happyghost2000
Em có đoạn code copy. Khi em chạy Getdata thì dữ liệu copy qua bị thiếu.
Em gủi 2 file : File data & file tổng họp.
Mong các AC giúp dùm em , chỉnh code lại cho nó lấy hết dữ liệu dùm em .
Em xin cám ơn
Em xin cám ơn
Function GetData(ByVal FileName As String, ByVal SheetName As String, ByVal RangeAddress As String, _
ByVal HasTitle As Boolean, ByVal UseTitle As Boolean)
Dim rsCon As Object, rsData As Object, cat As Object, tbl As Object
Dim tmpArr, Arr()
Dim szConnect As String, szSQL As String, tmp As String
Dim lCount As Long, lR As Long, lC As Long, lVer As Long
lVer = Val(Application.Version)
Set rsCon = CreateObject("ADODB.Connection")
Set rsData = CreateObject("ADODB.Recordset")
Set cat = CreateObject("ADOX.Catalog")
If lVer < 12 Then
szConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & FileName & ";" & _
"Extended Properties=""Excel 8.0;HDR=" & IIf(HasTitle, "Yes", "No") & """;"
szConnect = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & FileName & ";" & _
"Extended Properties=""Excel 12.0;HDR=" & IIf(HasTitle, "Yes", "No") & """;"
If SheetName = "" Then
Dim Dbs As Object, db As Object
Set Dbs = CreateObject("DAO.DBEngine." & IIf(lVer < 12, "36", "120"))
Set db = Dbs.OpenDatabase(FileName, False, False, "Excel 8.0;")
tmp = db.TableDefs(0).Name
tmp = Replace(tmp, " ", "?")
tmp = Replace(tmp, "'", " ")
tmp = WorksheetFunction.Trim(tmp)
tmp = Replace(tmp, " ", "'")
tmp = Replace(tmp, "?", " ")
SheetName = tmp
db.Close
Set Dbs = Nothing: Set db = Nothing
If Right(SheetName, 1) <> "$" Then SheetName = SheetName & "$"
rsCon.Open szConnect
cat.ActiveConnection = rsCon
szSQL = "SELECT * FROM [" & SheetName & RangeAddress & "];"
rsData.Open szSQL, rsCon, 0, 1, 1
tmpArr = rsData.GetRows
ReDim Arr(UBound(tmpArr, 2) - UseTitle, UBound(tmpArr, 1) + 1)
If UseTitle Then
For lC = LBound(tmpArr, 1) To UBound(tmpArr, 1)
Arr(0, lC) = rsData.Fields(lC).Name
For lR = LBound(tmpArr, 2) To UBound(tmpArr, 2)
Arr(lR - UseTitle, lC) = tmpArr(lC, lR)
rsData.Close: Set rsData = Nothing
rsCon.Close: Set rsCon = Nothing
GetData = Arr
Sub Main()
Dim vFile, FileItem, aRes, Target As Range
Dim FileName As String, SheetName As String, RangeAddress As String
vFile = Application.GetOpenFilename("Excel File, *.xls; *.xlsx; *.xlsm", , , , True)
If TypeName(vFile) = "Variant()" Then
SheetName = "Sheet1": RangeAddress = "A2:L10000"
For Each FileItem In vFile
FileName = CStr(FileItem)
If UCase(FileName) <> UCase(ThisWorkbook.FullName) Then
aRes = GetData(FileName, SheetName, RangeAddress, False, False)
If IsArray(aRes) Then
Set Target = Sheet1.Range("A60000").End(xlUp).Offset(1)
Target.Resize(UBound(aRes, 1) + 1, UBound(aRes, 2) + 1).Value = aRes
MsgBox "Done!"
