Sửa dùm code cập nhật Sheet sang Sheet (1 người xem)
chapi.you
Tôi đã viết code thế này. Nhưng không hiểu sao nó vẫn chưa chạy được (đúng hơn nó cập nhật được 1 dòng. Mình muốn lưu được nhiều dòng).
Sub CapNhat()
    Dim eR As Long
    Dim iR
    With S4
        eR = .[A50000].End(xlUp).Row + 1
        .Cells(eR, 1).Resize(, 1) = [c10]
        .Cells(eR, 2).Resize(, 1) = [c9]
        .Cells(eR, 3).Resize(, 1) = [h3]
        .Cells(eR, 4).Resize(, 1) = CDate([C4])
        .Cells(eR, 5).Resize(, 1) = [f8]
        .Cells(eR, 6).Resize(, 1) = Format([h8], "dd/MM/yyyy") ' Sao khong dung CDate([h8]) duoc?
        .Cells(eR, 7).Resize(, 1) = [h4]
        .Cells(eR, 8).Resize(, 1) = [h5]
        .Cells(eR, 9).Resize(, 1) = [d8]
        iR = IIf([b12].End(xlDown).Row > 42, 0, [b12].End(xlDown).Row - 12)
        .Cells(eR, 10).Resize(, 1) = [a13].Offset(, 2).Resize(iR, 1).Value
        .Cells(eR, 11).Resize(, 1) = [a13].Offset(, 1).Resize(iR, 1).Value
        .Cells(eR, 12).Resize(, 1) = [a13].Offset(, 3).Resize(iR, 1).Value
        .Cells(eR, 13).Resize(, 1) = [a13].Offset(, 6).Resize(iR, 1).Value
        .Cells(eR, 14).Resize(, 1) = [a13].Offset(, 5).Resize(iR, 1).Value
        .Cells(eR, 17).Resize(, 1) = [a13].Offset(, 7).Resize(iR, 1).Value
        .Cells(eR, 19).Resize(, 1) = [a13].Offset(, 8).Resize(iR, 1).Value
        Application.Union([h3], [c6:c7], [f8], [h8], [c10], [a13:i42]).ClearContents
Sub CapNhat()
    Dim eR As Long
    Dim iR
    With S4
Sửa thành vầy thử xem:
Sub CapNhat()
  Dim eR As Long, iR, SrcRng As Range
  Set SrcRng = S1.Range(S1.[A13], S1.[A44].End(xlUp))
  iR = SrcRng.Rows.Count
  With S4
   .Cells(eR, 1).Resize(iR).Value = S1.[C10]
   .Cells(eR, 2).Resize(iR).Value = S1.[C9]
   .Cells(eR, 3).Resize(iR).Value = S1.[H3]
   .Cells(eR, 4).Resize(iR).Value = CDate(S1.[C4])
   .Cells(eR, 5).Resize(iR).Value = S1.[F8]
   .Cells(eR, 6).Resize(iR).Value = CDate(S1.[H8])
   .Cells(eR, 7).Resize(iR).Value = S1.[H4]
   .Cells(eR, 8).Resize(iR).Value = S1.[H5]
   .Cells(eR, 9).Resize(iR).Value = S1.[D8]
   .Cells(eR, 10).Resize(iR).Value = SrcRng.Offset(, 2)
   .Cells(eR, 11).Resize(iR).Value = SrcRng.Offset(, 1)
   .Cells(eR, 12).Resize(iR).Value = SrcRng.Offset(, 3)
   .Cells(eR, 13).Resize(iR).Value = SrcRng.Offset(, 6)
   .Cells(eR, 14).Resize(iR).Value = SrcRng.Offset(, 5)
   .Cells(eR, 17).Resize(iR).Value = SrcRng.Offset(, 7)
   .Cells(eR, 19).Resize(iR).Value = SrcRng.Offset(, 8)
   Union(S1.[H3], S1.[C6:C7], S1.[F8], S1.[H8], S1.[C10], S1.[A13:I42]).ClearContents
Sub CapNhat()
  With S4
Trước tiên cám ơn anh @ndu96081631 nhiều! Em sửa lại của anh một chút thế này mới được ah:
   .Cells(eR, 10).Resize(iR).Value = SrcRng.Offset(, 2).Resize(, 1).Value
   .Cells(eR, 11).Resize(iR).Value = SrcRng.Offset(, 1).Resize(, 1).Value
   .Cells(eR, 12).Resize(iR).Value = SrcRng.Offset(, 3).Resize(, 1).Value
   .Cells(eR, 13).Resize(iR).Value = SrcRng.Offset(, 6).Resize(, 1).Value
   .Cells(eR, 14).Resize(iR).Value = SrcRng.Offset(, 5).Resize(, 1).Value
   .Cells(eR, 15).Resize(iR).Value = SrcRng.Offset(, 7).Resize(, 1).Value
   .Cells(eR, 18).Resize(iR).Value = SrcRng.Offset(, 8).Resize(, 1).Value
   .Cells(eR, 19).Resize(iR).Value = SrcRng.Offset(, 9).Resize(, 1).Value
Giờ thì tốt rùi!
