Sub Run()
Dim MOrder(), LRw As Long, ikey As String
ReDim Result(1 To 50000, 1 To 7)
LRw = [A10000].End(xlUp).Row
MOrder = Range("A4:C" & LRw).Value
'ActiveSheet.Range("F4:L50000").ClearContents
With Sheets("Data")
    .AutoFilterMode = 0
    LastRw = .Cells(50000, 2).End(xlUp).Row
    SProduct = .Range("A2:A" & LastRw).Value
    Material = .Range("E2:G" & LastRw).Value
    SQty = .Range("I2:I" & LastRw).Value
    Set Dict1 = CreateObject("scripting.dictionary")
    For i = 1 To UBound(SProduct, 1)
        'If Not Dict1.exists(SProduct(i, 1)) Then
            'Dict1.Add SProduct(i, 1), ""
            ikey = SProduct(i, 1)
            Dict1.Item(ikey) = Dict1.Item(ikey) & "|" & i
        'End If
t = Timer
For i = 1 To UBound(MOrder, 1)
    InitialProduct = MOrder(i, 1)
    ManufactQty = MOrder(i, 3)
    CalculateBOM_2 InitialProduct, ManufactQty
    'CalculateBOM InitialProduct, ManufactQty
If m > 0 Then
    'ActiveSheet.[F4].Resize(m, 7) = Result
    ActiveSheet.[N4].Resize(m, 7) = Result
Erase Material, SQty, SProduct, Result
Set dic1 = Nothing
InitialProduct = "": ManufactQty = 0: m = 0
MsgBox Timer - t & " second", , "Ptm0412"
Sub CalculateBOM_2(ByVal Product As String, ByVal PrQty As Double)
    Dim S As Variant
    S = Split(Dict1.Item(Product), "|")
    For i = 1 To UBound(S)
        j = Val(S(i))
            If Not Dict1.exists(CStr(Material(j, 1))) Then
                m = m + 1
                Result(m, 1) = InitialProduct
                Result(m, 2) = ManufactQty
                Result(m, 3) = Material(j, 1)
                Result(m, 4) = Material(j, 2)
                Result(m, 5) = Material(j, 3)
                Result(m, 7) = SQty(j, 1) * PrQty
                Result(m, 6) = Result(m, 7) / ManufactQty
                NewPrqty = SQty(j, 1)
                CalculateBOM_2 Material(j, 1), NewPrqty * PrQty
