Nguyễn Hồng Quang
Thành viên GPE Hà Nội
- Điểm
- 1,468
- Tuổi
- 39
- Nơi ở
- Hà Nội
- Giới tính
- Nam
- Nghề nghiệp
- Kế toán
Sao dài thế không biết..so sánh
Sub sosanh_()
Const maxR As Long = 1048500 'so dong ket qua'
Dim HTbl As Object
Set HTbl = CreateObject("System.Collections.Hashtable")
Dim lR As Long, i As Long, ii As Long, j As Long, k As Long, idex As Long
Dim a(), b(), kq(), scode As String
With Sheet1
lR = .Range("A" & Rows.Count).End(xlUp).Row
If lR < 3 Then MsgBox "Khong co du lieu!": Exit Sub
a = .Range("A3:F" & lR).Value2
lR = UBound(a, 1)
ReDim b(1 To lR)
ReDim kq(1 To maxR, 1 To 6)
For i = 1 To lR
scode = a(i, 4) & "--" & a(i, 5) & "--" & a(i, 6)
HTbl.Add i, scode
b(i) = scode
idex = 1
For i = 1 To lR
scode = a(i, 1) & "--" & a(i, 2) & "--" & a(i, 3)
'1/ bang nhau tuong ung
'idex = idex + 1
If scode = b(idex) Then
j = j + 1
For k = 1 To 3
kq(j, k) = a(i, k)
Next k
For k = 4 To 6
kq(j, k) = a(idex, k)
Next k
idex = idex + 1
HTbl(i) = "" '/xoa scode trong thu vien
'2/ khong bang nhau tuong ung -> di tim trong thu vien
'2.1/ khong tim thay trong thu vien
If HTbl.ContainsValue(scode) = False Then
'mang 1 giu nguyen
j = j + 1
For k = 1 To 3
kq(j, k) = a(i, k)
Next k
'tang 1 dong mang 2
j = j + 1
For k = 4 To 6
kq(j, k) = a(i, k)
Next k
idex = idex + 1
'2.2/ tim thay trong thu vien
j = j + 1 'dong tuong ung dau tien
For k = 4 To 6
kq(j, k) = a(i, k)
Next k
' tim tu vi tri i+1 toi cuoi cung
For ii = i + 1 To UBound(a, 1)
If scode = b(ii) Then 'neu tim thay
j = j + 1
For k = 1 To 3
kq(j, k) = a(i, k)
Next k
For k = 4 To 6
kq(j, k) = a(ii, k)
Next k
idex = ii + 1
HTbl(i) = ""
Exit For 'thoat tim
Else 'neu chua tim thay
j = j + 1
For k = 4 To 6
kq(j, k) = a(ii, k)
Next k
Next ii
If idex > lR Then Exit For
If j >= maxR Then
MsgBox "Nhieu ket qua >> " & maxR & vbNewLine & _
"Chi lay " & maxR & "ket qua."
Exit For
Sheet2.Range("A3").Resize(maxR, 6).ClearContents
If j > 0 Then Sheet2.Range("A3").Resize(j, 6).Value = kq
Hình như chưa ổn vì ở ví dụ không quan tâm ký tự sau của số phiếu. Ví dụ ở K8:K10 so với N8:N10.Sao dài thế không biết..
PHP:Sub sosanh_() Const maxR As Long = 1048500 'so dong ket qua' Dim HTbl As Object Set HTbl = CreateObject("System.Collections.Hashtable") Dim lR As Long, i As Long, ii As Long, j As Long, k As Long, idex As Long Dim a(), b(), kq(), scode As String With Sheet1 lR = .Range("A" & Rows.Count).End(xlUp).Row If lR < 3 Then MsgBox "Khong co du lieu!": Exit Sub a = .Range("A3:F" & lR).Value2 lR = UBound(a, 1) End With ReDim b(1 To lR) ReDim kq(1 To maxR, 1 To 6) For i = 1 To lR scode = a(i, 4) & "--" & a(i, 5) & "--" & a(i, 6) HTbl.Add i, scode b(i) = scode Next i idex = 1 For i = 1 To lR scode = a(i, 1) & "--" & a(i, 2) & "--" & a(i, 3) '1/ bang nhau tuong ung 'idex = idex + 1 If scode = b(idex) Then j = j + 1 For k = 1 To 3 kq(j, k) = a(i, k) Next k For k = 4 To 6 kq(j, k) = a(idex, k) Next k idex = idex + 1 HTbl(i) = "" '/xoa scode trong thu vien '2/ khong bang nhau tuong ung -> di tim trong thu vien Else '2.1/ khong tim thay trong thu vien If HTbl.ContainsValue(scode) = False Then 'mang 1 giu nguyen j = j + 1 For k = 1 To 3 kq(j, k) = a(i, k) Next k 'tang 1 dong mang 2 j = j + 1 For k = 4 To 6 kq(j, k) = a(i, k) Next k idex = idex + 1 HTbl(i) = "" '/xoa scode trong thu vien '2.2/ tim thay trong thu vien Else j = j + 1 'dong tuong ung dau tien For k = 4 To 6 kq(j, k) = a(i, k) Next k ' tim tu vi tri i+1 toi cuoi cung For ii = i + 1 To UBound(a, 1) If scode = b(ii) Then 'neu tim thay j = j + 1 For k = 1 To 3 kq(j, k) = a(i, k) Next k For k = 4 To 6 kq(j, k) = a(ii, k) Next k idex = ii + 1 HTbl(i) = "" Exit For 'thoat tim Else 'neu chua tim thay j = j + 1 For k = 4 To 6 kq(j, k) = a(ii, k) Next k End If Next ii End If End If If idex > lR Then Exit For If j >= maxR Then MsgBox "Nhieu ket qua >> " & maxR & vbNewLine & _ "Chi lay " & maxR & "ket qua." Exit For End If Next i Sheet2.Range("A3").Resize(maxR, 6).ClearContents If j > 0 Then Sheet2.Range("A3").Resize(j, 6).Value = kq End Sub
Không tìm được thuật toán, vì người hỏi không mô tả rõ ràng cách chèn dòng trắng sao?Hình như chưa ổn vì ở ví dụ không quan tâm ký tự sau của số phiếu. Ví dụ ở K8:K10 so với N8:N10.
Sáng giờ cũng chưa tìm ra thuật toán
Ví dụ ở K8:K10 so với N8:N10 => không dựa vào 3 ký tự cuối của số phiếu. Nếu tuân theo quy tắc này thì ví dụ sai hoàn toàn, vì có rất nhiều mã trùng, và trùng 7 ký tự đầu của số phiếu.Em có 2 mảng dữ liệu gồm mảng 1 và mảng 2 như trong File và kết quả mong muốn so sánh giữa 2 mảng này. Em mong anh (chị) trong diễn đàn giúp đỡ em bằng vba với. Em xin cảm ơn
hình như chủ topic chỉ đề nghị căn theo mã thôiVí dụ ở K8:K10 so với N8:N10 => không dựa vào 3 ký tự cuối của số phiếu. Nếu tuân theo quy tắc này thì ví dụ sai hoàn toàn, vì có rất nhiều mã trùng, và trùng 7 ký tự đầu của số phiếu.
Bài này em chỉ so khớp phần mã hàng thôi anh à. Phần ký tự phiếu không cần so khớp àVí dụ ở K8:K10 so với N8:N10 => không dựa vào 3 ký tự cuối của số phiếu. Nếu tuân theo quy tắc này thì ví dụ sai hoàn toàn, vì có rất nhiều mã trùng, và trùng 7 ký tự đầu của số phiếu.
Xem lại quy tắc so sánh, nếu chỉ so sánh mã hàng thì so sánh trong bao nhiêu dòng (kiểu như từng tháng, quý, group gì đó), còn nếu so luôn cột thì nhiều dòng trùng lắm.Bài này em chỉ so khớp phần mã hàng thôi anh à. Phần ký tự phiếu không cần so khớp à
Vì phần kết quả em phải làm bằng thủ công; nhanh tay, nhanh mắt nên có thể bị sót anh à. Về nguyên tắc thì mã nào nhỏ hơn thì ưu tiên chèn dòng trắng trước.Không tìm được thuật toán, vì người hỏi không mô tả rõ ràng cách chèn dòng trắng sao?
