Giúp sửa code chọn tài khoản để in (1 người xem)
Hongha0412
Tôi có file dùng để in sổ kế toán cần sửa code do có tình huống phát sinh mới.
Ví dụ: cần in sổ TK642 (TK chi tiết là 6421,6422), thì trong dữ liệu chỉ có 6421,6422, nên chưa thể in TK642 được.
Yêu cầu cụ thể trong file đính kèm.
Mới Edit lại
Sub InSoCai()
    Dim sArr(), dArr(), I As Long, J As Long
    Dim SoTK As Long, TKno As Long, TKco As Long, Er As Long
SoTK = Sheets("So").Range("D4").Value
With Sheets("T01")
    Er = .Range("D" & Rows.Count).End(xlUp).Row
    If Er < 7 Then Exit Sub
    sArr = .Range("D7:D" & Er).Resize(, 7).Value
ReDim dArr(1 To UBound(sArr), 1 To 6)
For I = 1 To UBound(sArr)
    If sArr(I, 5) <> Empty Then TKno = Left(sArr(I, 5), 3)
    If sArr(I, 6) <> Empty Then TKco = Left(sArr(I, 6), 3)
    If TKno = SoTK Or TKco = SoTK Then
        K = K + 1
        For J = 1 To 4
            dArr(K, J) = sArr(I, J)
        Next J
        If TKno = SoTK Then dArr(K, 5) = sArr(I, 7)
        If TKco = SoTK Then dArr(K, 6) = sArr(I, 7)
Next I
With Sheets("So")
    .Range("A13:F5000").Clear
    If K Then
        With .Range("A13").Resize(K, 6)
            .Value = dArr
            .Borders.LineStyle = xlContinuous
            .Borders(xlInsideHorizontal).Weight = xlHairline
        Er = .Range("A" & Rows.Count).End(xlUp).Row
        .Range("A13:A" & Er).HorizontalAlignment = xlCenter
        .Range("C13:C" & Er).HorizontalAlignment = xlLeft
        Union(.Range("B13:B" & Er), .Range("E13:F" & Er)).HorizontalAlignment = xlRight
        .Range("E13:F" & Er).NumberFormat = "#,##0"
        .Range("C" & Er + 1) = .Range("J4")
        .Range("E" & Er + 1) = "=Sum(E13:E" & Er & ")"
        .Range("F" & Er + 1) = "=Sum(F13:F" & Er & ")"
        With .Range("A" & Er + 1 & ": F" & Er + 1)
            .Font.Bold = True
        .Range("D" & Er + 3) = .Range("J3")
        .Range("A" & Er + 4) = .Range("J2"):  .Range("A" & Er + 9) = .Range("J5")
        .Range("D" & Er + 4) = .Range("J4"):  .Range("D" & Er + 9) = .Range("J6")
        .Range("A" & Er + 4 & ": C" & Er + 9).HorizontalAlignment = xlCenterAcrossSelection
        .Range("D" & Er + 3 & ": F" & Er + 9).HorizontalAlignment = xlCenterAcrossSelection
        ActiveSheet.PageSetup.PrintArea = "$A$1:$F" & Er + 9
If Target.Address = "$D$4" Or Target.Address = "$G$1" Then Call SoCai
Public Sub SoCai()
Dim sArr(), dArr(), R As Long, I As Long, J As Long, K As Long, TK As Long, Col As Long, Sh As String, col2 As Long
Dim Str1 As String, Str2 As String, Str3 As String, Str4 As String, Str5 As String, Str6 As String
Sh = [G1].Value
With Sheets(Sh)
    sArr = .Range(.[D7], .[D7].End(xlDown)).Resize(, 7).Value
ReDim dArr(1 To UBound(sArr, 1), 1 To 6)
With Sheets("So")
    TK = .Range("D4").Value
    Str1 = .[J1].Value: Str2 = .[J2].Value
    Str3 = .[J3].Value: Str4 = .[J4].Value
    Str5 = .[J5].Value: Str6 = .[J6].Value
    For I = 1 To UBound(sArr, 1)
        If sArr(I, 5) = TK Or sArr(I, 6) = TK Then
            K = K + 1
            Col = IIf(sArr(I, 5) = Tk
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            Col = IIf(sArr(I, 5) = TK, 5, 6)
            For J = 1 To 3
            For J = 1 To 3
            Next J
                dArr(K, Col) = sArr(I, 7)
                dArr(K, 4) = sArr(I, IIf(sArr(I, 5) = TK, 6, 5))
    Next I
            K = K + 1
            For J = 1 To 3
            Next J
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            For J = 1 To 3
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            For J = 1 To 3
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            For J = 1 To 3
Sh = [G1].Value
With Sheets(Sh)
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            For J = 1 To 3
With Sheets("So")
            K = K + 1
            For J = 1 To 3
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            For J = 1 To 3Dim Str1 As String, Str2 As String, Str3 As String, Str4 As String, Str5 As String, Str6 As String
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            For J = 1 To 3
    Next I
    .[A13:H1000].ClearContents
    .[A13:H1000].Borders.LineStyle = xlNone
    .[A13:H1000].Font.Bold = False
    .[F13:F1000].HorizontalAlignment = xlGeneral
    If K Then
        .[A13].Resize(K, 6) = dArr
        .[A13].Resize(K + 1, 6).Borders.LineStyle = xlContinuous
        .[A13].Resize(K, 6).Borders(xlInsideHorizontal).Weight = xlHairline
        .[C13].Offset(K) = Str1
        .[E13].Offset(K + 2) = Str3
        .[D13].Offset(K).Resize(, 4).Font.Bold = True
        .[E13:F13].Offset(K) = "=SUM(R13C:R[-1]C)" 'Cong tong Thu, Chi)
        .[B13].Offset(K + 3) = Str2
        .[B13].Offset(K + 8) = Str5
        .[E13].Offset(K + 3) = Str4
        .[E13].Offset(K + 8) = Str6
        .[E13].Offset(K + 2).Resize(7).HorizontalAlignment = xlCenter
    With Sheets("So")
        col2 = [k1].Value
        ActiveSheet.PageSetup.PrintArea = "$A$1:$F" & col2
Sao Dim str... nhiều vạy
Em cũng thắc mắc sao anh ấy dim lại nhiều lần thế với mục đích gì vậy nhỉ
Thà xử lầm không tha lầm
Chỉnh lại các dòng đầu
Public Sub SoCai()
Dim sArr(), dArr(), R As Long, I As Long, J As Long, K As Long, Col As Long, Sh As String, col2 As Long
Dim TK As String, Str1 As String, Str2 As String, Str3 As String, Str4 As String, Str5 As String, Str6 As String
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
    TK = .Range("D4").Value & "*"
        If CStr(sArr(I, 5)) Like TK Or CStr(sArr(I, 6)) Like TK Then
            K = K + 1
            Col = IIf(CStr(sArr(I, 5)) Like TK, 5, 6)
            For J = 1 To 3
            Next J
                dArr(K, 4) = sArr(I, IIf(CStr(sArr(I, 5)) Like TK, 6, 5))
    Next I
Public Sub SoCai()
Sh = [G1].Value
With Sheets(Sh)
With Sheets("So")
            K = K + 1
            For J = 1 To 3
            Next J
    Next I
Cảm ơn mọi người đã quan tâm và giúp đỡ.
Sau khi test lại, code đã hoạt động đúng ý.
Còn cái code cũ, cũng do mọi người chỉnh sửa giùm, nhưng sau đó mình có sửa thêm cho phù hợp, nên có thể nó hơi lung củng
Cài hoa lá cành sao nó lại dài thế :p:p:p
Sub InSoCai()
With Sheets("T01")
        K = K + 1
        For J = 1 To 4
        Next J
Next I
With Sheets("So")
    If K Then
            .Value = dArr
            .Font.Bold = True
chết cha rồi Cô giáo. Mình bị Ctrl V bị lố rồi. Xin lỗi cô giáo
Còn nữa kìa người ơi. Chưa xong được đâu (2 cái For I=.........) :p:p:p
Sub InSoCai()
With Sheets("T01")
        K = K + 1
        For J = 1 To 4
        Next J
Next I
With Sheets("So")
    If K Then
            .Value = dArr
            .Font.Bold = True
Code chạy ok quá. Mà giờ muốn đổi cái font chữ sang times new roman thì sửa chỗ nào vậy bạn.
Sub InSoCai()
With Sheets("T01")
        K = K + 1
        For J = 1 To 4
        Next J
Next I
With Sheets("So")
    If K Then
            .Value = dArr
            .Font.Bold = True
Sub InSoCai()
With Sheets("T01")
        K = K + 1
        For J = 1 To 4
        Next J
Next I
With Sheets("So")
    If K Then
            .Value = dArr
            .Font.Bold = True
bạn thử code này
Sub InSoCai()
With Sheets("T01")
        K = K + 1
        For J = 1 To 4
        Next J
Next I
With Sheets("So")
    If K Then
            .Value = dArr
            .Font.Bold = True
Bạn thêm dòng
  .Range("A13: F" & Er + 9).Font.Name = "Times New Roman"
vào trước dòng
You add row
in front of the line
You add row
before, NOT "in front of"
in front means:
.Range("A13: F" & Er + 9).Font.Name = "Times New Roman" ActiveSheet.PageSetup.PrintArea = "$A$1:$F" & Er + 9
And,
"You add row" is rather rude, and grammatically incorrect.
"Add the following line" would be more appropriate.
in front means:
And,
OK I understand. because I'm using google translate. Responsible then google
Trời đất ạ. Người Việt Nam nói chuyện với người Việt Nam lại nhờ google translate từ tiếng Việt sang tiếng Anh.
Hậu quả bị mắng là xứng đáng rồi
I'm happy to make the story humorous. I'm sorry teacher. Hope the teacher forgive me hihi
Tôi chỉ chỉnh sửa cho các bạn khác biết thôi. Không thấy gì trào lộng trong tiếng Anh sai ngữ pháp cả.
Nếu trào lộng thì nó phải thật cố tình sai, để người khác biết, ví dụ:
You increase row
Enter before row
