Xin mọi người giúp rút gọn CODE !!!!!! (1 người xem)
hoduytrieuvy
Hiện tại mình có 1 code này, do mình không rành về VBA lắm. Nên đã sử dụng MACROS.
Giờ thấy nó dài quá nên cần mọi người rút gọn CODE lại.
Cám Ơn mọi người.
Sub LECHKHO_01()
' LECHKHO_01 Macro
Range("AU7").Select
Selection.ClearContents
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-44],'[1.xls]01'!R7C3:R900C21,19,0)"
Range("AU7").Select
Selection.AutoFill Destination:=Range("AU7:AU841")
Range("AU7:AU841").Select
Range("AW7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-46],'[1.xls]01'!R7C3:R900C22,20,0)"
Range("AW7").Select
Selection.AutoFill Destination:=Range("AW7:AW841")
Range("AW7:AW841").Select
Range("AY7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-48],'[1.xls]01'!R7C3:R900C23,21,0)"
Range("AY7").Select
Selection.AutoFill Destination:=Range("AY7:AY841")
Range("AY7:AY841").Select
Range("BA7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-50],'[1.xls]01'!R7C3:R900C24,22,0)"
Range("BA7").Select
Selection.AutoFill Destination:=Range("BA7:BA841")
Range("BA7:BA841").Select
Range("BC7").Select
Range("BC7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-52],'[1.xls]01'!R7C3:R900C25,23,0)"
Range("BC7").Select
Selection.AutoFill Destination:=Range("BC7:BC841")
Range("BC7:BC841").Select
Range("BE7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-54],'[1.xls]01'!R7C3:R900C26,24,0)"
Range("BE7").Select
Selection.AutoFill Destination:=Range("BE7:BE841")
Range("BE7:BE841").Select
Range("BG7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-56],'[1.xls]01'!R7C3:R900C27,25,0)"
Range("BG7").Select
Selection.AutoFill Destination:=Range("BG7:BG841")
Range("BG7:BG841").Select
Range("BI7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-58],'[1.xls]01'!R7C3:R900C28,26,0)"
Range("BI7").Select
Selection.AutoFill Destination:=Range("BI7:BI841")
Range("BI7:BI841").Select
Range("BK7").Select
Range("BK7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-60],'[1.xls]01'!R7C3:R900C29,27,0)"
Range("BK7").Select
Selection.AutoFill Destination:=Range("BK7:BK841")
Range("BK7:BK841").Select
Range("BM7").Select
Range("BM7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-62],'[1.xls]01'!R7C3:R900C30,28,0)"
Range("BM7").Select
Selection.AutoFill Destination:=Range("BM7:BM841")
Range("BM7:BM841").Select
Range("BO7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-64],'[1.xls]01'!R7C3:R900C31,29,0)"
Range("BO7").Select
Selection.AutoFill Destination:=Range("BO7:BO841")
Range("BO7:BO841").Select
Range("BQ7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-66],'[1.xls]01'!R7C3:R900C32,30,0)"
Range("BQ7").Select
Selection.AutoFill Destination:=Range("BQ7:BQ841")
Range("BQ7:BQ841").Select
Range("BS7").Select
Range("BS7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-68],'[1.xls]01'!R7C3:R900C33,31,0)"
Range("BS7").Select
Selection.AutoFill Destination:=Range("BS7:BS841")
Range("BS7:BS841").Select
Range("BU7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-70],'[1.xls]01'!R7C3:R900C34,32,0)"
Range("BU7").Select
Selection.AutoFill Destination:=Range("BU7:BU841")
Range("BU7:BU841").Select
Range("BW7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-72],'[1.xls]01'!R7C3:R900C35,33,0)"
Range("BW7").Select
Selection.AutoFill Destination:=Range("BW7:BW841")
Range("BW7:BW841").Select
Range("BY7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-74],'[1.xls]01'!R7C3:R900C36,34,0)"
Range("BY7").Select
Selection.AutoFill Destination:=Range("BY7:BY841")
Range("BY7:BY841").Select
Range("CA7").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-76],'[1.xls]01'!R7C3:R900C38,36,0)"
Range("CA7").Select
Selection.AutoFill Destination:=Range("CA7:CA841")
Range("CA7:CA841").Select
Range("CA7").Select
Cám Ơn mọi người.
