Nhờ xem giúp file: Sửa công thức và chèn dòng thì bị lỗi code VBA (2 người xem)
  • Thread starter Thread starter 790312
790312
Trong 1 file tính excel khi mình sửa 1 vài công thức thi save lại không được và đoạn code trong file này cũng bị lỗi luôn.
đoạn code này là:
'Start of Interpolation for 2 or 1 dimension, named Interpolation
Private Function SlopeValue(ByVal RangeUpper, RangeLower, RowUpper, RowLower As Double) As Double
SlopeValue = (RangeUpper - RangeLower) / (RowUpper - RowLower)
Private Function InterValue(ByVal RangeLower, RowValue, RowSmaller, Slope As Double) As Double
InterValue = RangeLower + (RowValue - RowSmaller) * Slope
Function Interpolation(ByVal RowValue, ByVal ColValue, Rng As Range) As Double
Dim i As Long, j As Long
Dim Slope As Double
Dim Inter, Inter1, Inter2 As Double
Dim Rows, Columns As Long
Dim CheckValue As Double
'Specify the  number of columns and rows of the range data
Columns = Rng.Columns.Count
Rows = Rng.Rows.Count
'In case, the column value is less than the minimum of range column value
If ColValue <= Rng(1, 2) Then
    If RowValue <= Rng(2, 1) Then
        Inter = Rng(2, 2)
    ElseIf RowValue >= Rng(Rows, 1) Then
        Inter = Rng(Rows, 2)
        For i = 1 To Rows - 1
            If RowValue = Rng(i, 1) Then Inter = Rng(i, 2)
            CheckValue = (RowValue - Rng(i, 1)) * (RowValue - Rng(i + 1, 1))
            If CheckValue < 0 Then
                Slope = SlopeValue(Rng(i + 1, 2), Rng(i, 2), Rng(i + 1, 1), Rng(i, 1))
                Inter = InterValue(Rng(i, 2), RowValue, Rng(i, 1), Slope)
'In case, the column value is more than the maximun of range column value
ElseIf ColValue >= Rng(1, Columns) Then
        Inter = Rng(2, Columns)
        Inter = Rng(Rows, Columns)
            If RowValue = Rng(i, 1) Then Inter = Rng(i, Columns)
                Slope = SlopeValue(Rng(i + 1, Columns), Rng(i, Columns), Rng(i + 1, 1), Rng(i, 1))
                Inter = InterValue(Rng(i, Columns), RowValue, Rng(i, 1), Slope)
'In case, the column value is in the range column value
    For j = 1 To Columns - 1
        If ColValue = Rng(1, j) Then
                Inter = Rng(2, j)
                Inter = Rng(Rows, j)
                    If RowValue = Rng(i, 1) Then Inter = Rng(i, j)
                        Slope = SlopeValue(Rng(i + 1, j), Rng(i, j), Rng(i + 1, 1), Rng(i, 1))
                        Inter = InterValue(Rng(i, j), RowValue, Rng(i, 1), Slope)
        ElseIf (ColValue - Rng(1, j)) * (ColValue - Rng(1, j + 1)) < 0 Then
                Slope = SlopeValue(Rng(2, j + 1), Rng(2, j), Rng(1, j + 1), Rng(1, j))
                Inter = InterValue(Rng(2, j), ColValue, Rng(1, j), Slope)
                Slope = SlopeValue(Rng(Rows, j + 1), Rng(Rows, j), Rng(1, j + 1), Rng(1, j))
                Inter = InterValue(Rng(Rows, j), ColValue, Rng(1, j), Slope)
                    Slope = SlopeValue(Rng(i, j + 1), Rng(i, j), Rng(1, j + 1), Rng(1, j))
                    Inter = InterValue(Rng(i, j), ColValue, Rng(1, j), Slope)
                    Inter1 = InterValue(Rng(i, j), ColValue, Rng(1, j), Slope)
                    Slope = SlopeValue(Rng(i + 1, j + 1), Rng(i + 1, j), Rng(1, j + 1), Rng(1, j))
                    Inter2 = InterValue(Rng(i + 1, j), ColValue, Rng(1, j), Slope)
                    Slope = SlopeValue(Inter2, Inter1, Rng(i + 1, 1), Rng(i, 1))
                    Inter = InterValue(Inter1, RowValue, Rng(i, 1), Slope)
'Passing the Interpolation's function value
Interpolation = Inter
Mong các bác xem đoạn code này có cài lỗi gì để không save được không?Chân thành cảm ơn nhiều.
(Chú ý: lần sau khi đưa các đoạn code vào bạn nhớ đưa vào [ code]đoạn mã của bạn[ /code] nha)
Đưa file lên đây để test cho dể bạn ơi! Nhìn 1 đóng code, dù không làm biếng cũng khó mà làm.. siêng được!
Đây là 2 file.file gốc và file đã xoá nhữnng NAME lỗi.Sau khi xoá những Name lỗi ta chèn 1 vài dòng vào để lập thêm công thức tính thì bị lỗi không save được.Bạn xem giúp mình với.Thanks
Cụ thể là chèn dòng chổ nào? lập công thức gì?
Chứ file này tôi chèn dòng hay gõ công thức vào rồi save lại bình thường ---> Không lổi gì cả
Còn nữa: Câu thông báo lổi bạn nhìn thấy nó ghi cái gì?
mới sửa xong thì save được,nhưng sau vài lần thì không được.công thức thì đơn giản ô này bằng ô kia cộng ô nọ thôi.mình up file này lên hiện thông báo và vị trí mình chèn.Cảm ơn bạn nhiều.
đoạn code này là:
'Start of Interpolation for 2 or 1 dimension, named Interpolation'
  Dim i As Long, j As Long, Rows, Columns As Long
  Dim Slope As Double,  Inter, Inter1, Inter2 As Double, CheckValue As Double
'Specify the  number of columns and rows of the range data'
'In case, the column value is less than the minimum of range column value'
                Inter = Rng(2, 2)
'In case, the column value is more than the maximun of range column value'
'In case, the column value is in the range column value'
                   Inter = Rng(2, j)
'Passing the Interpolation's function value'
Lần sau bạn tự làm vậy đó nha, mới mong có người ngó ngàng tới & chú ý hơn về tiêu đề!
Bác ndu96081631 không giúp được e sao?
Tôi không nghĩ ra được bất cứ lổi gì có thể xuất hiện trên file của bạn cả! (vì trên máy tính của tôi, file này chạy bình thường) ---> Vậy hãy thí nghiệm bằng cách:
- Mang file sang chạy trên máy tính khác
- Tìm hiểu xem liệu có chương trình nào đang cài trên máy tính của bạn làm ảnh hưởng đến file này hay không (chẳng hạn các chương trình diệt virus)
