Chia sẻ: Công thức chuyển số thành chữ cho Excel 2007
huuthang_bd
Chuyên gia GPE
Donate (Momo)
Donate
Thợ đụng
Như đã hứa, hôm nay tôi chia sẻ công thức chuyển số thành chữ sử dụng được trên Excel 2007 trở lên.
Tiếng Việt:
=IF(ABS(A1)>=10^15;"###";IF(A1<0;"Âm ";MID("KMHBBNSBTC";LEFT(ROUND(A1;0))+1;1))&MID(TRIM(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(RIGHT(TEXT(A1;SUBSTITUTE("0\*0\=0\/0\*0;0\*0\=0\/0\*0";0;"0\-0\+0"));LEN(ROUND(ABS(A1);0))*2-1);"0-0+0*";"");"0-0+0/";"");"0-0+0";"");"0+0";"");"0+";" lẻ");"+0";"+");"+5";"+ lăm");"1+";" mười");"+1";"+ mốt");"_=";"_");0;" không");1;" một");2;" hai");3;" ba");4;" bốn");5;" năm");6;" sáu");7;" bảy");8;" tám");9;" chín");"+";" mươi");"-";" trăm");"*";" ngàn,");"/";" triệu,");",=";"=");"=";" tỷ,")&"  ";",  ";""));2-(A1<0);999))
Tiếng Anh:
=IF(ABS(A1)>=10^15;"###";IF(A1<0;"Negative ";MID("ZOTTFFSSENTETTFFSSEN";LEFT(ROUND(A1;0);IFERROR(IF(LEFT(ROUND(A1;0))*MOD(INT(LOG10(ROUND(ABS(A1);0)));3)=1;2;1);1))+1;1))&MID(TRIM(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(RIGHT(TEXT(A1;SUBSTITUTE("0\\0\=0\/0\*0;0\\0\=0\/0\*0";0;"0\-0\+0"));LEN(ROUND(ABS(A1);0))*2-1);"0-0+0=";"");"0-0+0/";"");"*0-";"* and");"0-0+0*";"");"0-";"");"0+";"");"1+0";" ten");"1+1";" eleven");"1+2";" twelve");"1+3";" thirteen");"1+4";"4teen");"1+5";" fifteen");"1+6";"6teen");"1+7";"7teen");"1+8";"8een");"1+9";"9teen");"2+";" twenty:");"3+";" thirty:");"4+";" forty:");"5+";" fifty:");"8+";"8y:");"+";"ty:");"y:0";"y");0;" zero");1;" one");2;" two");3;" three");4;" four");5;" five");6;" six");7;" seven");8;" eight");9;" nine");"-";" hundred and");"*";" thousand,");"/";" million,");"=";" billion,");"\";" trillion,");": ";"-");" and zero";"");", a";" a")&"  ";",  ";""));2-(A1<0);999))
Lưu ý: Các công thức trên chỉ chuyển được số trong phạm vi từ -10^15+1 đến 10^15-1, ngoài phạm vi này công thức sẽ trả về "###"
Bạn @cantl vào nhận hàng nhé.
Nhân tiện tôi chia sẻ luôn công thức chuyển số thành chữ tiếng Việt và tiếng Anh sử dụng trên Excel 365 và Goolge Sheet, không giới hạn độ lớn của số cần đọc (số lớn nhập vào dạng chuỗi).
