' The module modTrickUnregCOM.bas - for working with COM libraries without registration.
' © Krivous Anatolii Anatolevich (The trick), 2015
Public Type GUID
    data1       As Long
    data2       As Integer
    data3       As Integer
    data4(7)    As Byte
End Type
Private Declare Function CLSIDFromString Lib "ole32.dll" ( _
                         ByVal lpszCLSID As Long, _
                         ByRef clsid As GUID) As Long
Private Declare Function GetMem4 Lib "msvbvm60" ( _
                         ByRef src As Any, _
                         ByRef dst As Any) As Long
Private Declare Function SysFreeString Lib "oleaut32" ( _
                         ByVal lpbstr As Long) As Long
Private Declare Function LoadLibrary Lib "kernel32" _
                         Alias "LoadLibraryW" ( _
                         ByVal lpLibFileName As Long) As Long
Private Declare Function GetModuleHandle Lib "kernel32" _
                         Alias "GetModuleHandleW" ( _
                         ByVal lpModuleName As Long) As Long
Private Declare Function FreeLibrary Lib "kernel32" ( _
                         ByVal hLibModule As Long) As Long
Private Declare Function GetProcAddress Lib "kernel32" ( _
                         ByVal hModule As Long, _
                         ByVal lpProcName As String) As Long
Private Declare Function DispCallFunc Lib "oleaut32" ( _
                         ByVal pvInstance As Any, _
                         ByVal oVft As Long, _
                         ByVal cc As Integer, _
                         ByVal vtReturn As Integer, _
                         ByVal cActuals As Long, _
                         ByRef prgvt As Any, _
                         ByRef prgpvarg As Any, _
                         ByRef pvargResult As Variant) As Long
Private Declare Function LoadTypeLibEx Lib "oleaut32" ( _
                         ByVal szFile As Long, _
                         ByVal regkind As Long, _
                         ByRef pptlib As IUnknown) As Long
Private Declare Function memcpy Lib "kernel32" _
                         Alias "RtlMoveMemory" ( _
                         ByRef Destination As Any, _
                         ByRef Source As Any, _
                         ByVal Length As Long) As Long
Private Declare Function CreateStdDispatch Lib "oleaut32" ( _
                         ByVal punkOuter As IUnknown, _
                         ByVal pvThis As IUnknown, _
                         ByVal ptinfo As IUnknown, _
                         ByRef ppunkStdDisp As IUnknown) As Long
Private Const IID_IClassFactory   As String = "{00000001-0000-0000-C000-000000000046}"
Private Const IID_IUnknown        As String = "{00000000-0000-0000-C000-000000000046}"
Private Const CC_STDCALL          As Long = 4
Private Const REGKIND_NONE        As Long = 2
Private Const TKIND_COCLASS       As Long = 5
Private Const TKIND_DISPATCH      As Long = 4
Private Const TKIND_INTERFACE     As Long = 3
Dim iidClsFctr      As GUID
Dim iidUnk          As GUID
Dim isInit          As Boolean
' // Get all co-classes described in type library.
Public Function GetAllCoclasses( _
                ByRef path As String, _
                ByRef listOfClsid() As GUID, _
                ByRef listOfNames() As String, _
                ByRef countCoClass As Long) As Boolean
    Dim typeLib As IUnknown
    Dim typeInf As IUnknown
    Dim ret     As Long
    Dim count   As Long
    Dim index   As Long
    Dim pAttr   As Long
    Dim tKind   As Long
    ret = LoadTypeLibEx(StrPtr(path), REGKIND_NONE, typeLib)
    If ret Then
        Err.Raise ret
        Exit Function
    count = ITypeLib_GetTypeInfoCount(typeLib)
    countCoClass = 0
    If count > 0 Then
        ReDim listOfClsid(count - 1)
        ReDim listOfNames(count - 1)
        For index = 0 To count - 1
            ret = ITypeLib_GetTypeInfo(typeLib, index, typeInf)
            If ret Then
                Err.Raise ret
                Exit Function
            ITypeInfo_GetTypeAttr typeInf, pAttr
            GetMem4 ByVal pAttr + &H28, tKind
            If tKind = TKIND_COCLASS Then
                memcpy listOfClsid(countCoClass), ByVal pAttr, Len(listOfClsid(countCoClass))
                ret = ITypeInfo_GetDocumentation(typeInf, -1, listOfNames(countCoClass), vbNullString, 0, vbNullString)
                If ret Then
                    ITypeInfo_ReleaseTypeAttr typeInf, pAttr
                    Err.Raise ret
                    Exit Function
                countCoClass = countCoClass + 1
            Set typeInf = Nothing
    If countCoClass Then
        ReDim Preserve listOfClsid(countCoClass - 1)
        ReDim Preserve listOfNames(countCoClass - 1)
        Erase listOfClsid()
        Erase listOfNames()
    GetAllCoclasses = True
' // Create IDispach implementation described in type library.
