cách tạo bản quyền cho file excel bằng Regedit (1 người xem)
Có
Minh Tam 2024
Code nguồn trên mạng . Mọi người xem có khả thi không
Function CheckRegistry(ByVal Paths$, ByVal Entry$) As Boolean
'Haøm kieåm tra Registry coù toàn taïi
'[Paths]: Thö muïc chöùa - [Entry]: Teân thuoäc tính
Dim Obj, Fullpaths$
Fullpaths = "HKCC\ABCExcel\" & Paths & "\" & Entry
Set Obj = CreateObject("WScript.Shell")
Entry = Obj.RegRead(Fullpaths)
    If err.Number <> 0 Then
        err.Clear
        CheckRegistry = False
        err.Clear
        CheckRegistry = True
Function GetRegistry(ByVal Paths$, ByVal Entry$)
'Haøm laáy giaù trò Registry
Dim Obj, Fullpaths$
    GetRegistry = Obj.RegRead(Fullpaths)
Public Sub WriteRegistry(ByVal Paths$, ByVal Entry$, ByVal values$)
'Taïo môùi hoaëc tuøy chænh giaù trò Registry
Dim Obj, Fullpaths$
    Obj.RegWrite Fullpaths, values, "REG_SZ"
Private Function Encod(ByVal txt$) As Long
'Thuaät toaùn maõ hoùa
    Dim xVal As Long
    Dim xCh As Long
    Dim xSft1 As Long
    Dim xSft2 As Long
    Dim i%
    Dim xLen%
    xLen = Len(txt)
    For i = 1 To xLen
        xCh = Asc(Mid$(txt, i, 1))
        xVal = xVal Xor (xCh * 2 ^ xSft1)
        xVal = xVal Xor (xCh * 2 ^ xSft2)
        xSft1 = (xSft1 + 7) Mod 19
        xSft2 = (xSft2 + 13) Mod 23
    Encod = xVal
Function OpenKey(ByVal Psd$, ByVal InTxt$, Optional ByVal Enc As Boolean = True) As String
'Haøm maõ hoùa license
Dim xOffset!, xLen%, i%, xCh%, xOutTxt$
    xOffset = Encod(ReverseText(Psd) & "TafExcel")
    Rnd -1
    Randomize xOffset
    xLen = Len(InTxt)
    For i = 1 To xLen
        xCh = Asc(Mid$(InTxt, i, 1))
        If xCh >= 32 And xCh <= 126 Then
            xCh = xCh - 32
            xOffset = Int((96) * Rnd)
            If Enc Then
                xCh = ((xCh + xOffset) Mod 95)
                xCh = ((xCh - xOffset) Mod 95)
                If xCh < 0 Then xCh = xCh + 95
            xCh = xCh + 32
            xOutTxt = xOutTxt & Chr$(xCh)
    OpenKey = xOutTxt
Function HDSerialNumber() As String
'Hieån thò serial number cuûa HDD
Dim oFSO As Object
Dim drive As Object
Dim Serial As String, MyPath
    If Application.ActiveWorkbook Is Nothing Then
        Application.Workbooks.Add
    MyPath = Environ("SystemDrive") & Application.PathSeparator
    Set oFSO = CreateObject("Scripting.FileSystemObject")
    Set drive = oFSO.GetDrive("" & MyPath & "")
    'Maõ hoùa serial number cua HDD
    HDSerialNumber = Hex(drive.SerialNumber)
Function ProcessorInfo()
'Hieån thò thoâng tin CPU
Dim cimv2, PInfo, PItem
Dim PubStrComputer As String
    PubStrComputer = "."
    Set cimv2 = GetObject("winmgmts:\\" & PubStrComputer & "\root\cimv2")
    Set PInfo = cimv2.ExecQuery("Select * From Win32_Processor")
    For Each PItem In PInfo
        'MsgBox ("Processor: " & PItem.Name & vbCrLf & "Id: " & PItem.ProcessorId)
        ProcessorInfo = PItem.ProcessorId
    Next PItem
Function Limit(ByVal Paths$, ByVal Entry$, Optional ByVal n, Optional ByVal Limitation) As Boolean
'Giôùi haïn döõ lieäu keát hôïp kieåm tra license
'Löu yù khoâng taïo kieåu bieán cho n vaø limitation
Dim UserKey$
    UserKey = GetRegistry(Paths, Entry)
'B1. Kieåm tra license
    If OpenKey(Entry, HDSerialNumber, True) = UserKey Then
        Limit = True
        Exit Function
 'B2. Duøng thöû neáu coù
    If Not IsMissing(n) Or Not IsMissing(Limitation) Then
        If n > Limitation Then Limit = False Else Limit = True
Sub DisableLicense()
'Huûy baûn quyeàn test phaàn meàm
    Call WriteRegistry("System", "Addins", 0)
Bạn có thể giải thích chi tiết hơn đc hiong, bạn ơi?
Đường dẫn HKCC\ABCExcel là thế nào đó sếp?
Dim Obj, Fullpaths$
        err.Clear
        err.Clear
Dim Obj, Fullpaths$
Dim Obj, Fullpaths$
    Dim xVal As Long
    Dim xCh As Long
    Dim xSft1 As Long
    Dim xSft2 As Long
    Dim i%
    Dim xLen%
    xLen = Len(txt)
    For i = 1 To xLen
    Encod = xVal
    Rnd -1
    Randomize xOffset
    xLen = Len(InTxt)
    For i = 1 To xLen
            xCh = xCh - 32
            If Enc Then
            xCh = xCh + 32
    OpenKey = xOutTxt
Dim oFSO As Object
Dim drive As Object
    Next PItem
Dim UserKey$
        Limit = True
        Exit Function
mình có làm bản quyền, nhưng chọn cách kích hoạt theo thời gian thực và mã CPU của máy.
như vậy đảm bảo mã kích hoạt là duy nhất
Bạn có thể chia sẻ phương pháp trên không? có thuần VBA không bạn?
thuần VBA thôi, nhưng file đó thì không tiện chia sẻ vì nó là 1 phần mềm mình viết trên excel đang để bán cho nhiều người dùng
Cách làm :
1. tạo 1 chương trình chạy sẽ lấy mã CPU của thiết bị
2. tạo 1 chương trình tạo mã kích hoạt là ghép giữa mã CPU + thời gian hiện tại ( có thể ghép mới mã thời gian sử dụng)
3. trên file phần mềm của bạn cho chương trình khởi chạy khi mở file thì check xem file đã được nhập key hay chưa?
