Sub Autofit_dong()
MergeCellFit Range("D9")
Sub MergeCellFit(ByVal MergeCells As Range)
Dim Diff As Single
Dim FirstCell As Range, MergeCellArea As Range
Dim Col As Long, ColCount As Long, RowCount As Long
Dim FirstCellWidth As Double, FirstCellHeight As Double, MergeCellWidth As Double
If MergeCells.Count = 1 Then
Set MergeCellArea = MergeCells.MergeArea
With MergeCellArea
ColCount = .Columns.Count
RowCount = .Rows.Count
.WrapText = True
If RowCount = 1 And ColCount = 1 Then
.EntireRow.AutoFit
GoTo ExitSub
Set FirstCell = .Cells(1, 1)
FirstCellWidth = FirstCell.ColumnWidth
Diff = 0.75
For Col = 1 To ColCount
MergeCellWidth = MergeCellWidth + .Cells(1, Col).ColumnWidth + Diff
.MergeCells = False
FirstCell.ColumnWidth = MergeCellWidth - Diff
.EntireRow.AutoFit
FirstCellHeight = FirstCell.RowHeight
.MergeCells = True
FirstCell.ColumnWidth = FirstCellWidth
FirstCellHeight = FirstCellHeight / RowCount
.RowHeight = FirstCellHeight
ExitSub:
Cảm ơn bạn. Ý mình là code đảm bảo tự động co dãn được tất cả các dòng đã MergeCells trong Sheet theo điều kiện là số lượng ký tự nhiều hay ít . bạn xem lại giúp nhéBạn thử với sub này xem mình thử với 1 sub MergeCellFit trên diễn đàn !
Mã:Sub Autofit_dong() MergeCellFit Range("D9") End Sub Sub MergeCellFit(ByVal MergeCells As Range) Dim Diff As Single Dim FirstCell As Range, MergeCellArea As Range Dim Col As Long, ColCount As Long, RowCount As Long Dim FirstCellWidth As Double, FirstCellHeight As Double, MergeCellWidth As Double If MergeCells.Count = 1 Then Set MergeCellArea = MergeCells.MergeArea Else Set MergeCellArea = MergeCells End If Application.ScreenUpdating = False Application.EnableEvents = False Application.Calculation = xlCalculationManual With MergeCellArea ColCount = .Columns.Count RowCount = .Rows.Count .WrapText = True If RowCount = 1 And ColCount = 1 Then .EntireRow.AutoFit GoTo ExitSub End If Set FirstCell = .Cells(1, 1) FirstCellWidth = FirstCell.ColumnWidth Diff = 0.75 For Col = 1 To ColCount MergeCellWidth = MergeCellWidth + .Cells(1, Col).ColumnWidth + Diff Next .MergeCells = False FirstCell.ColumnWidth = MergeCellWidth - Diff .EntireRow.AutoFit FirstCellHeight = FirstCell.RowHeight .MergeCells = True FirstCell.ColumnWidth = FirstCellWidth FirstCellHeight = FirstCellHeight / RowCount .RowHeight = FirstCellHeight End With ExitSub: Application.Calculation = xlCalculationAutomatic Application.EnableEvents = True Application.ScreenUpdating = True End Sub
Cả cái trang tính nó rộng bao la vậy mà chạy Code thì máy treo mất ạCảm ơn bạn. Ý mình là code đảm bảo tự động co dãn được tất cả các dòng đã MergeCells trong Sheet theo điều kiện là số lượng ký tự nhiều hay ít . bạn xem lại giúp nhé
Sub Autofit_dong()
Dim Rng As Range, Cll As Range
Set Rng = Range("D7", Range("D" & Rows.Count).End(xlUp))
For Each Cll In Rng
If Cll.MergeCells = True Then
If Cll <> Empty Then MergeCellFit Cll
Anh thử cách khoanh vùng lại xem sao
Mã:Sub Autofit_dong() Dim Rng As Range, Cll As Range Set Rng = Range("D7", Range("D" & Rows.Count).End(xlUp)) For Each Cll In Rng If Cll.MergeCells = True Then If Cll <> Empty Then MergeCellFit Cll End If Next End Sub
Anh đã Copy cái Sub MergeCellFit vào file chưaXin cảm ơn bạn đã quan tâm - Mình chạy lỗi dòng code này bạn ơi
Có thể khống chế từ D7 đến G200 cũng được bạn ạ
Anh xem file thửTôi đã copi toàn bộ code này rồi
Sub Autofit_dong()
For Each Cll In Rng
Và sub này vào File rồi
Sub Autofit_dong()
MergeCellFit Range("D7")
Bạn xem lại giúp
Cảm ơn bạn - Xin cảm ơnAnh xem file thử
