Lequocvan
Sub test_buoc_4()
Dim Arr(), ketqua()
Dim K As Long, J As Long
Dim Dic As Object
Dim dic2 As Object
Dim Contents As Variant
Dim ParentKeys As Variant
Dim ChildKeys As Variant
Dim R As Long, r2 As Long
Dim LastR As Long
Dim LastCol As Integer
Dim WriteStr As String
Dic.CompareMode = vbTextCompare
' Dump the keys of the parent Dictionary in an array
With ThisWorkbook.ActiveSheet 'ThisWorkbook.Worksheets("212")
Function ConvertToLetter(iCol As Integer) As String
'from Microsoft 'Tu so thu tu cua cot cho ra ten chu cai cua cot do
Dim iAlpha As Integer
Dim iRemainder As Integer
iAlpha = Int(iCol / 27)
iRemainder = iCol - (iAlpha * 26)
If iAlpha > 0 Then
ConvertToLetter = Chr(iAlpha + 64)
If iRemainder > 0 Then
ConvertToLetter = ConvertToLetter & Chr(iRemainder + 64)
Dim Arr(), ketqua()
Dim Dic As Object
Dim dic2 As Object
Dim LastR As Long
LastR = .Cells(.Rows.Count, 1).End(xlUp).Row
LastCol = .Cells(1, .Columns.Count).End(xlToLeft).Column
'MsgBox LastR
'MsgBox LastCol
'MsgBox ConvertToLetter(LastCol)
Contents = .Range("A2:" & ConvertToLetter(LastCol) & LastR).Value
ReDim ketqua(1 To UBound(Contents, 1), 1 To 3) '1 to 3: ket qua se cho hien ra o may cot
' Loop through the array
For R = 1 To UBound(Contents, 1) ''Chay tu dong 1 den dong cuoi cung
'MsgBox UBound(Contents, 1) 'cho biet SoDong trong mang du lieu
'MsgBox Join(dic.Keys(), ";") 'MsgBox Join(dic.Keys(), vbNewLine)
'MsgBox Join(dic.Items(), ";")
'MsgBox k 'k chinh la so luong gia tri duy nhat, khi co them dong code:dic.Add Contents(r, 1), k
Range("I:J").Select
Selection.ClearContents
Range("I1").Select
Range("I2").Resize(1000, 4).Clear
Range("I2").Resize(K, 2).Value = ketqua
Range("J:J").Select
Selection.NumberFormat = "#,##0"
End WithLastCol = .Cells(1, .Columns.Count).End(xlToLeft).Column
'MsgBox LastR
'MsgBox LastCol
'dic.Add "Key " & r, "Item " & r
If Not Dic.Exists(Contents(R, 1)) Then
NextIf Not Dic.Exists(Contents(R, 1)) Then
K = K + 1
Dic.Add Contents(R, 1), K
ketqua(K, 1) = Contents(R, 1)
ketqua(K, 2) = Contents(R, 7)
ElseDic.Add Contents(R, 1), K
'MsgBox dic.Item(Contents(r, 1))
'Nếu muốn tính tổng theo giá trị duy nhất Key thì đặt công thức ntn ah?
End If'Nếu muốn tính tổng theo giá trị duy nhất Key thì đặt công thức ntn ah?
Range("I:J").Select
Range("I1").Select
Range("J:J").Select
If iAlpha > 0 Then
