Thử nghiệm vbcode highlight=vb (1 người xem)
OverAC
Đỗ Nguyên Bình
Thành viên BQT
Administrator
[noparse][highlight=vb]...[/highlight][/noparse]
So sánh với [noparse]
[/noparse]
[highlight=vb]Option Explicit
Dim endR As Long, SoDong As Long, iSh As Long, eRow As Long
Dim Sh As Worksheet, WsName As String, iR As Long, rngData As Range
Sub GanTmpNhap()
With Application
.DisplayAlerts = False: .ScreenUpdating = False: .Calculation = xlCalculationManual
Sheets("TongHop").Select
[A6:F65000].ClearContents
With Sheets("TMP")
endR = .[A65000].End(xlUp).Row
'Set rngData = .Range("C1:C" & endR)
'rngData.SpecialCells(xlCellTypeBlanks).EntireRow.Delete
'endR = .[A65000].End(xlUp).Row
Set rngData = .Range("A1:A" & endR)
With rngData
.AdvancedFilter Action:=xlFilterCopy, CopyToRange:=Range( _
"A5"), Unique:=True
.Range("A1:C" & endR).Name = "rngData"
.Range("D2:D" & endR).Name = "rngSL"
.Range("A2:A" & endR).Name = "rngMaHH"
Range("Extract").ClearContents: Names("Extract").Delete
endR = [A6].End(xlDown).Row
With Application
.Calculation = xlCalculationAutomatic
With Range(Cells(6, 2), Cells(endR, 2))
.FormulaR1C1 = "=vlookup(RC1,rngData,2,0)"
.Offset(, 1).FormulaR1C1 = "=vlookup(RC1,rngData,3,0)"
With Range(Cells(6, 2), Cells(endR, 3))
.Value = .Value
Names("rngData").Delete
TaoSLNhap
With Application
.DisplayAlerts = True: .ScreenUpdating = True
Sub TaoSLNhap()
Range(Cells(6, 4), Cells(endR, 4)).FormulaR1C1 = "=SUMIF(rngMaHH,RC[-3],rngSL)"
Range(Cells(6, 2), Cells(endR, 4)).Value = Range(Cells(6, 2), Cells(endR, 4)).Value
Names("rngSL").Delete: Names("rngMaHH").Delete
Set rngData = Nothing
With Sheets("TMP")
.[A2:N65000].ClearContents
[/highlight]
Sub GanTmpNhap()
With Application
With Sheets("TMP")
    With rngData
        "A5"), Unique:=True
With Application
    .Value = .Value
TaoSLNhap
With Application
Sub TaoSLNhap()
With Sheets("TMP")
Sub GanTmpNhap()
With Application
With Sheets("TMP")
    With rngData
        "A5"), Unique:=True
With Application
    .Value = .Value
TaoSLNhap
With Application
Sub TaoSLNhap()
With Sheets("TMP")
Bình ơi, cái vb code đúng tốt đấy, nhưng màu chưa đúng, nên để các từ khóa của CB là màu xanh còn các giá trị khác để màu đẹn Tám lại chỉ nên để 3 màu:
+ Từ khóa
+ Giá trị
+ Comment
[COLOR="Blue"]Sub[/COLOR] DoYourMacto()
[COLOR="Green"]    'If Your Macto is running then exit sub[/COLOR]
   [COLOR="Blue"] If[/COLOR] IsRunning [COLOR="Blue"]Then[/COLOR]
[COLOR="Blue"]        Exit Sub
End Sub[/COLOR]
Điểm đáng chú ý:
1. highlight làm nổi bật những từ thuộc mặc định trong VB
2. Những dấu nháy đơn ' gần nhau sẽ được hiểu đúng là bắt đầu của một ghi chú (comment) chứ không phải bắt đầu của một đoạn text
3. highlight không phải là một vbcode chính thống của VBB nên nó dể bị làm mất đi những dấu khoảng trắng đầu dòng. (lỗi này sẽ xem xét khắc phục)
code ban đầu
highlight
[/highlight]
php
thử cái đã
[highlight=vb]
Sub GanTmpNhap()
With Application
With Sheets("TMP")
'rngData.SpecialCells(xlCellTypeBlanks).EntireRow. Delete
With rngData
"A5"), Unique:=True
With Application
.Value = .Value
TaoSLNhap
With Application
Sub TaoSLNhap()
With Sheets("TMP")
End Sub[/color]
[/highlight]
code này đúng là làm nổi bật vị trí :
Từ khóa
Giá trị
Comment
Đã đổi lại màu highlight
+ Từ khóa
+ Giá trị
+ Comment
[COLOR=Blue]Sub[/COLOR] DoYourMacto()
[COLOR=Green]    'If Your Macto is running then exit sub[/COLOR]
   [COLOR=Blue] If[/COLOR] IsRunning [COLOR=Blue]Then[/COLOR]
[COLOR=Blue]        Exit Sub
End Sub[/COLOR]
[highlight=VB]
Sub GanTmpNhap()
With Application
With Sheets("TMP")
With rngData
"A5"), Unique:=True
With Application
.Value = .Value
TaoSLNhap
With Application
Sub TaoSLNhap()
With Sheets("TMP")
[/highlight]
Không biết mình có thể đặt tên lại cho Tag VB code hay không? Nếu được chúng ta nên đặt tên là Tag GPE.
[GPE]
[/GPE]
Như vậy sẽ dễ nhớ và hay hơn.
Vbavn
Phong ơi, Name không phải là từ khoa.
Nếu có thể chúng ta để màu xanh đen dễ nhìn và giống với format chuẩn của VB hợn
@anh vbavn: Nếu sửa được thì em nghĩ là nên sửa thành VBA chứ GPE thì không đặc trưng.
@anh Tuanvnuni: Những từ như Name, End được ghi nhận như một từ khóa, do vậy hể gặp là tô đậm chứ code này không biệt được .Name khác Name.End khác End, vậy thì sửa sẽ càng tốn nhiều thời gian hơn (chưa kể làm không được do những hạn chế khác)
Name hay .Name đều là đối tượng ứng dụng thôi chứ không phải là từ khóa trong VB/VBA, nên Name cần để màu đen Bình à. Anh không biết mã nguồn này trên Web như thế nào, như ở lập trình ứng dụng anh chỉ cần xóa nó khỏi danh sách các từ khóa là xong.
Đây là mà nguồn mở, của tác giả Roberto Rossi (rsoftware@altervista.org) (http://qbnz.com/highlighter)
Tác giả liệt kê Name như là từ khoá:
 $language_data = array (
    'LANG_NAME' => 'Visual Basic for Application',
    'COMMENT_SINGLE' => array(1 => "'"),
    'COMMENT_MULTI' => array(),
    'CASE_KEYWORDS' => GESHI_CAPS_NO_CHANGE,
    'QUOTEMARKS' => array('"'),
    'ESCAPE_CHAR' => '',
    'KEYWORDS' => array(
        1 => array(
            'as', 'err', 'boolean', 'and', 'or', 'recordset', 'unload', 'to',
            'integer','long','single','new','database','nothing','set','close',
            'open','print','split','line','field','querydef','instrrev',
            'abs','array','asc','ascb','ascw','atn','avg','me',
            'cbool','cbyte','ccur','cdate','cdbl','cdec','choose','chr','chrb','chrw','cint','clng',
            'command','cos','count','createobject','csng','cstr','curdir','cvar','cvdate','cverr',
            'date','dateadd','datediff','datepart','dateserial','datevalue','day','ddb','dir','doevents',
            'environ','eof','error','exp',
            'fileattr','filedatetime','filelen','fix','format','freefile','fv',
            'getallstrings','getattr','getautoserversettings','getobject','getsetting',
            'hex','hour','iif','imestatus','input','inputb','inputbox','instr','instb','int','ipmt',
            'isarray','isdate','isempty','iserror','ismissing','isnull','isnumeric','isobject',
            'lbound','lcase','left','leftb','len','lenb','loadpicture','loc','lof','log','ltrim',
            'max','mid','midb','min','minute','mirr','month','msgbox',
            'now','nper','npv','oct','partition','pmt','ppmt','pv','qbcolor',
            'rate','rgb','right','rightb','rnd','rtrim',
            'second','seek','sgn','shell','sin','sln','space','spc','sqr','stdev','stdevp','str',
            'strcomp','strconv','string','switch','sum','syd',
            'tab','tan','time','timer','timeserial','timevalue','trim','typename',
            'ubound','ucase','val','var','varp','vartype','weekday','year',
            'appactivate','base','beep','call','case','chdir','chdrive','const',
            'declare','defbool','defbyte','defcur','defdate','defdbl','defdec','defint',
            'deflng','defobj','defsng','defstr','deftype','defvar','deletesetting','dim','do',
            'else','elseif','end','enum','erase','event','exit','explicit',
            'false','filecopy','for','foreach','friend','function','get','gosub','goto',
            'if','implements','kill','let','lineinput','lock','loop','lset','mkdir','name','next','not',
            'onerror','on','option','private','property','public','put','raiseevent','randomize',
            'redim','rem','reset','resume','return','rmdir','rset',
            'savepicture','savesetting','sendkeys','setattr','static','sub',
            'then','true','type','unlock','wend','while','width','with','write',
            'vbabort','vbabortretryignore','vbapplicationmodal','vbarray',
            'vbbinarycompare','vbblack','vbblue','vbboolean','vbbyte','vbcancel',
            'vbcr','vbcritical','vbcrlf','vbcurrency','vbcyan','vbdataobject',
            'vbdate','vbdecimal','vbdefaultbutton1','vbdefaultbutton2',
            'vbdefaultbutton3','vbdefaultbutton4','vbdouble','vbempty',
            'vberror','vbexclamation','vbfirstfourdays','vbfirstfullweek',
            'vbfirstjan1','vbformfeed','vbfriday','vbgeneraldate','vbgreen',
            'vbignore','vbinformation','vbinteger','vblf','vblong','vblongdate',
            'vblongtime','vbmagenta','vbmonday','vbnewline','vbno','vbnull',
            'vbnullchar','vbnullstring','vbobject','vbobjecterror','vbok','vbokcancel',
            'vbokonly','vbquestion','vbred','vbretry','vbretrycancel','vbsaturday',
            'vbshortdate','vbshorttime','vbsingle','vbstring','vbsunday',
            'vbsystemmodal','vbtab','vbtextcompare','vbthursday','vbtuesday',
            'vbusesystem','vbusesystemdayofweek','vbvariant','vbverticaltab',
            'vbwednesday','vbwhite','vbyellow','vbyes','vbyesno','vbyesnocancel',
            'vbnormal','vbdirectory'
    'SYMBOLS' => array(
    'CASE_SENSITIVE' => array(
        GESHI_COMMENTS => false,
        1 => false
    'STYLES' => array(
            1 => 'color: #b1b100;'
        'COMMENTS' => array(
            1 => 'color: #808080;'
        'BRACKETS' => array(
            0 => 'color: #66cc66;'
        'STRINGS' => array(
            0 => 'color: #ff0000;'
        'NUMBERS' => array(
            0 => 'color: #cc66cc;'
        'METHODS' => array(
        'SYMBOLS' => array(
        'ESCAPE_CHAR' => array(
            0 => 'color: #000099;'
        'SCRIPT' => array(
        'REGEXPS' => array(
    'OOLANG' => true,
    'OBJECT_SPLITTERS' => array(
        1 => '.'
    'REGEXPS' => array(
    'STRICT_MODE_APPLIES' => GESHI_NEVER,
    'SCRIPT_DELIMITERS' => array(
    'HIGHLIGHT_STRICT_BLOCK' => array(
Tác giả không có tách riêng phần highlight cho VBA nên mình dùng VB để thay. Nếu sau khi bỏ bớt các từ khoá thì mình có thể rename thành VBA cũng được.
Về màu sắc thì tuỳ chỉnh rất đa dạng (xem code trên) thích màu nào thì chỉ cần nhập mã màu (HEX) vào.
Thanh Phong
[highlight=vb]Private Sub Worksheet_Change(ByVal Target As Range)
Dim strVal As String
Dim strEntry As String
strVal = Target.Validation.Formula1
If Not strVal = vbNullString Then
strEntry = Target
With Sheet1.Range("MyList")
.Replace What:=strEntry, _
Replacement:="", LookAt:=xlWhole, _
SearchOrder:=xlByRows, MatchCase:=False
.Sort Key1:=.Range("A1"), Order1:=xlAscending, _
Header:=xlNo, OrderCustom:=1, MatchCase:=False, _
Orientation:=xlTopToBottom
.Range("A1", .Range("A65536").End(xlUp)).Name = "MyList"
On Error GoTo 0
End Sub[/highlight]
A Tool pro có virus
Chào TuanVNUNI
Máy của tôi cài trình diệt virus ESS NOD32. khi toi chạy chương trinh A Tool . . . thì bị báo có Virus và nó diệt luôn. Mong TuanVNUNI kiểm tra lại chương trình A Tool có bị nhiễm virus không nhé.
Phong ơi,
Vậy mình có thể tích hợp vào diễn đàn cái vụ này được không?
Tks,
Lê Văn Duyệt
