6hoangcickg
Sub Get_ETABS_Data()
Dim etabsApp As Object, SapModel As Object
Set etabsApp = CreateObject("CSI.ETABS.API.ETABSObject")
Set SapModel = etabsApp.SapModel
On Error GoTo ErrHandler
etabsApp.ApplicationStart
SapModel.File.OpenFile "C:\Project\Model.edb"
' Setup nội lực
SapModel.Results.Setup.DeselectAllCasesAndCombosForOutput
SapModel.Results.Setup.SetCaseSelectedForOutput "COMB1", True
' Lấy nội lực tại điểm
Dim NumberResults As Long, Obj() As String, Elm() As String
Dim StepType() As String, StepNum() As Double, F1() As Double
SapModel.Results.FrameForce "B1", 0, NumberResults, Obj, Elm, StepType, StepNum, F1
' Đổ dữ liệu ra Excel
For i = 0 To NumberResults - 1
Sheets("Input").Cells(i + 2, 1).Value = Obj(i)
Sheets("Input").Cells(i + 2, 2).Value = F1(i)
MsgBox "Lấy nội lực xong!"
Exit Sub
ErrHandler:
MsgBox "Lỗi khi kết nối ETABS!"
' Setup nội lực
Exit Sub
ErrHandler:
