Hỗ trợ chuyển 1 dòng text thành 10 dòng text theo quy luật (1 người xem)
Có
Tình nghĩa giang hồ
Thanh sơn bất cải, lục thủy trường lưu
Chào anh chị em có trường hợp này nhờ anh chị hỗ trợ giúp.
A2 của em có chuổi dữ liệu
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,0]").Text = Sheet1.Rows(i).Cells(1)
B2:B11 em mong muốn
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i &]").Text = Sheet1.Rows(i).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 1 &]").Text = Sheet1.Rows(i + 1).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 2 &]").Text = Sheet1.Rows(i + 2).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 3 &]").Text = Sheet1.Rows(i + 3).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 4 &]").Text = Sheet1.Rows(i + 4).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 5 &]").Text = Sheet1.Rows(i + 5).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 6 &]").Text = Sheet1.Rows(i + 6).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 7 &]").Text = Sheet1.Rows(i + 7).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 8 &]").Text = Sheet1.Rows(i + 8).Cells(1)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0,& i + 9 &]").Text = Sheet1.Rows(i + 9).Cells(1)
tương tự A3 cảu em có chuổi dữ liệu
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,0]").Text = Sheet1.Rows(i).Cells(2)
B12:B21 em mong muốn
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i &]").Text = Sheet1.Rows(i).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 1 &]").Text = Sheet1.Rows(i + 1).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 2 &]").Text = Sheet1.Rows(i + 2).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 3 &]").Text = Sheet1.Rows(i + 3).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 4 &]").Text = Sheet1.Rows(i + 4).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 5 &]").Text = Sheet1.Rows(i + 5).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 6 &]").Text = Sheet1.Rows(i + 6).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 7 &]").Text = Sheet1.Rows(i + 7).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 8 &]").Text = Sheet1.Rows(i + 8).Cells(2)
session.findById("wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/txtKONP-KBETR[4,& i + 9 &]").Text = Sheet1.Rows(i + 9).Cells(2)
Em có rất nhiều chuổi kiểu này đều có chung quy luật là số 0 kế chuổi 0]").Text và chữ .Rows(i)
Em có thử viết code nhưng không hiệu quả, vì nó không hiểu chỗ này là Text.
Sub motdong_thanh_muoidong()
    Dim j As Integer
    For j = 0 To 9
        Range("B" & j + 1).Value = "session.findById(""wnd[0]/usr/tblSAPMV13ATCTRL_FAST_ENTRY/ctxtKOMG-MATNR[0," & i + j & "]"").Text = Sheet1.Rows(" & i + j & ").Cells(1)"
Nhờ anh chị hỗ trợ giúp em trường hợp này.
Em cảm ơn anh chị
B2:B11 em mong muốn
    Dim j As Integer
    For j = 0 To 9
Em cảm ơn anh chị
Bạn thử cho cái này lên đầu nhé.
Ở đây i có phải là biến đâu mà bạn để như vậy phải cho nó vào trong chứ.
Sub ThemChucDong()
 Dim Rws As Long, W As Integer, J As Long, Dm As Byte, Vtr As Byte
 Dim StrC As String
 Const Ii As String = "(i)"
 Rws = [A2].End(xlDown).Row
 ReDim Arr(1 To 13 * Rws, 1 To 1) As String
 [C2].Resize(13 * Rws).Value = ""
 For J = 2 To Rws
    StrC = Cells(J, "A").Value
    Vtr = InStr(StrC, Ii) + 1
    If Vtr Then
        W = W + 1:              Arr(W, 1) = StrC
        For Dm = 1 To 9
            W = W + 1
            Arr(W, 1) = Left(StrC, Vtr) & "+" & Str(Dm) & Mid(StrC, Vtr + 1, Len(StrC))
        Next Dm
 Next J
 [C2].Resize(W).Value = Arr()
Sub ThemChucDong()
 Dim StrC As String
 For J = 2 To Rws
    If Vtr Then
        For Dm = 1 To 9
            W = W + 1
            Arr(W, 1) = Left(StrC, Vtr) & "+ " & Str(Dm) & Mid(StrC, Vtr + 1, Len(StrC))
        Next Dm
 Next J
Dạ em cảm ơn bác SA_DQ. Nhưng của em cần 2 thông tin: 0]").Text và chữ .Rows(i).
Trong đoạn code này thì chỗ Rows(i) đã đúng yêu cầu. Còn chỗ 0]").Text thì chưa đúng bác ạ.
Bác SA_DQ có thể sửa giúp em thêm chút xíu nữa được không ?
Nó phải ra & i &, & i + 1& , & i + 2&.................
Em cảm ơn bác.
Công thức được không bạn?
B2=SUBSTITUTE(SUBSTITUTE(OFFSET($A$1,ROUNDUP(ROW(A1)/10,0),),".Rows(i).",".Rows(i+"&MOD(ROW(A1)-1,10)&")."),",0]"").Text",",& (i + "&MOD(ROW(A1)-1,10)&") &]"").Text")
Dạ công thức cũng được anh, nhưng mà công thức này nó ra dư 2 cái dấu ( ) với dư chỗ i+0
Dư dấu () thì cũng được. Nhưng có cách nào i + 0 thì ghi là i được không anh
Em quên mất rows(i) và row(i+0) giống nhau. Em cảm ơn anh Thắng.
Chưa thỏa i xì xì theo yếu cầu của bạn (& bạn tự sủa thử trước đi nha):
Sub ThemChucDong()
 Dim Rws As Long, J As Long, W As Integer, Dm As Byte, VTr As Byte, VTr0 As Byte
 Dim StrC As String
 Const C1 As String = "0,0":            Const C2 As String = "(i)"
 Range("C2").Resize(Rws * 13).Value = ""
 For J = 2 To Rws
    VTr = InStr(StrC, C1) + 2
    For Dm = 0 To 9
        W = W + 1
        Arr(W, 1) = Left(StrC, VTr) & "& i &+" & CStr(Dm) & Mid(StrC, VTr + 1, Len(StrC))
        VTr0 = InStr(Arr(W, 1), C2) + 1
        Arr(W, 1) = Left(Arr(W, 1), VTr0) & "+ " & CStr(Dm) & Mid(Arr(W, 1), VTr0 + 1, Len(StrC))
    Next Dm
 Next J
 Range("C2").Resize(W).Value = Arr()
Thử dùng công thức cho excel 365
=LET(t,A2:A6,
f,LAMBDA(a,b,SUBSTITUTE(SUBSTITUTE(a,"Rows(i)","Rows(i + "&b&")"),",0]"").Text",",& i + "&b&" &]"").Text")),
ar,DROP(REDUCE("",t,LAMBDA(x,y,LET(ty,f(y,SEQUENCE(10,,0)),VSTACK(x,ty)))),1),
SUBSTITUTE(ar," + 0",""))