Đẩy dòng trắng ưu tiên bên mảng 1 hay mảng 2 trước (hay theo điều kiện khác) - vì nó quyết định đến bước so sánh tiếp (có nhiều phương án đẩy/chèn dòng trắng)
Cứ nhìn cách đẩy (thêm dòng trắng) ở dữ liệu dòng 6 và dòng 11 (dữ liệu gốc) sẽ thấy trái nhau rồi.
Dữ liệu trước khi đưa vào mảng 1 và 2 em đã sort theo số phiếu nhập kho và đồng thời sort theo mã hàng. Nên dữ liệu trong 2 mảng này luôn tuân theo nguyên tắc là số phiếu NK là từ nhỏ đến lớn và trong từng phiếu NK các mã hàng cũng theo trật tự từ nhỏ đến lớn rồi anh à.Xem lại quy tắc so sánh, nếu chỉ so sánh mã hàng thì so sánh trong bao nhiêu dòng (kiểu như từng tháng, quý, group gì đó), còn nếu so luôn cột thì nhiều dòng trùng lắm.
Nhòm nhòm.. một lúc tưởng chủ thớt muốn so sánh cả 3 cột giống nhau.Hình như chưa ổn vì ở ví dụ không quan tâm ký tự sau của số phiếu. Ví dụ ở K8:K10 so với N8:N10.
Anh ơi ! nhờ anh xem lại giúp. Kết quả sau khi chạy code , bắt đầu bị lệch ở dòng số 6 anh à.Sao dài thế không biết..
Để em suy nghĩ về quy tắc dò và viết ra, hoặc tìm cách quay 1 cái clip và gửi lên. Cái này thực sự khó diễn tả bằng lời lắm anh à. Nên em cố gắng làm ra cái kết quả để hy vọng mọi người có thể hiểu ý tưởngNhòm nhòm.. một lúc tưởng chủ thớt muốn so sánh cả 3 cột giống nhau.
Chủ thớt nêu quy tắc dò xem nào? Rồi tự chỉnh chỗ nối 3 cột lại để tạo key so sánh chắc là được.
Hiện file dữ liệu của bạn chưa được sắp xếp như bạn nói:Vì phần kết quả em phải làm bằng thủ công; nhanh tay, nhanh mắt nên có thể bị sót anh à. Về nguyên tắc thì mã nào nhỏ hơn thì ưu tiên chèn dòng trắng trước.
Đây là dữ liệu nhập kho trong 1 năm do 2 người khác nhau theo dõi. Về lý thuyết là nó phải y hệt nhau (ví dụ phiếu NK1801/001 của người A có 1,2,3 mã hàng, số lượng 1,2,3 thì số phiếu NK1801/001 của người B cũng phải tương ứng) tuy nhiên thực tế lại có chênh lệch.
Trước mắt Em muốn so sánh ngang dòng (phần mã hàng) để nhanh chóng nhìn ra chênh lệch liên quan đến mã hàng (người A có mà người B không có)
theo kiểu đối chiếu (ngang hàng) mã - có trong A mà không có trong B và ngược lại - đưa ra 2 danh sách có số lượng phần tử như nhau tương ứng , trật tự A và B giữ nguyên
Đã mô tả xong chưa?Để em suy nghĩ về quy tắc dò và viết ra, hoặc tìm cách quay 1 cái clip và gửi lên. Cái này thực sự khó diễn tả bằng lời lắm anh à. Nên em cố gắng làm ra cái kết quả để hy vọng mọi người có thể hiểu ý tưởng
Vậy để em xem lại. Có thể là trong lúc tạo file có nhầm lẫnHiện file dữ liệu của bạn chưa được sắp xếp như bạn nói:
