hathanh349
'Kiem tra tiet trung cua GV
Sub KiemTraTrung()
Dim rng As Range
Dim cell As Range
Dim dict As Object
Dim a As Integer
Dim textAfterDash As String
Dim key As String
Dim duplicateCount As Integer
' Tang t?c macro
' Xóa d?nh d?ng màu n?n cu
ActiveSheet.Cells.Interior.ColorIndex = xlNone
' Kh?i t?o b? d?m s? lu?ng trùng
duplicateCount = 0
' Duy?t qua t?ng hàng t? 4 d?n 58
For a = 4 To 58
Set rng = ActiveSheet.Range(Cells(a, 2), Cells(a, 19))
' Ki?m tra ph?m vi có t?n t?i
If rng Is Nothing Then Exit Sub
' T?o Dictionary d? luu tr? giá tr?
Set dict = CreateObject("Scripting.Dictionary")
' Duy?t qua t?ng ô và thêm vào Dictionary
For Each cell In rng
If InStr(cell.value, "-") > 0 Then
textAfterDash = Trim(Mid(cell.value, InStr(cell.value, "-") + 1))
key = textAfterDash
' Ki?m tra trùng l?p trong Dictionary
If key <> "" Then
If dict.Exists(key) Then
If dict(key).Interior.Color <> RGB(255, 0, 0) Then
dict(key).Interior.Color = RGB(255, 0, 0) ' Bôi d? ô trùng l?p d?u tiên
duplicateCount = duplicateCount + 1 ' Tang s? lu?ng trùng
cell.Interior.Color = RGB(255, 0, 0) ' Bôi d? ô hi?n t?i
dict.Add key, cell
Next cell
Next a
' Khôi ph?c cài d?t Excel
MsgBox "Tông so luong ô trùng là: " & duplicateCount, vbInformation
'----------- Tìm theo Giáo viên ----------------
Sub TimTheoGiaoVien()
Dim ws As Worksheet
Set ws = ActiveSheet
Application.ScreenUpdating = False ' T?t c?p nh?t màn hình d? tang t?c
' Tìm dòng cu?i cùng trong c?t B
Dim lastRow As Integer
lastRow = ws.Cells(ws.Rows.Count, "B").End(xlUp).row
' Luu d? li?u vào m?ng d? tang t?c
Dim tkbChung As Variant, tenLop As Variant
tkbChung = ws.Range("C4:S" & lastRow).value
tenLop = ws.Range("C3:S3").value
Dim rowCount As Integer, colCount As Integer
rowCount = UBound(tkbChung, 1)
colCount = UBound(tkbChung, 2)
' Khai báo m?ng k?t qu?
Dim resultArr() As String
ReDim resultArr(1 To 61, 1 To 1)
Dim dict As Object
Dim i As Integer, j As Integer, k As Integer
Dim splitData As Variant, teacherName As String, subjectInfo As String, className As String
k = 0 ' Ch? s? c?t trong m?ng k?t qu?
' Duy?t qua t?ng c?t d? tách thông tin giáo viên
For j = 1 To colCount
className = Split(tenLop(1, j), "(")(0) ' L?y tên l?p
For i = 1 To rowCount
If InStr(tkbChung(i, j), "-") > 0 And tkbChung(i, j) <> "" Then
splitData = Split(tkbChung(i, j), "-")
teacherName = Trim(splitData(1))
subjectInfo = Trim(splitData(0)) & "- " & className
' Ki?m tra xem giáo viên dã có trong t? di?n chua
If Not dict.Exists(teacherName) Then
dict(teacherName) = k
' M? r?ng m?ng k?t qu? n?u c?n
If UBound(resultArr, 2) < k Then ReDim Preserve resultArr(1 To 61, 1 To k)
resultArr(1, k) = teacherName ' Luu tên giáo viên vào hàng d?u tiên
' Gán thông tin vào m?ng k?t qu?
resultArr(i + 1, dict(teacherName)) = subjectInfo
' Kiem tra ô T1 có giá tri không
Dim teacherSearch As String
teacherSearch = ws.Range("T1").value
If teacherSearch <> "" Then
Dim lastCol As Integer
lastCol = ws.Cells(4, ws.Columns.Count).End(xlToLeft).Column
' Ði?n d? li?u vào c?t T d?a trên tìm ki?m
For i = 4 To lastRow
ws.Range("T" & i).value = WorksheetFunction.HLookup(teacherSearch, resultArr, i - 2, False)
With ws.Range("T" & i)
.WrapText = False
.Font.Size = 8
.Borders.LineStyle = xlContinuous
MsgBox "Vui lòng chon Giáo viên!", vbExclamation
Application.ScreenUpdating = True ' B?t l?i c?p nh?t màn hình
'---- So sanh TKB hien tai voi TKB duoc chon ----------
Sub SoSanhTKB()
Dim ws1 As Worksheet
Dim ws2 As Worksheet
Dim cell1 As Range
Dim cell2 As Range
Dim r1 As Range
Dim cellAddress As String
Dim sheetName As String
' Prompt the user to select a sheet
sheetName = InputBox("Please enter the name of the sheet to extract data from:", "Select Sheet")
' Check if the sheet exists
Set ws2 = ThisWorkbook.Sheets(sheetName)
On Error GoTo 0
' Thi?t l?p sheet dang active và Sheet2
Set ws1 = ActiveSheet
' Vùng c?n so sánh (C4:S34) trong sheet dang active
Set r1 = ws1.Range("C4:S34")
' L?p qua t?t c? các ô trong vùng r1 c?a sheet dang active
For Each cell1 In r1
' L?y d?a ch? ô tuong ?ng trong Sheet2
cellAddress = cell1.Address
Set cell2 = ws2.Range(cellAddress)
' So sánh giá tr? gi?a hai ô
If cell1.value <> cell2.value Then
' N?u khác nhau, tô màu ô trong sheet dang active
cell1.Font.Color = RGB(255, 0, 0) ' Màu d?
Next cell1
MsgBox "OK"
Em tự mò học, làm nhưng sao file chạy nặng, hay bị đơ và tự thoát. AC góp ý giúp ah, em cảm ơn
Sub KiemTraTrung()
Dim rng As Range
Dim cell As Range
Dim dict As Object
Dim a As Integer
Dim key As String
' Tang t?c macro
duplicateCount = 0
For a = 4 To 58
key = textAfterDash
If key <> "" Then
dict.Add key, cell
Next cell
Next a
Dim ws As Worksheet
Dim dict As Object
.WrapText = False
.Font.Size = 8
Sub SoSanhTKB()
Dim cell1 As Range
Dim cell2 As Range
Dim r1 As Range
On Error GoTo 0
Next cell1
MsgBox "OK"