Public Function CreateIDispatch( _
                ByRef obj As IUnknown, _
                ByRef typeLibPath As String, _
                ByRef interfaceName As String) As Object
    Dim ret     As Long
    Dim retObj  As IUnknown
    Dim pAttr   As Long
    Dim tKind   As Long
    ret = LoadTypeLibEx(StrPtr(typeLibPath), REGKIND_NONE, typeLib)
    If ret Then
        Err.Raise ret
        Exit Function
    ret = ITypeLib_FindName(typeLib, interfaceName, 0, typeInf, 0, 1)
    If typeInf Is Nothing Then
        Err.Raise &H80004002, , "Interface not found"
        Exit Function
    If tKind = TKIND_DISPATCH Then
        Set CreateIDispatch = obj
        Exit Function
    ElseIf tKind <> TKIND_INTERFACE Then
        Exit Function
    ret = CreateStdDispatch(Nothing, obj, typeInf, retObj)
    If ret Then
        Err.Raise ret
        Exit Function
    Set CreateIDispatch = retObj
' // Create object by Name.
Public Function CreateObjectEx2( _
                ByRef pathToDll As String, _
                ByRef pathToTLB As String, _
                ByRef className As String) As IUnknown
    Dim ret     As Long
    Dim pAttr   As Long
    Dim tKind   As Long
    Dim clsid   As GUID
    ret = LoadTypeLibEx(StrPtr(pathToTLB), REGKIND_NONE, typeLib)
    If ret Then
        Err.Raise ret
        Exit Function
    ret = ITypeLib_FindName(typeLib, className, 0, typeInf, 0, 1)
        Err.Raise &H80040111, , "Class not found in type library"
        Exit Function
        memcpy clsid, ByVal pAttr, Len(clsid)
        Exit Function
    Set CreateObjectEx2 = CreateObjectEx(pathToDll, clsid)
' // Create object by CLSID and path.
Public Function CreateObjectEx( _
                ByRef clsid As GUID) As IUnknown
    Dim hLib    As Long
    Dim lpAddr  As Long
    Dim isLoad  As Boolean
    hLib = GetModuleHandle(StrPtr(path))
    If hLib = 0 Then
        hLib = LoadLibrary(StrPtr(path))
        If hLib = 0 Then
            Err.Raise 53, , Error(53) & " " & Chr$(34) & path & Chr$(34)
            Exit Function
        isLoad = True
    lpAddr = GetProcAddress(hLib, "DllGetClassObject")
    If lpAddr = 0 Then
        If isLoad Then FreeLibrary hLib
        Err.Raise 453, , "Can't find dll entry point DllGetClasesObject in " & Chr$(34) & path & Chr$(34)
        Exit Function
    If Not isInit Then
        CLSIDFromString StrPtr(IID_IClassFactory), iidClsFctr
        CLSIDFromString StrPtr(IID_IUnknown), iidUnk
        isInit = True
    Dim ret     As Long
    Dim out     As IUnknown
    ret = DllGetClassObject(lpAddr, clsid, iidClsFctr, out)
    If ret = 0 Then
        ret = IClassFactory_CreateInstance(out, 0, iidUnk, CreateObjectEx)
        Err.Raise ret
        Exit Function
    Set out = Nothing
    If ret Then
        Err.Raise ret
' // Unload DLL if not used.
Public Function UnloadLibrary( _
                ByRef path As String) As Boolean
    Dim hLib    As Long
    Dim lpAddr  As Long
    Dim ret     As Long
    If Not isInit Then Exit Function
    If hLib = 0 Then Exit Function
    lpAddr = GetProcAddress(hLib, "DllCanUnloadNow")
    If lpAddr = 0 Then Exit Function
    ret = DllCanUnloadNow(lpAddr)
    If ret = 0 Then
        FreeLibrary hLib
        UnloadLibrary = True
' // Call "DllGetClassObject" function using a pointer.
Private Function DllGetClassObject( _
                 ByVal funcAddr As Long, _
                 ByRef clsid As GUID, _
                 ByRef iid As GUID, _
                 ByRef out As IUnknown) As Long
    Dim params(2)   As Variant
    Dim types(2)    As Integer
    Dim list(2)     As Long
    Dim resultCall  As Long
    Dim pIndex      As Long
    Dim pReturn     As Variant
    params(0) = VarPtr(clsid)
    params(1) = VarPtr(iid)
    params(2) = VarPtr(out)
    For pIndex = 0 To UBound(params)
        list(pIndex) = VarPtr(params(pIndex)):   types(pIndex) = VarType(params(pIndex))
    resultCall = DispCallFunc(0&, funcAddr, CC_STDCALL, vbLong, 3, types(0), list(0), pReturn)
    If resultCall Then Err.Raise 5: Exit Function
    DllGetClassObject = pReturn
' // Call "DllCanUnloadNow" function using a pointer.
