Sub CopyTextSangExcel()
Dim ChuT As AcadEntity
Dim asset As AcadSelectionSet
Dim Diembao1P As Variant, Diembao2P As Variant
Dim i As Integer
'Bo qua loi neu asset khong ton tai
With ActiveDocument.SelectionSets
.Item("asset").Delete
'Tao doi tuong asset
Set asset = .Add("asset")
'Chon toan bo doi tuong trong cua so chon vao asset
With ActiveDocument.Utility
Diembao1P = .GetPoint(, vbLf & "Chon diem bao o phia tren, ben trai:")
Diembao2P = .GetPoint(, vbLf & "Chon diem bao o phia duoi, ben phai:")
asset.Select acSelectionSetWindow, Diembao1P, Diembao2P
asset.Highlight True
i = 0
'Duyet qua tung doi tuong trong asset
For Each ChuT In asset
'Chi chon doi tuong la Text
If ChuT.ObjectName = "AcDbText" Then
i = i + 1
ChuT.Highlight False
MsgBox "Gia tri cua doi tuong thu " & i & ": " & ChuT.TextString
MsgBox "Vung chon co " & i & " doi tuong."
asset.Highlight False
Set asset = Nothing
Set ChuT = Nothing
(defun c:c2e ( / hangdau)
(defun sosanh (e1 e2 / p1 p2)
(setq p1 (car e1)
p2 (car e2)
(if (equal (cadr p1) (cadr p2) fuzz)
(< (car p1) (car p2))
(> (cadr p1) (cadr p2))
(setq
ss (ssget '((0 . "TEXT")))
lst (ss2ent ss)
lst (mapcar '(lambda (e) (cons (cdr (assoc 10 (entget e))) (cdr (assoc 1 (entget e))))) lst)
caotext (cdr (assoc 40 (entget (ssname ss 0))))
fuzz (* caotext 1.0)
lst (vl-sort lst 'sosanh)
index 1
oldy nil
fn (getfiled "Chon file de save" "" "csv" 1)
fid (open fn "w")
(foreach e lst
(if (equal oldy (cadr (car e)) fuzz)
(progn
(princ "," fid)
(setq index (1+ index))
(progn
(if hangdau
(progn
(setq index 1)
(princ "\n" fid)
(setq hangdau t)
(princ (cdr e) fid)
(setq oldy (cadr (car e)))
(close fid)
(defun ss2ent (ss / sodt index lstent)
(setq
sodt (if ss
(sslength ss)
index 0
(repeat sodt
(setq ent (ssname ss index)
index (1+ index)
lstent (cons ent lstent)
(reverse lstent)
Nhưng để lồng vào một chương trình khác thì hơi khó.Bạn dùng lệnh Dataextraction trong Cad2008 la co the lay duoc so lieu tu Cad sang Excel. Ban chon toan bo Text ban muon lay, sau mot hoi Next ban chi can chon Text và Geometry. Tiep tuc next va chi chon Value va Position X, hoặc Position Y. Lai tiếp tục Next và Next. Số liệu đó được xuất ra file Excel nằm trong My Document, ban mở file do ra và sắp xếp theo giá trị tăng hoặc giảm dần của X, Y là xong.
Bạn làm thử đi, quen rồi thấy rất tiện và chính xác.
Đúng là có thể lấy được như vậy nhưng việc xuất số liệu sang excel kết quả chỉ cho vào một cột là value, trong khi nếu trong cad một bảng có nhiều hàng và cột thì hic...hic, xuất các giá trị vào excel lại lung tung. Ví dụ, trong cad tôi có bảng làBạn dùng lệnh Dataextraction trong Cad2008 la co the lay duoc so lieu tu Cad sang Excel. Ban chon toan bo Text ban muon lay, sau mot hoi Next ban chi can chon Text và Geometry. Tiep tuc next va chi chon Value va Position X, hoặc Position Y. Lai tiếp tục Next và Next. Số liệu đó được xuất ra file Excel nằm trong My Document, ban mở file do ra và sắp xếp theo giá trị tăng hoặc giảm dần của X, Y là xong.
Bó tay thật đấy, chưa nghe cái kiểu chuyển dữ liệu từ cad sang excel bao giờ, mà chỉ có kiểu hình ảnh thôi, nếu cao thủ nào giúp và post cho anh em tham khảo thì công việc giảm đi rất nhiều, nhất là những bảng thống kê dữ liệu từ cad mà ta ko phải nhập lại cho đỡ mệt và tránh được khỏi nhầm lẫn
Em muốn lấy dữ liệu chữ trong Autocad (đã được lập thành bảng) qua excel để tính toán.
cao thủ nào tinh thông thì chỉ giáo giùm em cái chứ cop từng dòng thì chết em mà lại không chính xác.
Gửi bác HNP
Sao em download cái lisp của bác về mà dùng không được vậy, có phải lệnh của nó là b2e không. khi em chon hai điểm xong thi nó cũng mở ra bảng excell nhưng trong đó khôg có gì cả. (bảng thống kê thép ở cad em muốn chuyển qua excell mà). Mong bác chỉ giáo thêm cách sử dụng. em dùng cad 2007, excell 2003.
Cảm ơn bác!
em thấy cad2file khi mình chọn nhiều nó thường không chạy và lại khi chọn Mtext thì thấy giá trị nó nhảy loạn lên.Bạn lên mạng tìm kiếm chương trình Cad2file nhé. Đó là một Add-Ins viết cho CAD. Sau khi nạp vào CAD, bạn chạy chương trình, sẽ có nhiều lựa chọn của các đối tượng CAD để bạn truy xuất sang Excel dưới dạng file CSV. Vấn đề là bạn phải viết 1 đoạn code để lọc lại dữ liệu đó, lấy ra các dữ liệu bạn muốn. Mình đã thử với các file tính thép, Cad2file lấy ra được các thông số mình cần như số hiệu thép, số thanh, chiều dài thanh, khối lượng đơn vị. Sau đó căn cứ vào cấu trúc dữ liệu để viết đoạn code phù hợp, lấy ra các số liệu cần thiết và sắp xếp theo 1 bảng tính chuẩn.
Lâu rồi mới vào mạng. Hôm nay đọc bài của bạn mình thấy có 2 loại dữ liệu mà bạn yêu cầu. Nếu dữ liệu được lập từ phần mềm Topo, NOva do máy tạo nên thì không khó gì. Ở phần tiện ích sẽ trích suất sang được excell. Nếu là dữ liệu nhập bằng tay thì hơi khó đấy.Em muốn lấy dữ liệu chữ trong Autocad (đã được lập thành bảng) qua excel để tính toán.
