Module thao tác với form. (2 người xem)
levanduyet
Hãy để gió cuốn đi.
Tôi xin giới thiệu module để thao tác với form khi các bạn cần dùng trong VBA. Với module này đôi khi cũng giúp ích các bạn nhiều trong một vài trường hợp:
'* MODULE NAME:     SIZEABLE USERFORM
'* AUTHOR:          TIM CLEM
'*                  STEPHEN BULLEN, Business Modelling Solutions Ltd.
'* CONTACT:         Stephen@BMSLtd.co.uk
'* WEB SITE:        http://www.BMSLtd.co.uk
'* DESCRIPTION:     Makes a userform resizeable and reacts to the form being resized
'* THIS MODULE:     Changes the userform's styles so it can be resized/maximised/minimized.
'*                  The code was initially created by Tim Clem, and expanded by Stephen Bullen
'* PROCEDURES:
'*  UserForm_Activate    Instantiates a class module to make the form sizeable
'*  UserForm_Resize      Sizes and positions the controls on the form when resized
'*  btnOK_Click          Closes the form when the OK button is clicked
'Windows API calls to do all the dirty work!
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Private Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hWnd As Long, ByVal nIndex As Long) As Long
Private Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hWnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Private Declare Function GetSystemMenu Lib "user32" (ByVal hWnd As Long, ByVal bRevert As Long) As Long
Private Declare Function DeleteMenu Lib "user32" (ByVal hMenu As Long, ByVal nPosition As Long, ByVal wFlags As Long) As Long
Private Declare Function ShowWindow Lib "user32" (ByVal hWnd As Long, ByVal nCmdShow As Long) As Long
Private Declare Function EnableWindow Lib "user32" (ByVal hWnd As Long, ByVal fEnable As Long) As Long
Private Declare Function DrawMenuBar Lib "user32" (ByVal hWnd As Long) As Long
Private Declare Function SetFocus Lib "user32" (ByVal hWnd As Long) As Long
Private Declare Function ExtractIcon Lib "shell32.dll" Alias "ExtractIconA" (ByVal hInst As Long, ByVal lpszExeFileName As String, ByVal nIconIndex As Long) As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, ByVal wMsg As Long, ByVal wParam As Integer, ByVal lParam As Long) As Long
'Lots of window styles for us to play with!
Private Const GWL_STYLE As Long = (-16)           'The offset of a window's style
Private Const GWL_EXSTYLE As Long = (-20)         'The offset of a window's extended style
Private Const WS_CAPTION As Long = &HC00000       'Style to add a titlebar
Private Const WS_SYSMENU As Long = &H80000        'Style to add a system menu
Private Const WS_THICKFRAME As Long = &H40000     'Style to add a sizable frame
Private Const WS_MINIMIZEBOX As Long = &H20000    'Style to add a Minimize box on the title bar
Private Const WS_MAXIMIZEBOX As Long = &H10000    'Style to add a Maximize box to the title bar
Private Const WS_POPUP As Long = &H80000000       'Standard option, cleared when showing a task bar icon
Private Const WS_VISIBLE As Long = &H10000000     'Standard option, cleared when showing a task bar icon
Private Const WS_EX_DLGMODALFRAME As Long = &H1   'Controls if the window has an icon
Private Const WS_EX_APPWINDOW As Long = &H40000   'Application Window: shown on taskbar
Private Const WS_EX_TOOLWINDOW As Long = &H80     'Tool Window: small titlebar
'Constant to identify the Close menu item
Private Const SC_CLOSE As Long = &HF060
'Constants for hide or show a window
Private Const SW_HIDE As Long = 0
Private Const SW_SHOW As Long = 5
'Constants for Windows messages
Private Const WM_SETICON = &H80
'Variables to store the various selections/options
Dim hWndForm As Long, mbSizeable As Boolean, mbCaption As Boolean, mbIcon As Boolean, miModal As Integer
Dim mbMaximize As Boolean, mbMinimize As Boolean, mbSysMenu As Boolean, mbCloseBtn As Boolean
Dim mbAppWindow As Boolean, mbToolWindow As Boolean, msIconPath As String
Dim moForm As Object
Public Property Set Form(oForm As Object)
    'Get the userform's window handle
    If Val(Application.Version) < 9 Then
        hWndForm = FindWindow("ThunderXFrame", oForm.Caption)  'XL97
        hWndForm = FindWindow("ThunderDFrame", oForm.Caption)  'XL2000
    'Remember the form for later
    Set moForm = oForm
    'Set the form's style
    SetFormStyle
    'Update the form's icon
    ChangeIcon
End Property
'Property procedure to get and set the form's window styles
Public Property Let Sizeable(bSizeable As Boolean)
    mbSizeable = bSizeable
    SetFormStyle
End Property
Public Property Get Sizeable() As Boolean
    Sizeable = mbSizeable
End Property
Public Property Let ShowCaption(bCaption As Boolean)
    mbCaption = bCaption
    SetFormStyle
End Property
Public Property Get ShowCaption() As Boolean
    ShowCaption = mbCaption
End Property
Public Property Let Modal(bModal As Boolean)
    miModal = Abs(CInt(Not bModal))
    'Make the form modal or modeless by enabling/disabling Excel itself
    EnableWindow FindWindow("XLMAIN", Application.Caption), miModal
End Property
Public Property Get Modal() As Boolean
    Modal = (miModal <> 1)
End Property
Public Property Let ShowIcon(bIcon As Boolean)
    mbIcon = Not bIcon
    ChangeIcon
    SetFormStyle
End Property
Public Property Get ShowIcon() As Boolean
    ShowIcon = (mbIcon <> 1)
End Property
Public Property Let IconPath(sNewPath As String)
    msIconPath = sNewPath
    ChangeIcon
End Property
Public Property Get IconPath() As String
    IconPath = msIconPath
End Property
Public Property Let ShowMaximizeBtn(bMaximize As Boolean)
    mbMaximize = bMaximize
    SetFormStyle
End Property
Public Property Get ShowMaximizeBtn() As Boolean
    ShowMaximizeBtn = mbMaximize
End Property
Public Property Let ShowMinimizeBtn(bMinimize As Boolean)
    mbMinimize = bMinimize
    SetFormStyle
End Property
Public Property Get ShowMinimizeBtn() As Boolean
    ShowMinimizeBtn = mbMinimize
End Property
Public Property Let ShowSysMenu(bSysMenu As Boolean)
    mbSysMenu = bSysMenu
    SetFormStyle
End Property
Public Property Get ShowSysMenu() As Boolean
    ShowSysMenu = mbSysMenu
End Property
Public Property Let ShowCloseBtn(bCloseBtn As Boolean)
    mbCloseBtn = bCloseBtn
    SetFormStyle
End Property
Public Property Get ShowCloseBtn() As Boolean
    ShowCloseBtn = mbCloseBtn
End Property
Public Property Let ShowTaskBarIcon(bAppWindow As Boolean)
    'If changing from showing an icon to not showing it, hide the window to remove the icon
    If hWndForm <> 0 And mbAppWindow And Not bAppWindow Then
        'Enable the Excel window, so we don't lose focus
        EnableWindow FindWindow("XLMAIN", Application.Caption), True
        ShowWindow hWndForm, SW_HIDE
    mbAppWindow = bAppWindow
    SetFormStyle
    'Repaint the userform, to ensure everything is updated correctly
    moForm.Repaint
    'Set the Excel window's enablement to the correct choice
End Property
Public Property Get ShowTaskBarIcon() As Boolean
    ShowTaskBarIcon = mbAppWindow
End Property
Public Property Let SmallCaption(bToolWindow As Boolean)
    mbToolWindow = bToolWindow
    SetFormStyle
End Property
Public Property Get SmallCaption() As Boolean
    SmallCaption = mbToolWindow
End Property
Lê Văn Duyệt
Phần tiếp theo
Phần tiếp theo
'Routine to set the form's window style
Private Sub SetFormStyle()
    Dim iStyle As Long, hMenu As Long, hID As Long, iItems As Integer
    'Have we got a form to set?
    If hWndForm = 0 Then Exit Sub
    iStyle = GetWindowLong(hWndForm, GWL_STYLE)
    'Build up the basic window style flags for the form
    If mbCaption Then iStyle = iStyle Or WS_CAPTION Else iStyle = iStyle And Not WS_CAPTION
    If mbSysMenu Then iStyle = iStyle Or WS_SYSMENU Else iStyle = iStyle And Not WS_SYSMENU
    If mbSizeable Then iStyle = iStyle Or WS_THICKFRAME Else iStyle = iStyle And Not WS_THICKFRAME
    If mbMinimize Then iStyle = iStyle Or WS_MINIMIZEBOX Else iStyle = iStyle And Not WS_MINIMIZEBOX
    If mbMaximize Then iStyle = iStyle Or WS_MAXIMIZEBOX Else iStyle = iStyle And Not WS_MAXIMIZEBOX
    If mbAppWindow Then iStyle = iStyle And Not WS_VISIBLE And Not WS_POPUP Else iStyle = iStyle Or WS_VISIBLE Or WS_POPUP
    'Set the basic window styles
    SetWindowLong hWndForm, GWL_STYLE, iStyle
    iStyle = GetWindowLong(hWndForm, GWL_EXSTYLE)
    'Build up and set the extended window style
    If mbIcon Then iStyle = iStyle Or WS_EX_DLGMODALFRAME Else iStyle = iStyle And Not WS_EX_DLGMODALFRAME
    If mbAppWindow Then iStyle = iStyle Or WS_EX_APPWINDOW Else iStyle = iStyle And Not WS_EX_APPWINDOW
    If mbToolWindow Then iStyle = iStyle Or WS_EX_TOOLWINDOW Else iStyle = iStyle And Not WS_EX_TOOLWINDOW
    SetWindowLong hWndForm, GWL_EXSTYLE, iStyle
    'Handle the close button differently
    If mbCloseBtn Then
        'We want it, so reset the control menu
        hMenu = GetSystemMenu(hWndForm, 1)
        'We don't want it, so delete it from the control menu
        hMenu = GetSystemMenu(hWndForm, 0)
        DeleteMenu hMenu, SC_CLOSE, 0&
    'Show the window with the changes
    ShowWindow hWndForm, SW_SHOW
    DrawMenuBar hWndForm
    SetFocus hWndForm
Private Sub ChangeIcon()
    Dim hIcon As Long
    If hWndForm <> 0 Then
        Err.Clear
        If msIconPath = "" Then
            hIcon = 0
        ElseIf Dir(msIconPath) = "" Then
            hIcon = 0
        ElseIf Err.Number <> 0 Then
            hIcon = 0
        ElseIf Not mbIcon Then
            'Get the icon from the source
            hIcon = ExtractIcon(0, msIconPath, 0)
            hIcon = 0
        'Set the big (32x32) and small (16x16) icons
        SendMessage hWndForm, WM_SETICON, True, hIcon
        SendMessage hWndForm, WM_SETICON, False, hIcon
Lê Văn Duyệt
Cám ơn bác. Nếu có thể bác giải thích thêm một số thông số đặc biệt để mọi người biết.
Ai có thể cho mình biết đoạn code trên dùng để làm gì không? cảm ơn nhiều !
