duongvanminh33
- Điểm
- 103
- Tuổi
- 30
Sub Button7_Click()
Dim OutApp As Object
Dim OutMail As Object
Dim printFrom As Variant, printTo As Variant
Dim sFile As String
Dim sPath As String
Dim i As Long
printFrom = Sheets("Sheet3").Range("I8")
printTo = Sheets("Sheet3").Range("I9")
Set OutApp = CreateObject("Outlook.Application")
For i = printFrom To printTo
Sheets("Sheet3").Range("I5") = i
ThisWorkbook.Sheets("Sheet3").Range("A133").Select
Range("A133").Copy
Workbooks.Add(xlWBATWorksheet).Sheets("Sheet1").Select
ActiveWorkbook.ActiveSheet.PasteSpecial
Columns("A").AutoFit
ActiveSheet.UsedRange.Value = ActiveSheet.UsedRange.Value 'HAM NAY CHI DC DUNG TRONG RANGE
sFile = ActiveWorkbook.Path & "\" & "Payslip Oct 2020 - " & Sheets("Sheet3").Range("B11") & ".xlsx"
ActiveWorkbook.SaveAs Filename:=sFile, FileFormat:=51, WriteResPassword:="", ReadOnlyRecommended:=True _
, CreateBackup:=False
Workbooks.Add.Close Savechanges:=False
ActiveWorkbook.Close False
Set OutMail = OutApp.CreateItem(0)
With OutMail
.To = Sheets("Sheet3").Range("B12")
.cc = ""
.BCC = ""
.Subject = Sheets("Sheet3").Range("B9")
.HTMLBody = " Dear " & Sheets("Sheet3").Range("B11") & "</B> <BR><BR> Kindly find attachment payslip of October 2020. <BR>" & _
"<BR>Should you have any questions, do not hestitate to contact us." & _
"<BR><BR>Thanks & regards</B><BR>" & _
"</B>"
.Attachments.Add (sFile)
.Send
Set OutMail = Nothing
Set OutApp = Nothing
MsgBox "Success"
Mình lại dính lỗi nãy, mình có xem xét lại từ đầu đến cuối mà vẫn báo lỗi sFile = ActiveWorkbook.Path & "\" & "Payslip Oct 2020 - " & Sheets("Sheet3").Range("B11") & ".xlsx"
Mấy anh giúp em với ạ, em không hiểu sai chổ nào cả.
Dim sFile As String
Dim sPath As String
Dim i As Long
Range("A133").Copy
With OutMail
.cc = ""
.BCC = ""
"</B>"
.Send
MsgBox "Success"
