Huy@@*
Dim rngCho As Range, rngNhan As Range, rngData As Range, rngDMTK As Range
Dim endR&, eRow&, eR&, iR&, iRow&, soDong&
Dim i&, j&, k&, m&, s&, t&, u&, n&
Dim DemNo&, DemCo&, Dem&, dongDau&, iCT&
Public sSoCT As String
Dim wf As WorksheetFunction, Dic As Object
Const ColTkNo = 8: Const ColTkCo = 9: Const RowEnd = 1000000
Dim Arr(), ArrNo(), ArrCo(), ArrTK(), arrCho(), arrNhan(), ArrSap(), ArrDM(), ArrSoCT()
Dim Tg
Dim ArrKQ(1 To 100, 1 To 16)
Sub TaoRng()
Set wf = WorksheetFunction
iRow = 2 'dong dau NKC
With Sheets("NKC")
.Range("A" & iRow & "
With Sheets("Tmp")
endR = .Range("A" & RowEnd).End(xlUp).Row
ArrTK = .Range(.Cells(2, 14), .Cells(u, 16)).Value
dongDau = 0
eRow = UBound(ArrTK)
For iCT = 1 To eRow
sSoCT = ArrTK(iCT, 1) 'so CT
Dem = ArrTK(iCT, 2) + ArrTK(iCT, 3) 'so lan N + C
If Dem = 0 Then GoTo exit_for
''Day la phan tinh toan cac TH, co ban la xac dinh cac vung RngCho va RngNhan'
DemNo = ArrTK(iCT, 2) 'so lan N'
DemCo = ArrTK(iCT, 3) 'so lan C'
TaoSubRng
'Truong hop nay la toan No
If DemCo = 0 Then
TinhToan07
GoTo exit_for
''Truong hop nay la toan Co
If DemNo = 0 Then
TinhToan08
GoTo exit_for
''Truong hop khac - TH nay nhieu nhat
'Truong hop nay la soct vua co No vua co Co
Select Case Dem
Case 2
''luc nay DemNo=1 va demCo =1
TinhToan01
Case Is > 2 'so record > 2
''Them 1 TH neu so TK No = So TK Co, STien No(1)=sotienco(1), SotienNo(end)=sotienco(end)
If Dem < 5 And DemNo = DemCo Then
If rngNhan(1, 9) = rngCho(1, 8) And rngNhan(DemCo, 9) = rngCho(DemNo, 8) Then
TinhToan04
GoTo exit_for
If DemNo = 1 Then 'quan he 1N nhieu C
TinhToan02
GoTo exit_for
If DemCo = 1 Then 'quan he 1C nhieu N
TinhToan03
GoTo exit_for
''quan he nhieu no nhieu co
If wf.CountIf(rngCh
''Truong hop nay la so tien No toan am
TinhToan06
GoTo exit_for
TinhToan05
GoTo exit_for
End Select
exit_for:
dongDau = dongDau + Dem
If dongDau >= endR Then Exit Sub
Next iCT
Erase ArrTK, arrCho(), arrNhan(), ArrKQ
Set rngCho = Nothing: Set rngNhan = Nothing
Sub TaoNKC()
With Application
.ScreenUpdating = False: .DisplayAlerts = False: .Calculation = xlCalculationManual: .EnableEvents = False
Tg = Timer
Sheets("NKC").Select
Sheets("NKC").AutoFilterMode = False
'Co the them 1 UDF kiem tra sh Tmp da ton tai
If SheetExists("Tmp") Then
With Sheets("Tmp")
.Cells.ClearContents
.[B1] = "SoCT" 'them tieu de
.[N1] = "SoCT": .[O1] = "DemNo": .[P1] = "DemCo": .[Q1] = "NgayHT"
'Neu chua co thi add
Sheets.Add
ActiveSheet.Name = "Tmp"
ConvertGoc2Tmp
TaoTmp
TaoRng
'GanTKVN
XuLySoCT
Sheets("Tmp").Delete
MsgBox "OK" & Chr(13) & Timer - Tg
With Application
.ScreenUpdating = True: .DisplayAlerts = True: .Calculation = xlCalculationAutomatic: .EnableEvents = True
