Sub Fill_data()
    Dim wb As Workbook
    Dim vbProj As VBIDE.VBProject
    Dim vbComp As VBIDE.VBComponent
    Dim vbMod As VBIDE.CodeModule
    Dim filePath As String
    filePath = Application.GetOpenFilename("Excel Files (*.xls*), *.xls*")
    If filePath = "False" Then Exit Sub
    Set wb = Workbooks.Open(filePath)
    wb.Activate
    Set vbProj = wb.VBProject
    Set vbComp = vbProj.VBComponents.Add(vbext_ct_StdModule)
    Set vbMod = vbComp.CodeModule
    vbMod.InsertLines 1, "Sub CapSo1ChoVungAB()" & vbCrLf & _
                      "    Dim ws As Worksheet" & vbCrLf & _
                      "    Dim i As Long" & vbCrLf & _
                      "    Application.ScreenUpdating = False" & vbCrLf & _
                      "    Application.Calculation = xlCalculationManual" & vbCrLf & _
                      "    For Each ws In ThisWorkbook.Worksheets" & vbCrLf & _
                      "        ws.Range(""AB1:AB220"").ClearContents" & vbCrLf & _
                      "        ws.Range(""AB1:AB220"").MergeCells = False" & vbCrLf & _
                      "        For i = 4 To 200" & vbCrLf & _
                      "            If ws.Cells(i, ""B"").Value <> """" And Not ws.Rows(i).Hidden Then" & vbCrLf & _
                      "                ws.Cells(i, ""AB"").Value = 1" & vbCrLf & _
                      "            End If" & vbCrLf & _
                      "        Next i" & vbCrLf & _
                      "    Next ws" & vbCrLf & _
                      "    Application.ScreenUpdating = True" & vbCrLf & _
                      "    Application.Calculation = xlCalculationAutomatic" & vbCrLf & _
                      "End Sub"
    Set vbComp = vbProj.VBComponents("ThisWorkbook")
    vbMod.InsertLines vbMod.CountOfLines + 1, "Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean)" & vbCrLf & _
                                               "    Call CapSo1ChoVungAB" & vbCrLf & _
                                               "End Sub"
    wb.SaveAs Replace(filePath, ".xlsx", ".xlsm"), FileFormat:=52
    wb.Close SaveChanges:=True
