sai_hikaru5555
Sub TachNhom()
Dim myCell As Range
Dim wks As Worksheet
Dim DataBaseWks As Worksheet
Dim ListRange As Range
Dim dummyRng As Range
Dim myDatabase As Range
Dim TempWks As Worksheet
Dim rsp As Integer
Dim i As Long
‘chinh dau tieu de
Const TopLeftCellOfDataBase As String = "A1"
‘chinh cot lay du lieu
Const KeyColumn As String = "A"
Set DataBaseWks = Worksheets("DATA")
i = DataBaseWks.Range(TopLeftCellOfDataBase).Row - 1
Set TempWks = Worksheets.Add
With DataBaseWks
Set dummyRng = .UsedRange
Set myDatabase = .Range(TopLeftCellOfDataBase, _
.Cells.SpecialCells(xlCellTypeLastCell))
With DataBaseWks
Intersect(myDatabase, .Columns(KeyColumn)).AdvancedFilter _
Action:=xlFilterCopy, _
CopyToRange:=TempWks.Range("A1"), _
Unique:=True
TempWks.Range("D1").Value = _
.Cells(.Range(TopLeftCellOfDataBase).Row, KeyColumn).Value
With TempWks
Set ListRange = .Range("A2", .Cells(.Rows.Count, "A").End(xlUp))
With ListRange
.Sort Key1:=.Cells(1), Order1:=xlAscending, _
Header:=xlNo, OrderCustom:=1, _
MatchCase:=False, Orientation:=xlTopToBottom
For Each myCell In ListRange.Cells
If WksExists(myCell.Value) = False Then
Set wks = Sheets.Add
wks.Name = myCell.Value
If Err.Number <> 0 Then
MsgBox "Please rename: " & wks.Name
Err.Clear
On Error GoTo 0
wks.Move After:=Sheets(Sheets.Count)
Set wks = Worksheets(myCell.Value)
wks.Cells.Clear
If rsp = 6 Then
DataBaseWks.Rows("1:" & i).Copy Destination:=wks.Range("A1")
TempWks.Range("D2").Value = "=" & Chr(34) & "=" & myCell.Value & Chr(34)
If rsp = 6 Then
myDatabase.AdvancedFilter _
CriteriaRange:=TempWks.Range("D1:D2"), _
CopyToRange:=wks.Range("A1").Offset(i, 0), _
Unique:=False
CopyToRange:=wks.Range("A1"), _
Unique:=False
Columns("D:D").ColumnWidth = 20
Columns("F:F").ColumnWidth = 20
Columns("G:G").ColumnWidth = 15
Next myCell
'Sub tachsheet()
Dim sh As Worksheet
For Each sh In Worksheets
sh.Copy
ActiveWorkbook.SaveAs ThisWorkbook.Path & "\" & sh.Name, 51
ActiveWorkbook.Close
'Application.ScreenUpdating = True
'Application.DisplayAlerts = True
'End Sub
TempWks.Delete
MsgBox "TÁCH PL THANH CONG"
Function WksExists(wksName As String) As Boolean
WksExists = CBool(Len(Worksheets(wksName).Name) > 0)
