Nhờ anh chị Fix lỗi muốn Copy tiêu đề từ file nguồn sang Workbook mới (1 người xem)
  • Thread starter Thread starter quyenpv
quyenpv
Thu nhặt kiến thức
Decode cuộc đời!
Dear anh chị
Nhờ anh chị Fix lỗi muốn Copy tiêu đề từ file nguồn sang Workbook mới bị lỗi
Sub CV_ChuaHoanThanh()
    ActiveWorkbook.Sheets("Data").Select
    Dim lr As Long
    Dim lrLoc As Long
    Dim sRootFolder, sFolder_Unfinished As String
    Dim sDauky, sCuoiky
    sRootFolder = ActiveWorkbook.Sheets("Setting").Range("K8")
    sFolder_Unfinished = ActiveWorkbook.Sheets("Setting").Range("K10")
    sDauky = Format(ActiveWorkbook.Sheets("Report").Range("Dauky"), "dd-mm-yyyy")
    sCuoiky = Format(ActiveWorkbook.Sheets("Report").Range("cuoiky"), "dd-mm-yyyy")
    Dim filename As Workbook
    If Len(Dir(sRootFolder & "\" & sFolder_Unfinished, vbDirectory)) = 0 Then
        MkDir (sRootFolder & "\" & sFolder_Unfinished)
    ActiveWorkbook.Sheets("Data").Range("A5:O5").Copy
    StopCalc
    Dim i&, k, Data(), Kq(), Sort(), lastRow
    Data = Range(Sheets("Data").[A6], Sheets("Data").[A10000].End(3)).Resize(, 15)
    ReDim Kq(1 To UBound(Data), 1 To 15)
    For i = 1 To UBound(Data)
        If Data(i, 11) <> "" And Data(i, 11) <> ActiveWorkbook.Sheets("Setting").Range("I2") Then
            Kq(k, 1) = k:               Kq(k, 2) = Data(i, 2)
            Kq(k, 3) = Data(i, 3):      Kq(k, 4) = Data(i, 4)
            Kq(k, 5) = Data(i, 5):      Kq(k, 6) = Data(i, 6)
            Kq(k, 7) = Data(i, 7):      Kq(k, 8) = Data(i, 8)
            Kq(k, 9) = Data(i, 9):      Kq(k, 10) = Data(i, 10)
            Kq(k, 11) = Data(i, 11):    Kq(k, 12) = Data(i, 12)
            Kq(k, 13) = Data(i, 13):    Kq(k, 14) = Data(i, 14)
            Kq(k, 15) = Data(i, 15)
    Set filename = Workbooks.Add
    Range("A5").Select
    ActiveSheet.Paste
    With filename.Worksheets("Sheet1")
        .Range("A6").Resize(k, 15).Value = Kq
        .Range("D6:d" & 6 + k).WrapText = 1
        .Columns("B:B").NumberFormat = "dd/mm"
        .Columns("D:D").ColumnWidth = 53
        .Columns("G:G").NumberFormat = "dd/mm"
        .Columns("J:J").Style = "Percent"
    '  filename.Worksheets("Sheet1").Rows(1, 99999).Autofit
    filename.SaveAs filename:=sRootFolder & "\" & sFolder_Unfinished & "\" & "Cong Viec Chua Hoan Thanh tu " & sDauky & " den " & sCuoiky
    'ActiveWorkbook.Close
    ResetCalc
    'End If
Dear anh chị
    Dim lr As Long
    Dim lrLoc As Long
    Dim sDauky, sCuoiky
    StopCalc
    Range("A5").Select
    ActiveSheet.Paste
    ResetCalc
    'End If
Đã có lệnh nào copy đâu mà paste nhỉ?
Chỉ có
    Range("A5").Select
    ActiveSheet.Paste
Dạ trên đó a
    StopCalc
Kiểm tra lại thường người ta phải đặt copy paste sát nhau, hoặc có khi cùng lệnh luôn
Đặt trước xa thế, sau khi 1 số lệnh có khi hiệu ứng COPY đã mất, nên Kiểm tra kỹ điều này
Thanks a, em đã fix lại chỗ này được rồi ạ. Em đưa trước câu lệnh Workbooks.Add