Sub TaoSubRng()
With Sheets("Tmp")
If DemNo = 0 Then
Set rngNhan = .Cells(2 + dongDau, 2).Offset(DemNo, -1).Resize(DemCo, 13)
GoTo bien
If DemCo = 0 Then
Set rngCho = .Cells(2 + dongDau, 2).Offset(, -1).Resize(DemNo, 12)
GoTo bien
bien:
'rngCho.Select
'rngNhan.Select
arrCho = rngCho.Value: arrNhan = rngNhan.Value
Sub XuLySoCT()
Dim endR&, i&
Dim Arr(), ArrSoTT()
Dim SearchChar$, myPos&
SearchChar = ";"
With Sheets("NKC")
endR = .Cells(RowEnd, 1).End(3).Row
Arr = .Range("B2:B" & endR).Value
ReDim ArrSoTT(1 To UBound(Arr), 1 To 1)
For i = 1 To UBound(Arr)
myPos = InStr(Arr(i, 1), SearchChar)
Arr(i, 1) = Right(Arr(i, 1), Len(Arr(i, 1)) - myPos)
ArrSoTT(i, 1) = i
With Sheets("NKC")
.Range("B2:B" & endR).Value = Arr
.Range("F2:F" & endR).Value = ArrSoTT
Erase Arr, ArrSoTT
Sub GanArr()
With Sheets("NKC")
.Cells(iRow, 1).Resize(soDong, 9) = ArrKQ
iRow = iRow + soDong
Erase ArrKQ
Sub TaoTmp()
With Sheets("Tmp")
endR = .Cells(RowEnd, 2).End(xlUp).Row
Arr = .Range("A2:M" & endR + 1).Value 'them +1'
endR = UBound(Arr)
ReDim ArrNo(1 To endR, 1 To 13), ArrCo(1 To endR, 1 To 13), ArrTK(1 To endR, 1 To 4)
s = 0: t = 0: u = 1
For i = 1 To endR - 1
'Gan phan no
If Arr(i, 8) <> 0 Then 'sotien no <>0
s = s + 1
For k = 1 To 4
ArrNo(s, k) = Arr(i, k)
Next k
If Arr(i, 12) <> 0 Then
For k = 10 To 11
Next k
ArrNo(s, 12) = Arr(i, 12)
ArrNo(s, 6) = Arr(i, 12) / Arr(i, 8)
ArrNo(s, 5) = "N"
ArrNo(s, 7) = CStr(Arr(i, 7)) ' & Arr(i, 5)) SHTK & CostStr
ArrNo(s, 8) = Arr(i, 8) 'so tien
ArrTK(u, 2) = ArrTK(u, 2) + 1 ' dem so N
'Gan phan co
If Arr(i, 9) <> 0 Then 'sotien co <>0
t = t + 1
For k = 1 To 4
ArrCo(t, k) = Arr(i, k)
Next k
If Arr(i, 13) <> 0 Then
For k = 10 To 11
Next k
ArrCo(t, 13) = Arr(i, 13)
ArrCo(t, 6) = Arr(i, 13) / Arr(i, 9)
ArrCo(t, 5) = "C"
ArrCo(t, 7) = CStr(Arr(i, 7)) '& Arr(i, 5)) 'SHTK & CostStr
ArrCo(t, 9) = Arr(i, 9) 'so tien
ArrTK(u, 3) = ArrTK(u, 3) + 1 ' dem so N
'tao DM TK duy nhat voi dieu kien la soct da sort******
ArrTK(u, 1) = Arr(i, 2) 'soct
ArrTK(u, 4) = Arr(i, 1) 'NgayHT
If ArrTK(u, 1) <> Arr(i + 1, 2) Then u = u + 1
'co nen gan bien dem vao
With Sheets("tmp")
.[B1] = "SoCT"
.Range("A2:M" & RowEnd).ClearContents
.Range("N2:Q" & RowEnd).ClearContents
.Range("A2").Resize(s, 13) = ArrNo
.Range("A2").Offset(s, 0).Resize(t, 13) = ArrCo
.Range("N2").Resize(u, 4) = ArrTK
Erase Arr(), ArrNo(), ArrCo(), ArrTK
With Sheets("Tmp")
endR = s + t + 1
'sort tmp
Set rngData = .Range(.Cells(1, 1), .Cells(endR, 13))
With .Sort
With .SortFields
.Clear
.Add Key:=Range("A1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayCT
.Add Key:=Range("B1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.Add Key:=Range("H1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 4 Tien No
