìt Ctrl+V
  ClipboardSet text, True
Sub ClipboardReturnLast()
  ClipboardSet ClipboardStorage
  ClipboardStorage = Empty
Private Sub test()
  Dim s
  s = ClipboardText
  Debug.Print Len(s); """" & s & """"
Function ClipboardText() As String
  #If Mac Then
    With New MSForms.DataObject: .GetFromClipboard: ClipboardText = .GetText(1): End With
  #Else
    #If VBA7 Then
      Dim h1 As LongPtr, h2 As LongPtr, l&, s$
    #Else
      Dim h1&, h2&, l&, s$
    #End If
    If IsClipboardFormatAvailable(13) Then
      If OpenClipboard(0) Then
        h1 = GetClipboardData(13): h2 = GlobalLock(h1): l = wstrlen(h2)
        If l > 0 Then s = String$(l, vbNullChar):  wstrcpy StrPtr(s), h2
        GlobalUnlock (h1): CloseClipboard
        ClipboardText = s
  #End If
Public Function ClipboardSet(Optional ByVal text As String = vbNullChar, Optional backup As Boolean = False) As Boolean
  #If Mac Then
      If backup Then ClipboardStorage = Empty: .GetFromClipboard: ClipboardStorage = .GetText(1)
      .SetText text: .PutInClipboard:
  #Else
    #If VBA7 Then
      Dim h1 As LongPtr, h2 As LongPtr, h3 As LongPtr, x&, s$
    #Else
      Dim h1&, h2&, h3&, x&, s$
    #End If
    If OpenClipboard(0&) = 0 Then Exit Function
    If text = vbNullChar Then
      x = EmptyClipboard()
      If backup Then
        If IsClipboardFormatAvailable(13&) Then
          h1 = GetClipboardData(13&): h2 = GlobalLock(h1): x = wstrlen(h2)
          If x > 0 Then s = String$(x, vbNullChar):  wstrcpy StrPtr(s), h2
          GlobalUnlock h1
          ClipboardStorage = s
      h1 = GlobalAlloc(&H42, LenB(text) + 2)
      h3 = GlobalLock(h1)
      h3 = wstrcpy(h3, StrPtr(text))
      If GlobalUnlock(h1) <> 0 Then GoTo e
      h2 = SetClipboardData(13&, h1)
      ClipboardSet = True
e:
    If CloseClipboard() = 0 Then ClipboardSet = False
  #End If
