Anh cải tiến cái này cho chạy nhanh hơn xem thế nào:
Sub Tinh()
Dim i1 As Integer, i2 As Integer, i3 As Integer, i4 As Integer, i5 As Integer, i6 As Integer, i7 As Integer, i8 As Integer, i9 As Integer, i10 As Integer
For i1 = 1 To 10
    For i2 = i1 + 1 To 10
        For i3 = i2 + 1 To 10
            For i4 = i3 + 1 To 10
                For i5 = i4 + 1 To 10
                    For i6 = i5 + 1 To 10
                        For i7 = i6 + 1 To 10
                            For i8 = i7 + 1 To 10
                                For i9 = i8 + 1 To 10
                                    For i10 = i9 + 1 To 10
                                    If Range("B" & i1) + Range("B" & i2) + Range("B" & i3) + Range("B" & i4) + Range("B" & i5) + Range("B" & i6) + Range("B" & i7) + Range("B" & i8) + Range("B" & i9) + Range("B" & i10) = Range("A1") Then
                                    MsgBox 10
                                    Cells(7, Sheet1.Range("B7").End(xlToRight).Column + 1) = Range("B" & i1)
                                    Cells(8, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i2)
                                    Cells(9, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i3)
                                    Cells(10, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i4)
                                    Cells(11, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i5)
                                    Cells(12, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i6)
                                    Cells(13, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i7)
                                    Cells(14, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i8)
                                    Cells(15, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i9)
                                    Cells(16, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i10)
                                If Range("B" & i1) + Range("B" & i2) + Range("B" & i3) + Range("B" & i4) + Range("B" & i5) + Range("B" & i6) + Range("B" & i7) + Range("B" & i8) + Range("B" & i9) = Range("A1") Then
                            If Range("B" & i1) + Range("B" & i2) + Range("B" & i3) + Range("B" & i4) + Range("B" & i5) + Range("B" & i6) + Range("B" & i7) + Range("B" & i8) = Range("A1") Then
                        If Range("B" & i1) + Range("B" & i2) + Range("B" & i3) + Range("B" & i4) + Range("B" & i5) + Range("B" & i6) + Range("B" & i7) = Range("A1") Then
                    If Range("B" & i1) + Range("B" & i2) + Range("B" & i3) + Range("B" & i4) + Range("B" & i5) + Range("B" & i6) = Range("A1") Then
                If Range("B" & i1) + Range("B" & i2) + Range("B" & i3) + Range("B" & i4) + Range("B" & i5) = Range("A1") Then
                    MsgBox i1 & Chr(13) & i2 & Chr(13) & i3 & Chr(13) & i4 & Chr(13) & i5 & Chr(13) & i6 & Chr(13) & i7 & Chr(13) & i8 & Chr(13) & i9 & Chr(13) & i10
            If Range("B" & i1) + Range("B" & i2) + Range("B" & i3) + Range("B" & i4) = Range("A1") Then
        If Range("B" & i1) + Range("B" & i2) + Range("B" & i3 + 1) = Range("A1") Then
            Cells(7, Sheet1.Range("B7").End(xlToRight).Column) = Range("B" & i1)
     If Range("B" & i1) + Range("B" & i2) = Range("A1") Then
If Range("B" & i1) = Range("A1") Then
        MsgBox 1