Tiếng Việt:
=LET(so;A1;d;SIGN(so)+2;n;"00"&IF(ISTEXT(so);MID(so;1+(d=1);99);TEXT(so;"0;0"));l;LEN(n);g;INT(l/3);r;SUBSTITUTE(TEXTJOIN(",";1;MAP(SEQUENCE(g;1;g;-1);LAMBDA(k;LET(s;LEFT(n;l-k*3+3);a;{"không";"một";"hai";"ba";"bốn";"năm";"sáu";"bảy";"tám";"chín"};b;MIN(k;MOD(k-2;3)+2);x;RIGHT(s;3)*1;y;MOD(x;100);z;MOD(y;10);IF(x>0;IF(LEN(s)>4;" "&INDEX(a;INT(x/100)+1)&" trăm"&IF(AND(y<10;z>0);" lẻ";"");"")&IF(y>=20;" "&INDEX(a;INT(y/10)+1)&" mươi";IF(y>=10;" mười";""))&IF(z>0;LET(t;(y>11)*((z=1)+(z=5)*2)+1;" "&CHOOSE(t;INDEX(a;z+1);"mốt";"lăm"));"")&CHOOSE(b;"";" ngàn";" triệu";" tỷ");IF(b=4;" tỷ";""))))));", tỷ";" tỷ");CHOOSE(d;"Âm"&r;"Không";UPPER(MID(r;2;1))&MID(r;3;999)))
Tiếng Anh:
=LET(so;A1;d;SIGN(so)+2;n;"00"&IF(ISTEXT(so);MID(so;1+(d=1);99);TEXT(so;"0;0"));l;LEN(n);g;INT(l/3);r;SUBSTITUTE(TEXTJOIN(",";1;MAP(SEQUENCE(g;1;g;-1);LAMBDA(k;LET(s;LEFT(n;l-k*3+3);a;{"zero";"one";"two";"three";"four";"five";"six";"seven";"eight";"nine";"ten";"eleven";"twelve";"thirteen";"fourteen";"fifteen";"sixteen";"seventeen";"eighteen";"nineteen"};b;{"";"twenty";"thirty";"forty";"fifty";"sixty";"seventy";"eighty";"ninety"};x;RIGHT(s;3)*1;y;MOD(x;100);z;MOD(y;10);IF(x>0;IF(LEN(s)>4;IF(x<100;IF(k=1;" and";"");" "&INDEX(a;INT(x/100)+1)&" hundred"&IF(y>0;" and";""));"")&IF(y>=20;" "&INDEX(b;INT(y/10))&IF(z>0;"-"&INDEX(a;z+1);"");IF(y>0;" "&INDEX(a;y+1);""))&CHOOSE(k;"";" thousand"; " million"; " billion"; " trillion";" quadrillion";" quintillion";" sextillion";" septillion";" octillion");"")))));", and";" and");CHOOSE(d;"Negative"&r;"Zero";UPPER(MID(r;2;1))&MID(r;3;999)))
-460.101.895.031
Âm bốn trăm sáu mươi tỷ, một trăm lẻ một triệu, tám trăm chín mươi lăm ngàn, không trăm ba mươi mốt
Negative four hundred and sixty billion, one hundred and one million, eight hundred and ninety-five thousand and thirty-one
  • So thanh chu.xlsx
    11.6 KB · Đọc: 188
=IF(ABS(A1)>=10^15;"###";IF(A1<0;"Âm ";MID("KMHBBNSBTC";LEFT(ABS(A1))+1;1))&MID(TRIM(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(RIGHT(TEXT(A1;SUBSTITUTE("0;0";0;"0\-0\+0\*0\-0\+0\=0\-0\+0\/0\-0\+0\*0\-0\+0"));LEN(ROUND(ABS(A1);0))*2-1);"0-0+0*";"");"0-0+0/";"");"0-0+0";"");"0+0";"");"0+";" lẻ");"+0";"+");"+5";"+ lăm");"1+";" mười");"+1";"+ mốt");"_=";"_");"0";" không");"1";" một");"2";" hai");"3";" ba");"4";" bốn");"5";" năm");"6";" sáu");"7";" bảy");"8";" tám");"9";" chín");"+";" mươi");"-";" trăm");"*";" ngàn,");"/";" triệu,");",=";"=");"=";" tỷ,")&"  ";",  ";""));2-(A1<0);999))
Lưu ý: Công thức trên chỉ chuyển được số trong phạm vi từ -10^15+1 đến 10^15-1, ngoài phạm vi này công thức sẽ trả về "###"
Tiếng Việt:
Tiếng Anh:
-460.000.101.895.031
Vinh dự quá bác ạ!!!
Em đã đối chiếu với hàm VBA của bác, giống tuyệt đối. :D :D :D
    55.2 KB · Đọc: 51
Quá đỉnh luôn anh ạ, em chạy thử công thức dành cho Excel 2007 trở lên, dữ liệu hơn 1 triệu dòng chạy công thức của anh sổ xuống mất khoảng 5 giây, tốc độ quá tuyệt vời. :clap:
Có nhiều bạn sẽ hỏi sao em chép đúng biểu thức ở trên mà báo lỗi hoài.
