Nhờ anh em sửa lỗi dùm ạ, sao không load được dữ liệu. Thanks all.
'http://priceboard.vcbs.com.vn/Priceboard/
Public Sub ShowForm()
UserForm1.Show
Public Sub hello(ByVal selectedStocks As String, ByVal criteriaId As String, ByVal pthMktId As String)
Dim str As String, payload As String, arr
'template Payload:{"selectedStocks":"AAM,ABT","criteriaId":"-11","marketId":0,"lastSeq":0,"isReqTL":false,"isReqMK":false,"tlSymbol":"","pthMktId":""}
payload = "{""selectedStocks
""" & selectedStocks & """,""criteriaId
""" & criteriaId & """,""marketId
0,""lastSeq
0," & _
"""isReqTL
false,""isReqMK
false,""tlSymbol
"""",""pthMktId
""" & pthMktId & """}"
With CreateObject("MSXML2.ServerXMLHTTP")
.Open "POST", "http://priceboard.vcbs.com.vn/Priceboard/", False
.setRequestHeader "Content-Type", "application/json"
.send (payload)
str = .ResponseText
If Len(pthMktId) = 0 Then
arr = tachBangGia(str)
arr = tachGDTT(str)
Sheet1.Range("A5").Resize(UBound(arr) + 1000, UBound(arr, 2) + 50).ClearContents
Sheet1.Range("A5").Resize(UBound(arr), UBound(arr, 2)).Value = arr
Private Function tachBangGia(ByVal stResponse As String)
Dim lStart As Long, lEnd As Long, arr, dArr, dicColName As Object, r As Long
Dim rowData, cellData, c As Long, colIndex As Long
Dim regec As Object, mats As Object, mat As Object
Set dicColName = CreateObject("Scripting.Dictionary")
dicColName.CompareMode = vbTextCompare
arr = Array("SB", "CL", "FL", "RE", "B3", "V3", "B2", "V2", "B1", "V1", "CH", "CP", "CV", "S1", _
"U1", "S2", "U2", "S3", "U3", "TT", "OP", "HI", "LO", "FB", "FS", "FR")
For r = 0 To UBound(arr) Step 1
dicColName(arr(r)) = r + 1
ReDim dArr(1 To 1000, 1 To dicColName.Count)
tachBangGia = dArr
lStart = WorksheetFunction.Max(1, InStr(1, stResponse, """f
lEnd = InStr(lStart, stResponse, "],")
If lStart < 2 Or lEnd < 2 Then Exit Function
stResponse = Replace(Mid(stResponse, lStart, lEnd - lStart + 1), "\""", "")
arr = Split(stResponse, "Id:")
Set regec = CreateObject("VBScript.RegExp")
regec.Pattern = "[A-Z][A-Z0-9]\:[^,]*(,\d+)*"
'[A-Z][A-Z0-9]\:.*?(?=,[A-Z][A-Z0-9]\
regec.Global = True
For r = LBound(arr) + 1 To UBound(arr) Step 1
Set mats = regec.Execute(arr(r))
For Each mat In mats
cellData = Split(mat, ":")
If dicColName.exists(cellData(0)) Then
colIndex = dicColName(cellData(0))
dArr(r, colIndex) = IIf(CStr(cellData(1)) = "null", "", cellData(1))
tachBangGia = dArr
Private Function tachGDTT(ByVal stResponse As String)
Dim lStart As Long, lEnd As Long, dicColName As Object, arr, dArr, r As Long
Dim colIndex As Long, rowData, colName As String, cellData, c As Long
arr = Array("Symbol", "Price", "MatchVol", "fake", "Time")
tachGDTT = dArr
lStart = WorksheetFunction.Max(1, InStr(1, stResponse, """pm
lEnd = InStr(lStart, stResponse, "}]")
stResponse = Replace(Mid(stResponse, lStart, lEnd - lStart + 2), """", "")
arr = Split(stResponse, "{Id:")
rowData = Split(arr(r), ",")
For c = LBound(rowData) + 1 To UBound(rowData) Step 1
lStart = InStr(1, rowData(c), ":")
If lStart > 0 Then
cellData = Mid(rowData(c), lStart + 1)
colName = Left(rowData(c), lStart - 1)
If dicColName.exists(colName) Then
colIndex = dicColName(colName)
If colIndex = 2 Then
dArr(r, colIndex) = cellData / 1000
dArr(r, 4) = "=RC[-2] * RC[-1]"
tachGDTT = dArr
Public Function createVcbsList()
Dim arr(1 To 50, 1 To 4), curRow As Long, str As String
.Open "GET", "http://priceboard.vcbs.com.vn/Priceboard/", False
.send
str = .ResponseText
tachGroup str, arr, "HOSE", curRow
tachGroup str, arr, "HNX", curRow
tachGroup str, arr, "UPCOM", curRow
createVcbsList = arr
Private Sub tachGroup(ByVal stResponse As String, ByRef arr, groupName As String, ByRef curRow As Long)
Dim lStart As Long, lEnd As Long, mats As Object, mat As Object
Static regec As Object, domDoc As Object
lStart = InStr(1, stResponse, "id=""" & groupName & "_Group""")
lEnd = InStr(lStart, stResponse, "</ul>")
If regec Is Nothing Then
regec.Pattern = "onclick\=\""selectTab\(([^\)]+)[\s\S]+?(<p>[\s\S]+?</p>)[\s\S]+?(value\=\""([\s\S]+?))?</li>"
regec.IgnoreCase = True
regec.Global = True
Set domDoc = CreateObject("Msxml2.DOMDocument")
Set mats = regec.Execute(Mid(stResponse, lStart, lEnd - lStart + 5))
curRow = curRow + 1
arr(curRow, 1) = groupName
domDoc.LoadXML mat.submatches(1)
arr(curRow, 2) = domDoc.Text
arr(curRow, 3) = mat.submatches(0)
If Len(mat.submatches(3)) > 0 Then
arr(curRow, 4) = Left(mat.submatches(3), InStr(1, mat.submatches(3), """") - 1)
UserForm1.Show
0,""lastSeq
0," & _"""isReqTL
false,""isReqMK
false,""tlSymbol
"""",""pthMktId
""" & pthMktId & """}"With CreateObject("MSXML2.ServerXMLHTTP")
.send (payload)
str = .ResponseText
arr = tachGDTT(str)
tachBangGia = dArr
["))lEnd = InStr(lStart, stResponse, "],")
regec.Global = True
tachBangGia = dArr
tachGDTT = dArr
["))lEnd = InStr(lStart, stResponse, "}]")
If lStart > 0 Then
tachGDTT = dArr
.send
str = .ResponseText
regec.Global = True
curRow = curRow + 1
