Chào anh chị, nhờ anh chị sửa code để chạy nhanh hơn!!! (5 người xem)
nguyenanhdung8111982
Em có đoạn code như dưới dùng để đếm tổng số file hình có đuôi mở rộng là '.jpg' hoặc '.JPG' trong từng subfolder. em đếm khoảng 17k hình. nhờ anh chị giúp chỉnh sửa code để chạy nhanh hơn!!!
Sub DemfileJPG1()
Dim FolderName As String
Sheets("sheet1").Select
Cells(1, 1).Value = 2
With Application.FileDialog(msoFileDialogFolderPicker)
        .AllowMultiSelect = False
        '.Title = "Select an image file"
        .Show
        '.AllowMultiSelect = True
        .Filters.Clear
        '.Filters.Add "JPG", ".JPG"
        '.Filters.Add "JPEG File Interchange Format", ".JPEG"
    FolderName = .SelectedItems(1)
    Err.Clear
    On Error GoTo 0
ListFolders (FolderName)
MsgBox "Done" & vbCrLf & "Total files found: " & Cells(1, 1).Value
Cells(1, 1).Value = "Source"
Cells(1, 2).Value = "Folder"
Cells(1, 3).Value = "Subfolder"
Cells(1, 4).Value = "FileCount"
Sub ListFolders(Fldr As String)
Dim fs
    Set fs = CreateObject("Scripting.FileSystemObject")
Dim fl1
    Set fl1 = CreateObject("Scripting.FileSystemObject")
Dim fl2
    Set fl2 = CreateObject("Scripting.FileSystemObject")
Set fl1 = fs.GetFolder(Fldr)
For Each fl2 In fl1.SubFolders
    Cells(Cells(1, 1).Value, 1).Value = Replace(Fldr, fl1.Name, "")
    Cells(Cells(1, 1).Value, 2).Value = fl1.Name
    Cells(Cells(1, 1).Value, 3).Value = fl2.Name
    Cells(Cells(1, 1).Value, 4).Value = CountFiles(Fldr & "\" & fl2.Name)
    Cells(1, 1).Value = Cells(1, 1).Value + 1
    ListFolders fl2.Path
Private Function CountFiles(strDirectory As String, Optional strExt As String = ".JPG", Optional strExt1 As String = ".jpg") As Double
'Private Function CountFiles(strDirectory As String, Optional strExt As String = ".JPG") As Double
'Author          : Ken Puls (www.excelguru.ca)
'Function purpose: To count files in a directory.  If a file extension is provided,
'   then count only files of that type, otherwise return a count of all files.
    Dim objFSO As Object
    Dim objFiles As Object
    Dim objFile As Object
    'Set Error Handling
    On Error GoTo EarlyExit
    'Create objects to get a count of files in the directory
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    Set objFiles = objFSO.GetFolder(strDirectory).Files
    'Count files (that match the extension if provided)
    'If strExt = "*.*" Then
    'If strExt <> ".jpg" Or strExt1 <> ".JPG" Then
    'If strExt = ".JPG" Or strExt1 = ".jpg" Then
    'If strExt = ".JPG" Then
    If strExt = ".csv" Then
        CountFiles = objFiles.Count
        For Each objFile In objFiles
            'If UCase(Right(objFile.Path, (Len(objFile.Path) - InStrRev(objFile.Path, ".")))) = UCase(strExt) Then
            'If UCase(Right(objFile.Path, (Len(objFile.Path) - InStrRev(objFile.Path, ".JPG")))) = UCase(strExt) Then
            If Right(objFile.Path, 4) = ".JPG" Or Right(objFile.Path, 4) = ".jpg" Then
              'If UCase(objFile.Path) Like ".JPG" Then
               CountFiles = CountFiles + 1
        Next objFile
'Loop
EarlyExit:
    'Clean up
    Set objFile = Nothing
    Set objFiles = Nothing
    Set objFSO = Nothing
    On Error GoTo 0
Trân trọng,
Nguyen Anh Dung
Bạn dùng hàm Dir() xem sao.
Public Function countFiles(strDir As String, Optional strType As String) As Long
    Dim file As String, i As Long
    If Right(strDir, 1) <> "\" Then strDir = strDir & "\"
    file = Dir(strDir & strType)
    While (file <> "")
        i = i + 1
        file = Dir
    Wend
    countFiles = i
Áp dụng:
Sub Test()
    Msgbox countFiles("D:\Hinh\", "*.jpg*")
Sub DemfileJPG1()
        .Show
        .Filters.Clear
    Err.Clear
    On Error GoTo 0
Dim fs
Dim fl1
Dim fl2
    'Set Error Handling
        Next objFile
'Loop
EarlyExit:
    'Clean up
    On Error GoTo 0
Trân trọng,
Nguyen Anh Dung
Chạy code
Option Compare Text
Sub Demfile_JPG()
  Dim Res(0 To 100000, 1 To 4)
  Dim k As Long, FolderName As String
    .Show
    If .SelectedItems.Count = 0 Then MsgBox ("Phai Chon Thu Muc!"): Exit Sub
  If FolderName <> Empty Then
    Res(0, 1) = "Source":       Res(0, 2) = "Folder"
    Res(0, 3) = "Subfolder":    Res(0, 4) = "FileCount"
    Call ListFolders(Res, k, FolderName)
    Range("A1").Resize(k + 1, 4) = Res
    MsgBox "Done" & vbCrLf & "Total files found: " & k
Private Sub ListFolders(ByRef Res, ByRef k, ByVal Fldr As String)
  Dim fs As Object, fd As Object, fdSub As Object
  Set fd = fs.GetFolder(Fldr)
  For Each fdSub In fd.SubFolders
    Res(k, 1) = Replace(Fldr, fd.Name, "")
    Res(k, 2) = fd.Name
    Res(k, 3) = fdSub.Name
    Res(k, 4) = 0
    Call CountFiles(Res, k, Fldr & "\" & fdSub.Name)
    Call ListFolders(Res, k, fdSub.Path)
  Set fs = Nothing:   Set fd = Nothing:   Set fdSub = Nothing
Private Sub CountFiles(ByRef Res, ByRef k, ByVal strDirectory As String)
  Dim objFSO As Object, objFiles As Object, objFile As Object
    If Right(objFile.Path, 4) = ".JPG" Then
      Res(k, 4) = Res(k, 4) + 1
  Next objFile
  Set objFSO = Nothing:   Set objFiles = Nothing
Chạy code
Option Compare Text
Sub Demfile_JPG()
    .Show
    Res(k, 2) = fd.Name
    Res(k, 4) = 0
  Next objFile
Cám ơn bạn, cách này chạy cũng chậm giống như của mình. Cám ơn bạn!!!
Em đoán chủ thớt tìm tới FileSystemObject vì vụ đường dẫn có ký tự có dấu. Dir() không xử lý được vụ đó.
Đường dẫn thư mục không có dấu bạn ơi!!!
ý mình là có thể cải thiện vòng lặp nào để chạy nhanh hơn!!!
Bao nhiêu lâu thì mí được gọi là nhanh????
Mình test với 200 thư mục tốc độ code của mình nhanh gần 2 lần code gốc
Cái này sao không dùng command line bạn?
Dir /s /b "đường dẫn" *.jpg | find /c ":"