Vì là công thức với dấu tách đối số có thể là dấu phẩy hoặc dấu chấm phẩy. Dấu tách mảng là dấu \ hoặc dấu ;. Mà Excel của bạn đang là dấu ngược lại thì chắc chắn lỗi.
Để sao chép công thức dài như công thức trong bài viết này một cách nhanh nhất các bạn có thể tham khảo Add-in dưới đây:
Ví dụ chỉ cần nhấn nút [sao chép] phần công thức ở trên và gõ vào ô Excel:
Dán công thức và chuẩn hóa:
=fx_paste()
Chuẩn hóa công thức cho Google Sheets:
=Fx_Copy_forGoolgeSheet()
Đơn giản vậy thôi.
Các bạn có thể tham khảo thêm hàm Đọc số trong chuỗi chứa số được viết bằng VBA.
Ví dụ với chuỗi : "Vào ngày 12/04/2023 tôi được tin báo trúng số Vietlott với giải thưởng chỉ có 44,037,000,000 VNĐ, nhưng may mắn họ báo nhầm người"
Có thể đọc số giữ chuỗi hoặc chỉ đọc số.
Công thức ngon. Tuy nhiên muốn thay đổi ô tham chiếu thì chịu khó dùng Ctrl+H
Cách của em hơi khác tí. Em sẽ:
- Dán công thức vào ô bất kỳ khác A1 trước.
- Ctrl+x ô A1 dán vào vị trí bản thân cho là hoàn hảo nào đấy.
- Nhập số vào ô hoàn hảo ấy.
Cách của bạn chuẩn đấy. Nhưng không phải ai cũng biết. :D
Nhờ bác góp ý hộ. Cơ bản công thức này chia số cần đọc theo hàng trăm, hàng chục và đơn vị, đọc từng bộ 3 số rồi kết hợp với "hàng" (ngàn, triệu, tỷ).
=LET(so,SUBSTITUTE(IF(ISTEXT(A2),A2,TEXT(A2,"0")),"-",""),
    doc_so,TRIM(IF(LEFT(A2)="-","Âm ","")&TEXTJOIN(", ",,
        LET(l,SEQUENCE(ROUNDUP(LEN(so)/3,0),,1,3),m,MOD(2*LEN(so),3),
            tr,--MID(so,l-m,1),ch,--MID(so,l-m+1,1),dv,--MID(so,l-m+2,1),
            chuso,{"không ","một ","hai ","ba ","bốn ","năm ","sáu ","bảy ","tám ","chín "},
            doc_tr,IFERROR(IF(tr+ch+dv>0,INDEX(chuso,tr+1)&"trăm ",""),""),
            doc_ch,IFERROR(IF(ch+dv>0,IF(ch=0,"lẻ ",IF(ch=1,"mười ",INDEX(chuso,ch+1)&"mươi ")),""),""),
            doc_dv,IF(dv>0,IF(dv=1,IF(IFERROR(ch,0)>1,"mốt ","một "),IF(IFERROR(dv,0)=5,IF(IFERROR(ch,0)=0,"năm ","lăm "),INDEX(chuso,dv+1))),""),
            doc_hang,IF(IFERROR(tr,0)+IFERROR(ch,0)+dv>0,INDEX({"","ngàn","triệu"},MOD((MAX(l)-l)/3,3)+1),""),
            doc_ty,IF(MOD(MAX(l)-l,9)=0,IF(l=MAX(l),"","tỷ"),""),
        doc_tr&doc_ch&doc_dv&doc_hang&doc_ty))),
SUBSTITUTE(SUBSTITUTE(doc_so,LEFT(doc_so),UPPER(LEFT(doc_so)),1),", tỷ"," tỷ"))&" đồng."
Ế ẩm quá phải vào thớt hót của người khác rao =)))
Người ta úp file lên rồi thì cứ thế chép lấy công thức trong file mà dùng, dấu phân cách là gì thì mặc kệ nhà máy tính, nhà phần mềm nó tự biết mà làm.
Chép công thức ra bài là để dành người có khả năng đọc được nó.
Trước mắt tôi thấy công thức của bạn không hoạt động được trên Google Sheet. Những hàm bạn dùng Google Sheet đều có mà công thức không sử dụng được trên Google Sheet là một điểm trừ rồi.
Cùng suy nghĩ luôn.