Sub LECHKHO_01()
' LECHKHO_01 Macro
Range("AU7").Select
Range("AU7").Select
Range("AW7").Select
Range("AW7").Select
Range("AY7").Select
Range("AY7").Select
Range("BA7").Select
Range("BA7").Select
Range("BC7").Select
Range("BC7").Select
Range("BC7").Select
Range("BE7").Select
Range("BE7").Select
Range("BG7").Select
Range("BG7").Select
Range("BI7").Select
Range("BI7").Select
Range("BK7").Select
Range("BK7").Select
Range("BK7").Select
Range("BM7").Select
Range("BM7").Select
Range("BM7").Select
Range("BO7").Select
Range("BO7").Select
Range("BQ7").Select
Range("BQ7").Select
Range("BS7").Select
Range("BS7").Select
Range("BS7").Select
Range("BU7").Select
Range("BU7").Select
Range("BW7").Select
Range("BW7").Select
Range("BY7").Select
Range("BY7").Select
Range("CA7").Select
Range("CA7").Select
Range("CA7").Select
Tốt nhất bạn cho file lên và đưa ra kết quả cần đạt được viết code còn nhanh hơn.:D.
Bạn thử code sau. Tôi khuyên bạn đã dùng code thì không cần dùng VLockup ghi vào bảng tính nữa
Sub test()
  Dim i&, j&, k&, m&: k = 19: m = 44
  Dim AUCol&, CACol&: AUCol = Range("AU1").Column: CACol = Range("CA1").Column - 1
  For j = AUCol  To CACol
    For i = 7 To 841
      If j = CACol Then k = k + 1
      Cells(i, AUCol + k - 19).FormulaR1C1 = _
      "=VLOOKUP(RC[-" & m & "],'[1.xls]01'!R7C3:R900C" & k + 2 & "," & k & ",0)"
  Next : k = k + 1: m = m + 2: Next j
FILE của công ty, e ko dám đưa lên bạn ơi. hix
Sub test()
    For i = 7 To 841
không chạy được bạn ơi, đứng hình luôn.
Nhìn kĩ lại code của bạn. Tôi thấy các cột cách nhau một đơn vị. Cột cuối đột biến tăng 1 đơn vị
Bạn thử lại
Sub test()
  For j = AUCol To CACol Step 2
    For i = 7 To 841
      If i = 7 Then
          Cells(i, AUCol + m - 44).Formula = _
          Cells(i, AUCol + m - 44).Formula = Cells(7, AUCol + m - 44).FormulaR1C1
  Next i: k = k + 1: m = m + 2: Next j
Bạn thử lại
Sub test()
    For i = 7 To 841
      If i = 7 Then
          Cells(i, AUCol + k - 19).Formula = _
          Cells(i, AUCol + k - 19).Formula = Cells(7, AUCol + k - 19).FormulaR1C1
Đúng rồi bạn. Do cột đó không cần dò lệch. Nên mình bỏ qua. bạn cứ việc chạy cách nhau 1 đơn vị cũng dc, mình sẽ thêm cột đó vào nữa.