.Add Key:=Range("I1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 5 Tien co
.SetRange rngData
.Header = xlYes ' co tieu de hay khong'
.Apply
'sort soct duy nhat
Set rngData = .Range("N2:Q" & u)
With .Sort
With .SortFields
.Clear
.Add Key:=rngData.Cells(1, 4), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayHT
.Add Key:=rngData.Cells(1, 1), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.SetRange rngData
.Header = xlNo ' co tieu de hay khong'
.Apply
Set rngData = Nothing
Sub ConvertGoc2Tmp()
Dim ArrKQ()
With Sheets("NKCGoc")
Arr = .Range("A3:I" & endR).Value
ReDim ArrKQ(1 To UBound(Arr), 1 To 9)
s = 0
If Len(Arr(i, 7)) > 0 Then
s = s + 1
ArrKQ(s, 1) = Arr(i, 1)
ArrKQ(s, 2) = Arr(i, 1) & ";" & Arr(i, 2)
ArrKQ(s, 3) = Arr(i, 3)
ArrKQ(s, 7) = CStr(Arr(i, 7))
ArrKQ(s, 4) = Arr(i, 4)
ArrKQ(s, 5) = Arr(i, 5)
ArrKQ(s, 6) = Arr(i, 6)
ArrKQ(s, 8) = Arr(i, 8) * 1
ArrKQ(s, 9) = Arr(i, 9) * 1
With Sheets("Tmp")
.[A2].Resize(RowEnd, 9).ClearContents
.[A2].Resize(s, 9) = ArrKQ
Set rngData = .Range("A2:I" & s + 1)
With .Sort
With .SortFields
.Clear
.Add Key:=rngData.Cells(1, 1), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayHT
.Add Key:=rngData.Cells(1, 2), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.Add Key:=rngData.Cells(1, 3), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 ngayCT
.SetRange rngData
.Apply
Erase Arr(), ArrKQ()
Private Function SheetExists(ShName) As Boolean
Dim x As Object
Set x = ActiveWorkbook.Sheets(ShName)
If Err = 0 Then SheetExists = True _
Else SheetExists = False
Sub TinhToan01()
'Truong hop nay danh cho 1N va 1C - Dem=2
soDong = 1
ArrKQ(soDong, 1) = arrNhan(1, 1) 'ngay HT
ArrKQ(soDong, 2) = sSoCT 'SoCT
ArrKQ(soDong, 3) = arrNhan(1, 3) 'NgayCT
ArrKQ(soDong, 4) = arrNhan(1, 4) 'diengiai
ArrKQ(soDong, ColTkNo) = arrCho(1, 7) 'TKNo
ArrKQ(soDong, ColTkCo) = arrNhan(1, 7) 'TKCo;
ArrKQ(soDong, 7) = arrNhan(1, 9) 'sotien
If arrNhan(1, 6) > 0 Then
ArrKQ(soDong, 14) = arrNhan(1, 10) 'MaKH
ArrKQ(soDong, 15) = arrNhan(1, 11) 'TenKH
ArrKQ(soDong, 16) = Round(arrNhan(1, 6) * ArrKQ(soDong, 7), 0) 'ST VND
GanArr
Sub TinhToan05()
Dim curCho&, curNhan&
Dim curSLCho As Double, curSLNhan As Double
Dim curSLChoDu As Double, curSLNhanThieu As Double, SLChia As Double
curCho = 0: curNhan = 0: s = 1
curSLNhanThieu = 0: curSLChoDu = 0: SLChia = 0
'Phan nay la nhieu no nhieu co
Do While Not (curCho = UBound(arrCho) And curSLChoDu = 0)
If curSLChoDu = 0 Then
curCho = curCho + 1
curSLCho = arrCho(curCho, 8)
curSLChoDu = curSLCho
If curSLNhanThieu = 0 Then
curNhan = curNhan + 1
curSLNhan = arrNhan(curNhan, 9)
curSLNhanThieu = curSLNhan
If curSLChoDu <= curSLNhanThieu Then
SLChia = curSLChoDu
SLChia = curSLNhanThieu
ArrKQ(s, 1) = arrCho(curCho, 1) 'Ngay HT
ArrKQ(s, 2) = sSoCT 'SoCT
ArrKQ(s, 3) = arrCho(curCho, 3) 'NgayCT
ArrKQ(s, 4) = arrCho(curCho, 4) 'Dien giai
ArrKQ(s, ColTkNo) = arrCho(curCho, 7) ' TK No
ArrKQ(s, ColTkCo) = arrNhan(curNhan, 7) ' TK Co
ArrKQ(s, 7) = SLChia 'So tien
If arrCho(curCho, 6) > 0 Then
ArrKQ(s, 14) = arrCho(curCho, 10) 'MaKH
ArrKQ(s, 15) = arrCho(curCho, 11) 'TenKH
ArrKQ(s, 16) = Round(arrCho(curCho, 6) * ArrKQ(s, 7), 0) 'ST VND
curSLChoDu = curSLChoDu - SLChia
curSLNhanThieu = curSLNhanThieu - SLChia
s = s + 1
Loop
soDong = s - 1
GanArr
'Phan code duoi day it khi dung
Sub TinhToan06()
'With Sheets("NKC")
'Phan nay la nhieu no nhieu co vµ tat ca la so <0
curCho = curCho + 1
If curSLChoDu >= curSLNhanThieu Then 'lay so < lon hon
SLChia = curSLChoDu
If arrCho(curCho, 6) > 0 Then 'Ti gia
ArrKQ(s, 16) = Round(ArrKQ(s, 7) * arrCho(curCho, 6), 0) 'VND
s = s + 1
Loop
soDong = s - 1
GanArr
Sub TinhToan02()
'Truong hop nay danh cho 1N va many C - Dem>2
soDong = UBound(arrNhan)
n = 1 '1 No
For i = 1 To soDong
For k = 1 To 4
ArrKQ(i, k) = arrNhan(i, k) '4 cot dau
Next k
For k = 14 To 16
ArrKQ(i, k) = arrNhan(i, k - 4) '3 cot sau
Next k
ArrKQ(i, ColTkNo) = arrCho(n, 7) 'TKNo
ArrKQ(i, ColTkCo) = arrNhan(i, 7) 'TKCo
ArrKQ(i, 7) = arrNhan(i, 9) 'So tien
If arrNhan(i, 6) > 0 Then
ArrKQ(i, 14) = arrNhan(i, 10) 'MaKH
ArrKQ(i, 15) = arrNhan(i, 11) 'TenKH
ArrKQ(i, 16) = Round(arrNhan(i, 6) * ArrKQ(i, 7), 0) 'ST VND
GanArr
Sub TinhToan03()
'Truong hop nay danh cho 1C va many N - Dem>2
'TH nay nguoc voi TinhToan02 - be care Tuan
soDong = UBound(arrCho)
n = 1 '1 No
For i = 1 To soDong
For k = 1 To 4
ArrKQ(i, k) = arrCho(i, k) '4 cot dau
Next k
ArrKQ(i, ColTkNo) = arrCho(i, 7) 'TKNo
ArrKQ(i, ColTkCo) = arrNhan(n, 7) 'TKCo
ArrKQ(i, 7) = arrCho(i, 8) 'So tien
If arrCho(i, 6) > 0 Then
ArrKQ(i, 14) = arrCho(i, 10) 'MaKH
ArrKQ(i, 15) = arrCho(i, 11) 'TenKH
ArrKQ(i, 16) = Round(arrCho(i, 6) * ArrKQ(i, 7), 0) 'ST VND
GanArr
Sub TinhToan04()
' TH neu so TK No = So TK Co, STien No(1)=sotienco(1), SotienNo(end)=sotienco(end)
'MsgBox "OK"
For i = 1 To soDong
For k = 1 To 4
Next k
GanArr
Sub TinhToan07()
' TH neu co nhieu TK No va khong co TK Co
For i = 1 To soDong
For k = 1 To 4
Next k
For k = 10 To 3
ArrKQ(i, k) = arrCho(i, k) '4 cot sau
Next k
ArrKQ(i, ColTkCo) = "" 'TKCo
GanArr
Sub TinhToan08()
' TH neu co nhieu TK Co va khong co TK No
n = 1 '1 No
For i = 1 To soDong
For k = 1 To 4
Next k
For k = 10 To 13
ArrKQ(i, k) = arrNhan(i, k) '4 cot sau
Next k
ArrKQ(i, ColTkNo) = "" 'arrCho(n, 7) 'TKNo
GanArr
Code là như vậy, giới hạn dòng của e là 1 triệu dòng