Nhưng khách đến nhà không lẽ... :D
Công thức quá đỉnh ạ. Cảm ơn sự kỳ công và chia sẻ tuyệt vời của bác ạ. Lại có thêm một hàm bỏ túi cho những file cần "di chuyển" nhiều rồi ạ.
Cảm ơn bác. Em không xài Google Sheet nên không biết viết sao cho nó hoạt động trên đó. Để từ từ nghiên cứu sau.
Em viết công thức trên để tự học là chính. Bữa có đọc trên trang chủ về mấy hàm kết hợp với LET mà nó viết nhức đầu quá nên thôi. Bởi vậy nên hàm Map và Lambda em đâu có xài được.
Thì trước giờ tôi cũng có biết LET với LAMBDA là gì đâu, tôi dùng Excel 2007 từ xưa đến giờ. Tại thấy cái bạn giỏi excel kia hô to quá nên tôi mới dùng excel online làm thử xem thế nào thôi.
Cái máy cùi bắp ở nhà, bấm vào step in coi từng bước của công thức như thế nào thì đến chỗ hàm MAP đơ máy tự thoát Excel luôn.
Tôi thấy Microsoft mô tả rất dễ hiểu mà. Nếu muốn hiểu nguyên lý thì bạn nên thử với công thức đơn giản.
MAP({1;2;3};LAMBDA(x;x*x)) = {1;4;9}
MAP({1;2;3};LAMBDA(x;x*2)) = {2;4;6}
f(x))) = {f(1);f(2);f(3)}
Như đã hứa, hôm nay mình chia sẻ công thức chuyển số thành chữ sử dụng được trên Excel 2007 trở lên.
_=";"_");"0";" không phải");"1";" một");"2";" hai");"3";" ba");"4";" bốn");"5";" năm");"6";" sáu");"7";" bảy");"8";" tám");"9";" chín");"+";" tút");"-";" Xe điện");"*";" ngàn,");"/";" triệu,");",=";"=");"=";" Tỷ,")&" ";", ";""));2-(A1<0);999))[/CODE]
Lưu ý: Công thức chuyển đổi chỉ được đánh số trong phạm vi từ -10^15+1 đến 10^15-1, ngoài phạm vi công thức này sẽ trả về "###"
Nhân tiện ích tôi chia sẻ luôn công thức chuyển số thành chữ tiếng Việt và tiếng Anh sử dụng trên Excel 365 và Goolge Sheet, không giới hạn độ lớn của số cần đọc (số lớn nhập vào định dạng chuỗi).
Tiếng Việt:
")&CHOOSE(b;"";" điểm";" triệu";" tỷ");IF(b=4;" tỷ";""))))));", tỷ";" Tỷ");CHOOSE(d;"Âm"&r;"Không";UPPER(MID(r;2;1))&MID(r;3;999)))[/CODE]
Tiếng Anh:
Và";"");" "&INDEX(a;INT(x/100)+1)&" Trăm"&IF(y>0;" và";""));"")&IF(y>=20;" "&INDEX(b;INT (y/10))&IF(z>0;"-"&INDEX(a;z+1);"");IF(y>0;" "&INDEX(a;y+1);""))&CHOOSE (k;"";"nghìn"; "triệu"; "tỷ"; "nghìn Tỷ";"nghì Tỷ";"nghìn Tỷ";"sextillion";"septillion";"octillion");"")) ))) ;", Và";" and");CHOOSE(d;"Negative"&r;"Zero";UPPER(MID(r;2;1))&MID(r;3;999)))[/CODE] tỉ lệ";" Nghìn Tỷ Tỷ ";" Nghìn tỷ tỷ";" octillion");""))))); ", và";" and");CHOOSE(d;"Negative"&r;"Zero";UPPER(MID(r;2;1))&MID(r;3;999)))[/CODE] tỉ lệ ";" Nghìn tỷ tỷ";" Nghìn tỷ tỷ";" octillion");"")))));", và";" and");CHOOSE(d;"Negative"&r;"Zero";UPPER(MID(r;2;1))&MID(r;3;999)))[/CODE]
Âm ba trăm sáu mươi tỷ, một trăm lẻ một triệu, tám trăm chín mươi vạn, không trăm ba mươi mốt
Âm bốn trăm sáu mươi tỷ một trăm lẻ một triệu tám trăm chín tàn ác ma quỷ
thêm chữ đồng đằng sau thì làm thế nào vậy bác