Giờ thì tốt rùi!
SrcRng là vùng chỉ có 1 cột, vậy cần quái gì Resize(, 1) cho nó thừa (không Resize thì nó vẫn là 1 cột rồi)
Nhưng sao em copy code đó vào thì nó không cập nhật hết được sang Sheet Dulieu? cụ thể là chỉ cập nhật thông tin đến cột 9 thui.
Thì bạn cứ thử bỏ Resize(,1) đi xem thế nào! Chừa lại vầy thôi:
.Cells(eR, 10).Resize(iR).Value = SrcRng.Offset(, 2).Value
.Cells(eR, 11).Resize(iR).Value = SrcRng.Offset(, 1).Value
.Cells(eR, 12).Resize(iR).Value = SrcRng.Offset(, 3).Value
.Cells(eR, 13).Resize(iR).Value = SrcRng.Offset(, 6).Value
.Cells(eR, 14).Resize(iR).Value = SrcRng.Offset(, 5).Value
.Cells(eR, 15).Resize(iR).Value = SrcRng.Offset(, 7).Value
.Cells(eR, 18).Resize(iR).Value = SrcRng.Offset(, 8).Value
.Cells(eR, 19).Resize(iR).Value = SrcRng.Offset(, 9).Value
Em gửi file lên anh coi xem nhé!
Tôi kêu sửa 1 đàng bạn sửa 1 nẻo
Tôi nói sửa thành:
.Cells(eR, 10).Resize(iR).Value = SrcRng.Offset(, 2)[COLOR=red][B].Value[/B][/COLOR]
.Cells(eR, 11).Resize(iR).Value = SrcRng.Offset(, 1)[COLOR=red][B].Value[/B][/COLOR]
.Cells(eR, 12).Resize(iR).Value = SrcRng.Offset(, 3)[COLOR=red][B].Value[/B][/COLOR]
.Cells(eR, 13).Resize(iR).Value = SrcRng.Offset(, 6)[COLOR=red][B].Value[/B][/COLOR]
.Cells(eR, 14).Resize(iR).Value = SrcRng.Offset(, 5).[COLOR=red][B]Value[/B][/COLOR]
.Cells(eR, 17).Resize(iR).Value = SrcRng.Offset(, 7)[COLOR=red][B].Value[/B][/COLOR]
.Cells(eR, 19).Resize(iR).Value = SrcRng.Offset(, 8)[COLOR=red][B].Value[/B][/COLOR]
Của bạn đâu có cái "đuôi" màu đỏ như ở trên
Chao sư phụ ndu...!
sư phụ giải thích dùm em ý nghĩa của RESIZE này nhé. Em thấy nó mà chẳng hiệu công dụng là gì cả.
Thanks
Resize dùng để thay đổi kích thước của 1 vùng thôi
Ví dụ ta có vùng A1:A10, nếu Resize thế này
Range("A1:A10").Resize(5,3)
Tức thay đổi kích thước vùng A1:A10 thành 5 dòng, 3 cột ---> Trở thành A1:C5