Hên xui:
Sub RutGonLechKho()
 Const GPE As Integer = 841
 Dim Cot As Byte, Tmp As Integer, Col As Integer
 For Cot = 47 To 80 Step 2
    With Cells(7, Cot)
        .ClearContents
        Tmp = (Cot + 1) \ 2 - 5:                    Col = Cot - 3
        .FormulaR1C1 = "=VLOOKUP(RC[-" & Col & "],'[1.xls]01'!R7C3:R900C21," & Tmp & ",0)"            '19'
        .Select
        Selection.AutoFill Destination:=Cells(7, Cot).Resize(GPE)
 Next Cot
Hên xui:
Sub RutGonLechKho()
    With Cells(7, Cot)
        .ClearContents
        .Select
Next Cot
cột đầu tiên chạy đúng. VLOOKUP(C7,'[1.xls]01'!$C$7:$U$900,19,0)
cột thứ 2 sai: VLOOKUP(C7,'[1.xls]01'!$C$7:$U$900,20,0) ( sai chỗ chữ U )
bác tăng lên 1 cột dùm e.
nếu đúng là cột 2 như thế này: VLOOKUP(C7,'[1.xls]01'!$C$7:$V$900,20,0)
Bạn xem code nhé.
Sub lechhang()
   Dim arr, arr1, lr As Long, i As Long, j As Integer, dic As Object, ten As String, wb As Workbook, b As Long, lr1 As Long
   ten = ThisWorkbook.Path & "\test2.xlsx"
   With Sheets("sheet1")
   lr = .Range("A" & Rows.Count).End(xlUp).Row
      If lr < 2 Then Exit Sub
   arr = .Range("A2:S" & lr).Value
   .Range("j2:s" & lr).ClearContents
   For i = 1 To UBound(arr, 1)
      If Not dic.exists(arr(i, 1)) Then
         dic.Add arr(i, 1), i
   Set wb = Workbooks.Open(ten)
   lr1 = wb.Sheets(1).Range("A" & Rows.Count).End(xlUp).Row
   If lr1 < 2 Then Exit Sub: wb.Close False
      arr1 = wb.Sheets(1).Range("A2:I" & lr1).Value
      wb.Close False
      For i = 1 To UBound(arr1, 1)
          b = dic.Item(arr1(i, 1))
          If b Then
             arr(b, 10) = arr1(i, 5)
             arr(b, 11) = arr(b, 5) - arr(b, 10)
             arr(b, 12) = arr1(i, 6)
             arr(b, 13) = arr(b, 6) - arr(b, 12)
             arr(b, 14) = arr1(i, 7)
             arr(b, 15) = arr(b, 7) - arr(b, 14)
             arr(b, 16) = arr1(i, 8)
             arr(b, 17) = arr(b, 8) - arr(b, 16)
             arr(b, 18) = arr1(i, 9)
             arr(b, 19) = arr(b, 9) - arr(b, 18)
          .Range("A2:S" & lr).Value = arr
Tạo công thức tất cả các cột
Sub AddVlookup()
Dim sRow As Long, eCol As Long, j As Long
eCol = Range("AAA1").End(xlToLeft).Column
sRow = Range("A1000000").End(xlUp).Row - 1
For j = 10 To eCol Step 2
  Cells(2, j).Resize(sRow).FormulaR1C1 = "=VLOOKUP(RC2,[test2.xlsx]Sheet1!R2C2:R6C9," & j / 2 - 1 & ",0)"
  Cells(2, j + 1).Resize(sRow).FormulaR1C1 = "=RC[-1]-RC[" & -1 - j / 2 & "]"
Sub AddVlookup()
check inbox giúp e ạ.
Sub RutGonLechKho()
    With Cells(7, Cot)
        .ClearContents
        .FormulaR1C1 = "=VLOOKUP(RC[-" & Col & "],'[1.xls]01'!R7C3:R900C" & Tmp + 2 & "," & Tmp & ",0)"            '19=> 21'
        .Select
 Next Cot
Sub RutGonLechKho()
    With Cells(7, Cot)
        .ClearContents
        .Select
Next Cot
Ngon bác ơi. chạy ok rồi.
Cái này là một range cố định. Người ta đặt vào một name rồi cứ từ ấy mà dùng.
(tôi chỉ nói về quy luật Vlookup trong Excel)