Private Function DllCanUnloadNow( _
                 ByVal funcAddr As Long) As Long
    resultCall = DispCallFunc(0&, funcAddr, CC_STDCALL, vbLong, 0, ByVal 0&, ByVal 0&, pReturn)
    DllCanUnloadNow = pReturn
' // Call "IClassFactory:CreateInstance" method.
Private Function IClassFactory_CreateInstance( _
                 ByVal obj As IUnknown, _
                 ByVal punkOuter As Long, _
                 ByRef riid As GUID, _
    Dim list(2)     As Long
    Dim pIndex      As Long
    params(0) = punkOuter
    params(1) = VarPtr(riid)
    resultCall = DispCallFunc(obj, &HC, CC_STDCALL, vbLong, 3, types(0), list(0), pReturn)
    If resultCall Then Err.Raise resultCall: Exit Function
    IClassFactory_CreateInstance = pReturn
' // Call "ITypeLib:GetTypeInfoCount" method.
Private Function ITypeLib_GetTypeInfoCount( _
                 ByVal obj As IUnknown) As Long
    resultCall = DispCallFunc(obj, &HC, CC_STDCALL, vbLong, 0, ByVal 0&, ByVal 0&, pReturn)
    ITypeLib_GetTypeInfoCount = pReturn
' // Call "ITypeLib:GetTypeInfo" method.
Private Function ITypeLib_GetTypeInfo( _
                 ByVal index As Long, _
                 ByRef ppTInfo As IUnknown) As Long
    Dim params(1)   As Variant
    Dim types(1)    As Integer
    Dim list(1)     As Long
    Dim pIndex      As Long
    params(0) = index
    params(1) = VarPtr(ppTInfo)
    resultCall = DispCallFunc(obj, &H10, CC_STDCALL, vbLong, 2, types(0), list(0), pReturn)
    ITypeLib_GetTypeInfo = pReturn
' // Call "ITypeLib:FindName" method.
Private Function ITypeLib_FindName( _
                 ByRef szNameBuf As String, _
                 ByVal lHashVal As Long, _
                 ByRef ppTInfo As IUnknown, _
                 ByRef rgMemId As Long, _
                 ByRef pcFound As Integer) As Long
    Dim params(4)   As Variant
    Dim types(4)    As Integer
    Dim list(4)     As Long
    Dim pIndex      As Long
    params(0) = StrPtr(szNameBuf)
    params(1) = lHashVal
    params(2) = VarPtr(ppTInfo)
    params(3) = VarPtr(rgMemId)
    params(4) = VarPtr(pcFound)
    resultCall = DispCallFunc(obj, &H2C, CC_STDCALL, vbLong, 5, types(0), list(0), pReturn)
    ITypeLib_FindName = pReturn
' // Call "ITypeInfo:GetTypeAttr" method.
Private Sub ITypeInfo_GetTypeAttr( _
            ByRef ppTypeAttr As Long)
    pReturn = VarPtr(ppTypeAttr)
    resultCall = DispCallFunc(obj, &HC, CC_STDCALL, vbEmpty, 1, vbLong, VarPtr(pReturn), 0)
    If resultCall Then Err.Raise resultCall: Exit Sub
' // Call "ITypeInfo:GetDocumentation" method.
Private Function ITypeInfo_GetDocumentation( _
                 ByVal memid As Long, _
                 ByRef pBstrName As String, _
                 ByRef pBstrDocString As String, _
                 ByRef pdwHelpContext As Long, _
                 ByRef pBstrHelpFile As String) As Long
    Dim list(4)     As Long
    Dim pIndex      As Long
    params(0) = memid
    params(1) = VarPtr(pBstrName)
    params(2) = VarPtr(pBstrDocString)
    params(3) = VarPtr(pdwHelpContext)
    params(4) = VarPtr(pBstrHelpFile)
    resultCall = DispCallFunc(obj, &H30, CC_STDCALL, vbLong, 5, types(0), list(0), pReturn)
    ITypeInfo_GetDocumentation = pReturn
' // Call "ITypeInfo:ReleaseTypeAttr" method.
Private Sub ITypeInfo_ReleaseTypeAttr( _
            ByVal ppTypeAttr As Long)
    resultCall = DispCallFunc(obj, &H4C, CC_STDCALL, vbEmpty, 1, vbLong, VarPtr(CVar(ppTypeAttr)), 0)
