Trang 6
TÔI GỬI TỪNG TRANG DỊCH BẰNG GOOGLE (DỊCH CHAY) KÍNH MONG HỖ TRỢ BẰNG CHUYÊN MÔN:
Auditing of the Standard
Tesco will undertake regular audits against this standard and will determine the degree of compliance to each section. Your TTM can give you information on the Tesco audit process. There is a likelihood that some non-conformances will be raised through the audit and these will be categorized as:
Critical - Failure to meet a safety standard or a legal standard; where this failure puts the customer and or Tesco brand integrity, at risk.
Major – A deficiency which requires prompt attention to prevent a potential safety failure or legal issue from arising; where this failure may potentially put customers or the Tesco brand integrity, at risk.
Minor – A deficiency which requires attention to improve Good Manufacturing Practice standards, Due Diligence documentation (our ability to defend a legal challenge) or to achieve compliance with Tesco standards.
Depending on the category of non conformances (critical, major, and minor) and numbers identified, sites will receive a specific rating.
Blue = Satisfactory
Green = Satisfactory
Amber = Improvement needed
Red = Not Satisfactory
Sites which receive a ‘Not Satisfactory’ rating will need to immediately contact their TTM.
In instances where a site has not previously worked with Tesco and is being audited as part of the initial approval process, the site will be rated as either Approved or Not Approved.
Country Specific Requirements
Although this Manufacturing Standard is a ‘Group’ document i.e. it applies globally; a small number of the clauses may apply only to factories supplying products to Tesco stores in specific countries e.g. in the UK.
Where this is the case, the clause will be slightly shaded (grey) and will note the specific country / countries where it is applicable. (For example see clause 2.8)
The standard may also make reference to additional Tesco Codes of Practice (COP). These COP’s may also only be applicable to factories supplying products to Tesco stores in specific countries e.g. the UK, and will note the specific country / countries where it is applicable
Kiểm toán của Standard
Tesco sẽ thực hiện kiểm toán thường xuyên đối với tiêu chuẩn này và sẽ xác định mức độ tuân thủ cho mỗi phần. TTM của bạn có thể cung cấp cho bạn thông tin về quá trình kiểm toán Tesco. Có một khả năng phi-conformances một số sẽ được nâng lên thông qua kiểm toán và các sẽ được phân loại là:
• Quan trọng - Việc không đáp ứng tiêu chuẩn an toàn hoặc một tiêu chuẩn pháp lý; nơi thất bại này khiến các khách hàng và toàn vẹn hoặc thương hiệu Tesco, có nguy cơ.
• Chính - Một thiếu vốn đòi hỏi sự quan tâm nhắc nhở để ngăn chặn một sự thất bại tiềm năng về an toàn hoặc vấn đề pháp lý phát sinh từ; nơi này không có khả năng có thể gây cho khách hàng hoặc sự toàn vẹn thương hiệu Tesco, có nguy cơ.
• Nhỏ - Một thiếu vốn đòi hỏi sự chú ý để cải thiện các tiêu chuẩn Thực hành tốt sản xuất, Do siêng tài liệu (khả năng của chúng tôi để bảo vệ một thách thức pháp lý) hay để đạt được việc tuân thủ các tiêu chuẩn Tesco.
Tùy thuộc vào thể loại của conformances (không quan trọng, lớn và nhỏ) và các con số được xác định, các trang web sẽ nhận được một đánh giá cụ thể.
• Blue = Satisfactory
• Màu xanh lá cây = Satisfactory
• Amber = cải thiện cần thiết
• Đỏ = Không Satisfactory
Các trang web nhận được một 'Không Satisfactory' rating sẽ cần phải ngay lập tức liên hệ với TTM của họ.
Trong trường hợp mà một trang web chưa từng làm việc với Tesco và đang được kiểm toán như là một phần của quá trình phê duyệt ban đầu, trang web sẽ được đánh giá là một trong hai được chấp thuận hay không chấp thuận.
Quốc gia cụ thể yêu cầu
Mặc dù tiêu chuẩn này là tập đoàn sản xuất 'tức là một' tài liệu này áp dụng trên toàn cầu; một số ít các điều khoản có thể chỉ áp dụng cho các nhà máy cung cấp sản phẩm đến các cửa hàng Tesco ở các quốc gia cụ thể ví dụ: tại Vương quốc Anh.
Nơi đây là trường hợp, các khoản sẽ được tô bóng hơi (xám) và sẽ lưu ý các quốc gia cụ thể / quốc gia mà nó được áp dụng. (Ví dụ: xem khoản 2,8)
Các tiêu chuẩn cũng có thể tham khảo để bổ sung Tesco Codes of Practice (COP). Những COP's cũng có thể chỉ được áp dụng cho các nhà máy cung cấp sản phẩm đến các cửa hàng Tesco ở các quốc gia cụ thể ví dụ: Vương quốc Anh, và sẽ lưu ý các quốc gia cụ thể / quốc gia mà nó được áp dụng
