Sub xyz()
  Dim arr(), res(), a, C, b, bT
  Dim sRow&, i&, r&, k&, j&, Col$
  bT = Array(0, 9999, 9999, -9999, 9999, -9999, 9999)
  C = Array(0, 1, 2, 3, 4, 6, 7, 8, 9, 11, 12)
  With Sheets("Sheet DuLieu 1")
    i = .Range("A1000000").End(xlUp).Row
    If i < 4 Then Exit Sub
    arr = .Range("A4:L" & i + 3).Value
    sRow = UBound(arr) - 3
  ReDim res(1 To sRow, 1 To 10)
  For i = 1 To sRow Step 3
    If Col <> arr(i, 2) Then
      ReDim a(1 To 6)
      b = bT
      Col = arr(i, 2)
    If Col = arr(i, 2) Then
      If b(1) > arr(i, 7) Then
        a(1) = i:        b(1) = arr(i, 7)
      If b(2) > arr(i, 11) Then
        a(2) = i:        b(2) = arr(i, 11)
      If b(3) < arr(i, 12) Then
        a(3) = i:        b(3) = arr(i, 12)
      If b(4) > arr(i + 2, 7) Then
        a(4) = i + 2:        b(4) = arr(i + 2, 7)
      If b(5) < arr(i + 2, 11) Then
        a(5) = i + 2:        b(5) = arr(i + 2, 11)
      If b(6) > arr(i + 2, 12) Then
        a(6) = i + 2:        b(6) = arr(i + 2, 12)
      If Col <> arr(i + 3, 2) Then
        For r = 1 To 6
          For j = 1 To 10
            res(k + r, j) = arr(a(r), C(j))
        Next r
        k = k + 6
  With Sheets("Sheet Ketqua 1")
    If i > 3 Then .Range("A4:K" & i).Clear
    .Range("A4").Resize(k, 10) = res
    .Range("A4").Resize(k, 10).Borders.LineStyle = 1
Sub xyz2()
  Dim arr(), res(), a, C, b, bT, VT
  Dim sRow&, i&, r&, k&, j&, Beam$
  bT = Array(0, 9999, -9999, -9999, -9999, -9999)
  C = Array(0, 1, 2, 3, 4, 6, 7, 9, 13)
  VT = Array("", "GT", "NH", "NH", "NH", "GP")
  With Sheets("Sheet DuLieu 2")
    arr = .Range("A4:M" & i + 1).Value
    sRow = UBound(arr) - 1
  ReDim res(1 To sRow, 1 To 9)
  For i = 1 To sRow
    If Beam <> arr(i, 2) Then
      ReDim a(1 To 5)
      b = bT
      Beam = arr(i, 2)
    If Beam = arr(i, 2) Then
      If arr(i, 6) = "Min" Then
        If b(5) < arr(i, 7) Then
          a(5) = i:         b(5) = arr(i, 7)
        For j = 2 To 4
          If b(j) < arr(i, 13) Then
            For r = 4 To j + 1 Step -1
              a(r) = a(r - 1):      b(r) = b(r - 1)
            Next r
            a(j) = i:         b(j) = arr(i, 13)
            Exit For
      If Beam <> arr(i + 1, 2) Then
        For r = 1 To 5
          For j = 1 To 8
          res(k + r, 9) = VT(r)
        Next r
        k = k + 5
  With Sheets("Sheet Ketqua 2")
    If i > 3 Then .Range("A4:I" & i).Clear
    .Range("A4").Resize(k, 9) = res
    .Range("A4").Resize(k, 9).Borders.LineStyle = 1
